Old January 20th, 2012, 02:54 AM   #121
wandyhee
wandyhee's Avatar
Motorcycle(s): 2010 250R FI, 2006 ZX10R
recommended size are 120/60/17 & 150/60/17. I've installed 160 rear because there are no such size stock available at the time, anywhere in my town. everything else such like chain & sprocket are still standard (oem)
I'm Selling wider (4.5" & 5") aftermarket Wheel for N250r/N300r/Z250/Z250r
wandyhee is offline   Reply With Quote
Old January 28th, 2012, 10:23 PM   #122
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
does it rub with tyre flex??
ninja250r81 is offline   Reply With Quote
Old January 29th, 2012, 12:18 AM   #123
air_rick
air_rick's Avatar
Motorcycle(s): 08 ninja 250R
$315 shipped for front and 4.5 rear rim without modding anything??
So the "VROSSI 3" front & 4.5" rear" rim set that you are selling on your blog site needs no modification and will work with what we currently have on our stock rear wheel (rear sprocket, rotor, etc)? -- If so I'm in!
air_rick is offline   Reply With Quote
Old January 29th, 2012, 08:20 AM   #124
wandyhee
wandyhee's Avatar
didn't see any rubbing mark.. but if you hesitate, just slap those 150/60 for peace in mind.
rear sprocket, rotor, etc. will fit on like OEM wheel.
Old February 1st, 2012, 03:19 AM   #125
wandyhee
wandyhee's Avatar
2 sets of Vrossi wheel will be ship out to USA before this friday
Old February 1st, 2012, 11:26 AM   #126
ws6lt4
Motorcycle(s): 2005 zx6r, 2009 250R
Woo hoo... one of those sets is mine. Well technically they are really for the GF's bike, but either way I'm stoaked.
I'll post up some pictures when I get them installed.
They are going to be stripped and powdercoated gold to match her Pazzo levers... the bike is pearl black with a undertail and flush mounts, GSXR muffler.
~Shea
ws6lt4 is offline   Reply With Quote
Old February 1st, 2012, 12:25 PM   #127
air_rick
air_rick's Avatar
The other is mine! I just bought a 160 tire to put on it! Cant wait! will post pics after its installed too
Old February 1st, 2012, 01:27 PM   #128
n250r
Motorcycle(s): 2009 Blue Ninja 250r
wandyhee,
Can you get me a set as well please?
n250r is offline   Reply With Quote
Old February 1st, 2012, 01:50 PM   #129
You know, we'll still be able to tell it's a 250 right?
Just giving you a rough time.
I think it looks cool, I just am not sold on the performance "gains" of going with significantly wider tires.
Definitely post pictures. Modded 250's that are state-side are always cool to see
Old February 1st, 2012, 02:06 PM   #130
air_rick
air_rick's Avatar
Lol I know haha oh well my friends who dont know anything about bikes wont.
Old February 1st, 2012, 07:29 PM   #131
wandyhee
wandyhee's Avatar
Originally Posted by n250r View Post
wandyhee,
yep, currently more stock available
Last futzed with by wandyhee; February 26th, 2012 at 10:06 PM.
Old February 2nd, 2012, 08:00 AM   #132
GlassAnkles
GlassAnkles's Avatar
Motorcycle(s): 02 zx-12r, 13 zx-10r abs
i went with the same size tires you have, but metzler sportec m3's. i may order a longer chain now since im +1 on the front sprocket
everyday i check the tracking number you gave me im kicking myself for not upgrading to the faster shipping
GlassAnkles is offline   Reply With Quote
Old February 2nd, 2012, 08:30 AM   #133
wandyhee
wandyhee's Avatar
to be honest, those Sea Mail tracking number are the poorest I've ever seen. but it's also the cheapest option to deliver the package oversea. They do offer EMS shipping but that will cost around $360 USD just to ship it out
Old February 2nd, 2012, 02:24 PM   #134
icbm
icbm's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Hayabusa GSX1300R, 2004 Kawasaki ZRX1200R, 1985 Kawasaki 750 Turbo
I would like a set too.
