March 26th, 2012, 03:01 PM | #121 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
PM sent
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
April 12th, 2012, 08:48 AM | #122 |
Join Date: Apr 2012 Motorcycle(s): 2009 Ninja 250 (blue) Posts: 134
I did the quick and dirty hacksaw special as well.
Once I get more time, I will actually dremmel the fender and cut it to get rid of that license plate light hump and snug things up a bit. |
April 20th, 2012, 04:21 PM | #123 |
Join Date: Apr 2012 Motorcycle(s): 2008 Black Ninja 250r Posts: 21
Rear Fender Eliminator Kit
Looking for one for my black 08 Ninja ive seen some but not sure which one to get, the previous owner of the bike kind chopped the back end up and cut the fender off so i dont know if i will need additional parts to make a fender kit work. Any suggestions on nice eliminator kits?
April 20th, 2012, 04:27 PM | #124 |
Well idk exacally what he did but there is a led tail light with the turn signals in the tail light, but there is no bracket for the plate it was held on by zip ties...lol
April 20th, 2012, 04:49 PM | #125 |
The undertail Shot from the back Another angle And another angle\ Hope someone can give me an idea where to start lol please excuse the led kit wiring i havent had the chance to properly hide it and the bike it dirty lol |
April 21st, 2012, 01:30 PM | #126 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
If all you need to do is mount your license plate, buy two L-shaped brackets from your local parts store + bolts & nuts (home depot/lowes), then pop off the rear seat & drill some holes to mount the two brackets.
After cutting my fender, that's what I did. |
April 21st, 2012, 02:40 PM | #127 |
well i wanna mount my lisence plate but, it looks like **** i want something that looks more um.... like it wasent rigged up.
April 21st, 2012, 06:33 PM | #128 |
Join Date: Apr 2012 Motorcycle(s): 2008 Ninja 250 (sold) Posts: 110
http://www.google.com/products/catal...d=0CIQBEPMCMAM
http://www.google.com/products/catal...ed=0CH4Q8wIwAg http://www.biohazardcycles.com/servl...MINATOR/Detail http://www.google.com/products/catal...ed=0CHgQ8wIwAQ http://www.amazon.com/08-09-Kawasaki.../dp/B002IF6YNW http://www.google.com/products/catal...ed=0CHIQ8wIwAA |
April 22nd, 2012, 02:27 PM | #129 |
Thanks everyone for your help i bought the hotbodies one, we'll see how that works out
April 22nd, 2012, 03:22 PM | #130 |
certified newbie
Join Date: Apr 2010 Motorcycle(s): 08 ninja 250r blue Posts: 127
nice, you should write a review or DIY for it when you get it
locktite ALL the things!!! |
April 22nd, 2012, 07:21 PM | #131 |
April 26th, 2012, 07:50 AM | #132 |
Join Date: Apr 2012 Motorcycle(s): 2012 Ninja SE 250R "Knight Rider" Posts: 78
Battle of the Best Fender Eliminator Kit
Which is the best Fender Eliminator Kit?
I have narrowed it down to two choices because they supply lighting and a flush plate mount. Competition Werkes Yoshimura Anyone with insight is welcomed to respond. Looking for an easy install, of course no cutting would be the easiest. Please let me know if there is another good choice I may have missed! |
April 26th, 2012, 08:27 AM | #133 |
Join Date: Apr 2012 Motorcycle(s): 2012 Ninja 250 Posts: 10
Seriously, do not waste your money on one of these. All you need to do is follow the instructions on the DIY Fender eliminator kit here:http://www.2fiddy.com/2008/07/how-to...er-eliminator/ to cut the fender off and then get 2 bolts that are exactly the same as the two used to hold your tail light in place, except an inch longer. With the cut fender gone they will poke through the bottom between the turn signal lights. Take 2 small rectangle brackets (made by Stanley, at Lowes) that cost about a dollar, bend them to a 90 degree angle with a vice and pliers and bolt them to the bolts sticking through. Use lock washers! Then attach the original plate mount to those brackets and call it done. For about 5 bucks worth of parts and an hour or so of your time you can make it look just as good. You have to make cuts no matter what kit you get. Trust me, I did my research and came to the same conclusion. Take that money and buy something meaningful with it.
April 26th, 2012, 09:00 AM | #135 |
Recalculating. . .
