Old May 11th, 2011, 06:58 AM   #41
bp328i
bp328i's Avatar
Motorcycle(s): 2010 Ninja 250
Originally Posted by bob138 View Post
This about moment of inertia I believe.
http://en.wikipedia.org/wiki/Moment_of_inertia
Bob
Copied right from the link.
The moment of inertia of an object about a given axis describes how difficult it is to change its angular motion about that axis. Therefore, it encompasses not just how much mass the object has overall, but how far each bit of mass is from the axis. The farther out the object's mass is, the more rotational inertia the object has, and the more force is required to change its rotation rate. For example, consider two hoops, A and B, made of the same material and of equal mass. Hoop A is larger in diameter but thinner than B. It requires more effort to accelerate hoop A (change its angular velocity) because its mass is distributed farther from its axis of rotation: mass that is farther out from that axis must, for a given angular velocity, move more quickly than mass closer in. So in this case, hoop A has a larger moment of inertia than hoop B.
bp328i is offline   Reply With Quote
Old May 11th, 2011, 07:21 AM   #42
want1sobad
Ninjette CPT
want1sobad's Avatar
Motorcycle(s): Black 08 250r
.........i didn't say it would be a big difference keep in mind, there is in fact more mass from the axis due to the larger rim width even though the wheels are the same diameter. although, it's effect on the moment of inertia is probably negligible......
happy trails
want1sobad is offline   Reply With Quote
Old May 11th, 2011, 10:07 AM   #43
dubojr1
dubojr1's Avatar
So... In short there will probably be no noticeable difference.
Old May 11th, 2011, 10:17 AM   #44
bp328i
bp328i's Avatar
Actually there would be a very noticeable difference if we think about this for one second.
Your bike would look completely awesome from the rear with this done!
Old May 11th, 2011, 10:23 AM   #45
dubojr1
dubojr1's Avatar
Old June 16th, 2011, 04:24 PM   #46
slolane
Motorcyclist
slolane's Avatar
Motorcycle(s): 2014 Ninja 300 ABS
Ordered THIS real wheel from Matt last weekend, can't wait for it to arrive. I'm currently running a BT016 150/60 on the stock wheel.
Once it arrives I will post some before and after pics.
slolane is offline   Reply With Quote
Old June 16th, 2011, 04:31 PM   #47
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
im considering this rim myself or just modifying a zx6 rim to put on.. undecided what i wanna do. curious to see pics when you get it on.
greatwhiteninja is offline   Reply With Quote
Old June 18th, 2011, 12:03 AM   #48
almost40
ninjette.org Monkey Spank
almost40's Avatar
Big rim is a waste of money for track riders. The rear traction isnt an issue. Slap a 150 or a 140 on the stocker and ride. If a wider rim is ok per the rules, I would think SOMEONE would be racing it if indeed it was better.
ANYONE RACING A 4.5 inch rim????? (if you can)
$700 for the wider rear tire look?? (with a new tire)
Whatever. To each his own.
Black 250R
Full Area P QC
Old June 18th, 2011, 12:23 AM   #49
rusninja
Ninjette wanabe :D
rusninja's Avatar
Motorcycle(s): white 300 :D
id love like a 160/60 on the ninja x]
VROOOM vrooom >.>
rusninja is offline   Reply With Quote
Old June 20th, 2011, 10:31 PM   #50
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
I don't run a 140 or a 150 on my race bike I run a 120 front on the rear. I don't sell it as a racing app. The rim weighs 12 pounds if anyone was curious.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old June 21st, 2011, 09:46 AM   #51
almost40
almost40's Avatar
I know you dont, I was making a point is all. Is there a 130/60??
Black 250R
Full Area P QC
Old June 21st, 2011, 12:07 PM   #52
slolane
Motorcyclist
slolane's Avatar
Yeh, I'm not interested in racing so really doesn't matter to me what may work better for that application. I'm sharing my mods as I go with pics, a comparison and review once installed to help others who may also be interested.
Old June 22nd, 2011, 05:45 PM   #53
slolane
Motorcyclist
slolane's Avatar
Got my wheel today.
Unwrapped...
Next to our 2011 250 with stock wheel and 130 tire...
Some mounted shots...
After a short test ride I see I was able to easily use more tire, I didn't have time to ride out to some nice twisties but it was a good test still...