Don't forget we are going to need new bearings for them so keep that in mind. Bearings are not expensive though.
icbm is offline   Reply With Quote
Old February 2nd, 2012, 05:05 PM   #135
wandyhee
wandyhee's Avatar
Here's How To Order
Old February 2nd, 2012, 05:15 PM   #136
icbm
icbm's Avatar
Paypal sent
Old February 2nd, 2012, 05:24 PM   #137
wandyhee
wandyhee's Avatar
Paypal sent
Noted
Old February 2nd, 2012, 07:22 PM   #138
icbm
icbm's Avatar
If you compare a 130 70 17 to a 150 60 17 tire you will see that there is more sidewall or contact patch to be used when you want to exploit more lean angle.....thus in most cases you can go faster in corners.
Old February 2nd, 2012, 07:53 PM   #139
We've been into this so many times on this forum. Do we really have to get back into it again?
Yes, but only on a wider rim. And even then a) it will weigh more, which will make the bike a little less able to be flicked back and forth, and it will be more unsprung weight, which means the suspension will be less effective, and it will be more rotating weight, and b) how often have you been able to power-slide on a 250 on a 130/70-17 rear tire?
The catch with your example is the build and compound of those two different sizes of tires. The tires available in 150/60-17 sizes are all super-sticky, radial sport tires. The tires in 130/70-17 are not as sticky, and are usually bias-ply construction.
A tire in a 130/70-17 size that is the same construction and same rubber compound as the tire in the 150/60-17 size will keep the handling characteristics of bike (i.e. lightness between turns) and get more grip than the stock tires.
Old February 3rd, 2012, 10:13 AM   #140
icbm
icbm's Avatar
Your talking extremes. I will tell you what. I will compare total weights of the stock wheels/tires to the bigger wheels/tires. Then see how much of this weight could cause such a huge problem with suspension which by the way has been completely upgraded and adjustable. Now the gyroscopic effect will play a small part but these are not Carbon Fiber or Magnesium wheels where the outside weight of the wheel matters most. Look up MOI. The tires being larger should weigh slightly heavier or pretty close to any comparable or same brand tire in the factory size. Same goes for the wheels. So yes the combination will be heavier....big deal. Your talking about a bike that is already super light and will be lighter from other mods I do to it. A fair trade in my book.
Available lean angle is my goal. All I have to do is mod my dogbones to allow me to raise the rear enough to compensate. Not a problem.
Old February 6th, 2012, 11:49 PM   #141
wandyhee
wandyhee's Avatar
some pictures from my customer who just got his vrossi wheel set with Pirelli angle St 160/60/17 rear
LINK to original post
Old February 8th, 2012, 11:23 PM   #142
wandyhee
wandyhee's Avatar
Chemco wheel (rear only) also 4.5" wide Plug & play on ninja 250r with similar pattern spoke as oem
this brand come with;
- Lighter than OEM rear wheel
- better quality built compare to vrossi, and also cost more
- bearings & bushing
Last futzed with by wandyhee; February 9th, 2012 at 08:59 PM.
Old February 9th, 2012, 05:12 AM   #143
dubojr1
dubojr1's Avatar
That's the one I have. Love it!
Old April 3rd, 2012, 08:29 AM   #144
air_rick
air_rick's Avatar
Installed the rear rim! :)
Got my rims in over the weekend and installed the rear on with a new tire. (Had a nail in the rear tire so it was necessary that I install the rear first) Later on I am planning on changing out the front tire and rim as well. I had to cut just a bit off of the chain guard but it was worth it. Handles perfectly. Honestly don't notice any difference. I just ride on the highway back and forth to work. Here's some pics!
Old April 3rd, 2012, 08:31 AM   #145
Good grief what size is that rear tire air_rick?
Old April 3rd, 2012, 08:33 AM   #146
air_rick
air_rick's Avatar
lol it's a 160/60
Old April 3rd, 2012, 10:00 AM   #147
icbm
icbm's Avatar
So how long did it take for you to get the wheels? I am on 6 weeks and still waiting.