Join Date: Nov 2011 Motorcycle(s): '09 250 (sold) '12 Ninja 650 Posts: 353
I have the Yoshimura eliminator and did not have to cut anything... You take the old one off and put the new one on... There is a little bit of re-assembly required if you re-use the stock turn signals, but it's not too bad... And it's a bit expensive, but it's really clean looking!
Here's what it looks like on my bike:
jasontracewell.com |
April 26th, 2012, 09:06 AM | #136 |
Yeah, I didn't put any plate lighting on it either. But I'm sure for another couple bucks you could get a light housing to wire into the harness for the original light. My plate is right up under my tail light and at night it illuminates it great. You might check with the laws in your state to see if its required. From what I understand nobody really gets messed with about that, ususally its going 120mph that gets them pulled over.
I also know there is a light that mounts to a screw hole in the license plate that can illuminate it as well. Not sure if its wired in or runs on batteries but if your really worried that may work. Also, and my dad used to say this to me and I thought he was an idiot but problems are really just opportunities in disguise. Get creative and figure it out on your own and you'll be much happier with it in the end. Once you get it set up you'll wonder why people pay that much for it. |
April 26th, 2012, 09:08 AM | #137 |
Icyknight - yeah, thats a clean looking setup. From what I understood all the kits required cutting. I stand corrected . But still, thats alot of money for something you could DIY for a couple bucks. If you like to tinker, I say go for it. Otherwise pony up and pay up!
April 26th, 2012, 09:18 AM | #138 | |
Recalculating. . .
This was one of the first major mods I did to the bike... I am glad I went with the kit though... I knew I didn't just want to cut the back part off and I wanted a clean 'finished' look. That said, I have seen a few DYI on Youtube and Google searches that looked pretty good too.
April 26th, 2012, 09:25 AM | #139 |
Understood. This was the first thing I did to my bike as well. I've got a dremel and all the little pieces/bits/attachments that made this possible. I like to do my own work so I knew what I was getting involved with. There are a few scuff marks and places where I could have polished it out a little more so I won't say its perfect, but you'd have to really look to notice. I had the right tools and the time which made it alot easier. If someone isn't so equipped then buying the kit may cost the same as their time and going out and buying the tools to do it. For me, buying the kit was not worth it.
April 26th, 2012, 09:55 AM | #140 |
I just ordered and received the competition werkes fender eliminator, but wish I saw the Yoshimura before hand because it is a much better buy.
Yoshimura retain the factory straps, is no-cut and looks cleaner in my opinion. I already spray painted the competition werkes black so I can't return it. |
April 26th, 2012, 01:13 PM | #141 |
That sucks. Thanks guys for all the insight. A $0 DIY mod is def. appealing, but a Yoshimura is manufactured to look sick and work well hence the cost factor.
Last thing I want to do is jack up the OEM fender and then still have to order a kit. At least if i sell the bike I can reuse my kit. |
April 26th, 2012, 04:04 PM | #142 |
Unless you just like wasting money, I'd go the DIY route, especially if you already have a dremel. If you're worried about plate lighting, pick up some led plate bolts on ebay for about $7. I went to Oreilly Auto parts and got some blue led light things and placed them on the metal pieces by the cargo hooks, so they shine down onto the plate (colored plate lights are not illegal here). And the bolts/L-brackets will cost you a couple dollars if you don't have them already.
If you did screw up horrifically (just take your time) then a replacement OEM fender is like $30 I have no electrical experience, never used a dremel, etc, but managed just fine. |
April 26th, 2012, 04:15 PM | #143 |
Join Date: Feb 2012 Motorcycle(s): 2011 Ninja 250R Posts: 12
I'd have to say go with the Yoshimura kit. I just installed one on my bike last weekend and it looks great. There is no cutting involved and the install is fairly easy.
EDIT: Here's the link to my picture thread on the kit, hopefully this will help you in your decision. Last futzed with by cstro250r; April 26th, 2012 at 05:53 PM. Reason: Added link |
April 26th, 2012, 04:19 PM | #144 | |
Recalculating. . .
That was another reason I liked this kit, cause if in the future I decide to go to an all-in-one brake light, I can take them off without getting another kit! Plus, you have the option of leaving on or taking off the hooks (which I obviously) left on...