Old June 22nd, 2011, 07:08 PM   #54
warlord
warlord's Avatar
Motorcycle(s): 2014 Ducati Panigale 899
Looking good, James! Seriously good looking upgrade. Was it really plug and play?
warlord is offline   Reply With Quote
Old June 22nd, 2011, 07:13 PM   #55
dubojr1
dubojr1's Avatar
Looks good James. I am curious how I ordered mine a couple weeks before you and mine has yet to arrive. Guess I need check with Matt again to find out whats going on.
Btw... What's your total investment?
Old June 22nd, 2011, 08:07 PM   #56
slolane
Motorcyclist
slolane's Avatar
Thanks, I'm happy with the result. It was a pretty easy swap... I had to move the cush drive/sprocket, brake rotor and a dust seal and snap ring clip for the bearing.
Thank you. I'm not sure about the shipping there, mine took 11 days to be delivered. Total into the wheel setup or entire bike? For the wheel I was already running the 150 BT016 on the stock rear wheel so I just had to purchase the new wheel and swap everything over.
Old June 22nd, 2011, 10:14 PM   #57
chitor
Ninja Master
chitor's Avatar
Very nice upgrade! Looks really good. I read somewhere that you need to watch out for the wheel bearing, you can change it to an original part if the bearings are damaged already.
I'll change mine also but It will be a conversion kit from ER6f mags, sprockets, etc. It will be more expensive since all parts will come from Kawasaki dealer except for the conversion kit.... I decided to do it because I have no plans of selling the bike, its a keeper!
chitor is offline   Reply With Quote
Old June 22nd, 2011, 10:20 PM   #58
ztrack157
The Sportisi Master
ztrack157's Avatar
I Actually pay more to have these rims come installed with brand new bearings.
Old June 22nd, 2011, 10:51 PM   #59
chitor
Ninja Master
chitor's Avatar
Good to know that. Too bad for me since I already ordered the parts from Kawasaki before I learned that there is already plug and play rim available already in the market... I could have saved hundreds of dollars.
Old June 22nd, 2011, 11:58 PM   #60
rusninja
Ninjette wanabe :D
rusninja's Avatar
Its so beautiful you think you can fit a 160/60 on :S?
VROOOM vrooom >.>
Old June 23rd, 2011, 07:27 AM   #61
slolane
Motorcyclist
slolane's Avatar
Thanks, I appreciate it. I'm loving this upgrade! Please post up your wheel swap too, I would be interested to see that too. I have no plans of selling this bike either so I agree, why not make it exactly what you want for a few hundred here and there... that's way cheaper than buying another bike and this is one of the cheapest I have owned, good cheap fun.
Good stuff Matt. Thanks again for this and all the help in answering my many emails.
I know different manufactures have all sorts of sizing differences but I'm not sure a 160/60 would work. I think my Bridgestone BT016 in 150/60 is about a big as your going to get in there. Maybe Matt (ztrack157) would know the largest that would fit?
Old June 23rd, 2011, 10:25 AM   #62
dubojr1
dubojr1's Avatar
Woohoo!!! Mine should be here next week.
BTW... I was one of the first to try this mod on here (http://www.ninjette.org/forums/showthread.php?t=54118) and can say the 650R's wheel will have to have major machine work for it to work. I'll be selling off my 650R parts now (http://www.ninjette.org/forums/showthread.php?t=57233). I'm really looking forward to this mod.
Old June 23rd, 2011, 10:57 AM   #63
ztrack157
The Sportisi Master
ztrack157's Avatar
I think a 160 would fit. But you would have to ditch the chain guard
Old June 23rd, 2011, 11:58 AM   #64
slolane
Motorcyclist
slolane's Avatar
Sweet, glad it's coming soon. They have to travel a long way so based on where you live it may take a different route, just guessing. No matter, when you get it the wait will be worth it.
I read that other thread, that is A LOT of work to do, this wheel from Matt is really an easy way to do it and it all bolts/lines up perfectly, no worries.
Ahh, yeah that could work, great point. I'm really happy with the 150 myself.
Old June 23rd, 2011, 03:49 PM   #65
joes280
Motorcycle(s): 250
can u post full bike pics
can you post some full bike pics from the rear for perspective. I think I might pull the trigger, if it only took 11days to arrive.
I'm like you, the bike is cheap, the mods are relatively cheap and I enjoy the bike to much to get rid of it.
joes280 is offline   Reply With Quote
Old June 23rd, 2011, 04:03 PM   #66
rusninja
Ninjette wanabe :D
rusninja's Avatar
Anyway of modding the chain guard :S? Or will it be inaffective then?