Old April 3rd, 2012, 10:02 AM   #148
wandyhee
wandyhee's Avatar
glad to hear you got the package.. I'm worried as hell since those tracking number system's useless.. hopefully others get their soon
Old April 3rd, 2012, 10:05 AM   #149
wandyhee
wandyhee's Avatar
Steve, from the date record I have here, you're mostly get your package by next week. as your package delivered a week after Eric
Old April 3rd, 2012, 10:13 AM   #150
icbm
icbm's Avatar
Yea I hope so. I have the opening race day on April 14th. Going to be close. I still have the forks being worked and waiting on them too. Thanks for the heads up.
Old April 3rd, 2012, 12:56 PM   #151
air_rick
air_rick's Avatar
Yea the tracking number was useless but it sure was a great surprise to see the box at my door. I hope you get yours soon bro. keep us posted and when you have time to spare post up pics when u get them mounted after the race.
Old April 3rd, 2012, 03:47 PM   #152
ws6lt4
Mine shipped out on the 7th of Feb and showed up at my door March 29th... on march 30th they were at the shop to get powder coated gold.
Hopefully I will get them back and installed within the next week, pictures will follow.
Old April 3rd, 2012, 06:52 PM   #153
wandyhee
wandyhee's Avatar
glad to hear that too
Old April 3rd, 2012, 06:55 PM   #154
2fiftyR
Motorcycle(s): 07 Ducati S4RS, 02 Ducati 998R, 02 Honda 954RR, 07 Yamaha R1, 92 Honda NC30 (VFR400), 08 Kawasaki Ninja 250R
VROSSI 3" front & 4.5" rims set - NEED CLARIFICATION
Is the VROSSI 3" front & 4.5" rims set $255 plus shipping, by boat or EMS?
2fiftyR is offline   Reply With Quote
Old April 3rd, 2012, 06:57 PM   #155
wandyhee
wandyhee's Avatar
boat, that took around 7-8 weeks delivery time
Old April 9th, 2012, 12:01 PM   #156
GlassAnkles
my vrossi's came in also.....did your rear rim have bumps that look like divets all over it by the spokes? looks like a bad cast on mine
Old April 9th, 2012, 06:54 PM   #157
wandyhee
wandyhee's Avatar
was it holes on spoke?
Old April 10th, 2012, 11:12 AM   #158
ws6lt4
Mine looked the same way, like a casting issue... when I get mine back from the powder coater, I'll take a few close up shots of the flaws. The casting flaws dont seem to be too deep, so I just said F-it and sent them to the coater.
I'm hoping it doesn't affect the strength of the rear wheel any. The front wheel looked fine and was defect free.
Old April 10th, 2012, 06:20 PM   #159
GlassAnkles
yeah my local shop guy and i looked at it and said f-it also. you cant beat the price, so i just had them mount up the tires.
if it continues to bother me i will order the chemco rear wheel.....or if i continue to enjoy the bike i will order the Galespeed Type-S rims
Old April 10th, 2012, 06:21 PM   #160
GlassAnkles
no holes, just bumps in the metal that look ugly. Great price so no concern
[motorcyclistonline] - Plug and Play, or Pray? | Answers Ninjette Newsbot Motorcycling News 0 May 27th, 2014 07:30 PM
FS: VROSSI 3" Front & 4.5" Rear, Plug & Play for Ninja250 (08-12) & Ninja300 n250r Motorcycle-related 1 January 19th, 2014 07:39 PM
L.E.D Dioded mod, Plug and play!! Syphontek 2008 - 2012 Ninja 250R Farkles 2 July 7th, 2012 07:11 PM
Koso rx-2 plug and play kit F/S dyeforever Motorcycle-related 2 May 14th, 2011 02:31 PM
[motorcycledaily.com] - Plug-and-Play Ninjette Newsbot Motorcycling News 0 August 7th, 2009 01:20 AM