April 26th, 2012, 05:56 PM | #145 |
Join Date: Jul 2011 Motorcycle(s): 2010 Ninja 250r Posts: 80
I went with the Projekt D Kit
http://www.newninja.com/forums/f98/j...ator-6279.html
2010 Ninja 250 Danmoto Carbon Slip On,Factory Pro Jet Kit,K&N R-0990 Air Filter,10000K HID's,Carbon Fiber Shogun No Cut Frame Sliders & Swingarm Spools,SSR Lowering Links and more.... |
April 26th, 2012, 06:10 PM | #146 |
My hacksaw job looks the same as that projekt d "maximus" and it was free.
April 26th, 2012, 06:20 PM | #147 |
If you read my post on new ninja I don't want to hack anything on my bike. I want to be able to return to factory if needed or what ever. And with this kit when I want to get a integrated taillight it's easy to switch over.
April 26th, 2012, 06:32 PM | #148 |
$30 oem replacement fender if you wanted to return to factory...hack away.
April 26th, 2012, 06:55 PM | #149 |
The Project D is not bad, but I prefer the flush mount of the plate with the bottom of the bike. It just looks much cleaner.
I guess this is why I'd rather just get the kit instead of the hacking away at the OEM fender. But kudos to those who have done this successfully. |
April 26th, 2012, 06:58 PM | #150 |
And hows that look with an integrated tail light?
April 26th, 2012, 07:06 PM | #151 |
Super Noob
Join Date: Oct 2011 Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc Posts: A lot.
I did mine the DIY way recommended by @RickySlickUHS above and here's how it looks with my integrated lights. If you take your sweet time cutting, the product will boost your self-esteem
April 27th, 2012, 06:29 AM | #153 |
ninjette.org *********
Join Date: Jul 2011 Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r Posts: 347
hotbodies racing undertail kit
okay okay, i know hbr has a bad rep. but ive had no problems with mine, i got the smoked undertail that hides the tail light, and it has built in turn signals and tag light, but what kind of rider leaves their stuff alone?? i put led integrated tail lights in mine
April 27th, 2012, 10:32 AM | #154 | |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
Thanks!
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
April 27th, 2012, 10:33 AM | #155 | |
April 27th, 2012, 10:40 AM | #156 |
Super Noob
It's pretty intuitive bro, the DIY is very thorough, but I'll take and upload more pics later (about to go into a 2 hour long lecture )
April 27th, 2012, 06:27 PM | #157 |
Super Noob
Sorry for the lateness of my post @edxmon, I got caught up in the "It's freaking friday!" madness lol. Ok, here are a couple of shots I took just now, I recently spray painted the screws black for better visuals, the flash on my phone made it appear wet and sticky, it actually looks phenomenal in person (brushing dust off my shoulder ).
Hope this helps you bruh. |
April 27th, 2012, 06:48 PM | #158 | |
Join Date: Mar 2010 Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919 Posts: 605
April 27th, 2012, 07:33 PM | #159 |
Join Date: Apr 2012 Motorcycle(s): Ninja 250r Posts: 228
was thinking same thing
anyone try one of these ? Targa fender eliminator kit This was the one i was going to get in a few weeks, it was the only one i found that required no cutting what so ever. They have two different ones, one that use stock wires and another that comes with smaller lites for like $10 more, but that one causes you to have to splice your lite wires so then it rules out the no modification to stock parts.
Anyone have a link on the yoshi? I'm decently handy but i would not want to do any cutting, cant afford to fix something if i break it or have to order another part. Anyone try or heard anything from the Targa?
www.SafetyPaws.org |
April 27th, 2012, 07:37 PM | #160 | |
fender eliminator | 102dalz | Items Wanted | 4 | March 11th, 2014 04:18 PM |
fender eliminator.... | dark_beaverezt | 2008 - 2012 Ninja 250R Farkles | 9 | December 8th, 2013 05:49 PM |
SS Fender Eliminator | ninjamunky85 | 2013 - 2017 Ninja 300 Farkles | 1 | June 13th, 2013 06:56 PM |
The best fender eliminator!! | SSANGHA | 2008 - 2012 Ninja 250R Farkles | 11 | October 19th, 2012 07:09 PM |
Help! Rear fender replacement (not fender eliminator) | mcnuggett | General Motorcycling Discussion | 7 | April 30th, 2012 08:24 PM |