VROOOM vrooom >.>
Old June 23rd, 2011, 04:04 PM   #67
rusninja
Ninjette wanabe :D
rusninja's Avatar
and would it be pinching like if you put a bigger tire on the stocker?
VROOOM vrooom >.>
Old June 23rd, 2011, 05:09 PM   #68
chitor
Ninja Master
chitor's Avatar
I would be getting the "Bigfoot mod" here. It will cost more, but the designer of the kit is my friend and it was too late when I learned that there's a plug and play rim already, I already ordered and payed for the ER6 parts. Good for you guys who will be getting the plug and play rim. It's cheaper and worth the $. Good decision guys.
Old June 23rd, 2011, 08:20 PM   #69
slolane
Motorcyclist
slolane's Avatar
Will do, won't be until Monday but I can do those and any other angles you want of the rear tire, profile, etc.
I'm sure yours will turn out sweet, post up some pics and details of your project please, I would love to check that out.
Old June 23rd, 2011, 08:28 PM   #70
chitor
Ninja Master
chitor's Avatar
Will post pics as soon as it is done. All parts will be completed by 1st week of July. I'll be using a Pirelli Diablo 150/60/17.
Old June 23rd, 2011, 09:47 PM   #71
ztrack157
The Sportisi Master
ztrack157's Avatar
There is only one way to tell. But I'm not going to install a 160 or a new rim on my bike for a test fit.
Old June 23rd, 2011, 11:31 PM   #72
rusninja
Ninjette wanabe :D
rusninja's Avatar
I know, I was just wondering if you took a bit off the chain guard over the chain would it not serve its purpose? :S Because its there so your pants dont get caught in the chain right :S?
VROOOM vrooom >.>
Old June 25th, 2011, 11:59 AM   #73
ztrack157
The Sportisi Master
ztrack157's Avatar
it is more for keeping the undertail clean.
Old June 27th, 2011, 04:20 PM   #74
slolane
Motorcyclist
slolane's Avatar
Took a bunch of pics for you, I haven't ridden it since the other day but look forward to getting it out this week and weekend more.
Old June 27th, 2011, 05:16 PM   #75
chitor
Ninja Master
chitor's Avatar
The rear wheel doesn't seem to be aligned?
Old June 27th, 2011, 10:24 PM   #76
joes280
Motorcycle(s): 250
thank you...that looks great
Old June 28th, 2011, 07:22 AM   #77
dubojr1
dubojr1's Avatar
Why do you say that?
Old June 28th, 2011, 11:28 AM   #78
I noticed the same thing. Check out the picture below. it sure looks like the wheel/tire is mounted to the left of center when compared to the tailsection of the bike. It might be an illusion in the picture due to the bags.
Old June 28th, 2011, 11:49 AM   #79
slolane
Motorcyclist
slolane's Avatar
I lined up the notches (as usual) on the swingarm, after work I will take a peek at again to ensure it's good. Thanks
Old June 28th, 2011, 11:50 AM   #80
dubojr1
dubojr1's Avatar
I think it is a illusion due to the angle the picture was taken. If you look closely you can see that more of the left fairing is showing than is the right. This means the picture was not taken straight on and I believe as the bike is rotated, with the front of the bike moving to the right just enough so the right fairing is showing just as much as the left, the red line I drew in will come around to the left a bit to align it perfectly in the center of the tire. The mirrors are another good source. See how most of the left mirror is showing and little of the right one is. Hope this makes sense.
[motorcyclistonline] - Plug and Play, or Pray? | Answers Ninjette Newsbot Motorcycling News 0 May 27th, 2014 07:30 PM
FS: VROSSI 3" Front & 4.5" Rear, Plug & Play for Ninja250 (08-12) & Ninja300 n250r Motorcycle-related 1 January 19th, 2014 07:39 PM
L.E.D Dioded mod, Plug and play!! Syphontek 2008 - 2012 Ninja 250R Farkles 2 July 7th, 2012 07:11 PM
Koso rx-2 plug and play kit F/S dyeforever Motorcycle-related 2 May 14th, 2011 02:31 PM
[motorcycledaily.com] - Plug-and-Play Ninjette Newsbot Motorcycling News 0 August 7th, 2009 01:20 AM
