July 5th, 2010, 11:54 AM | #1 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250r 09 SE Posts: 172
oil level always goes up ....
i am wondering why my oil level always goes up ... after 800 km of riding, i can have +- 500ml over...
July 5th, 2010, 12:06 PM | #2 |
July 5th, 2010, 03:53 PM | #3 |
Make sure you're comparing apples to apples and always checking the level under the same conditions, on a perfectly level surface, and the same length of time after shutting down. Short of coolant mixing with the oil, which would be obvious because the oil would look like a milkshake, the only thing I can think of that would cause an increase in the level would be a lot of fuel getting into the oil. If the engine is idling for long periods of time, or only taken on really short trips where the oil never reaches operating temperature, fuel dilution of the oil can occur. It would have to be pretty extreme for you to notice it as a change in the oil level, though.
Kevin 2009 Ninja 250R |
July 5th, 2010, 03:56 PM | #4 |
July 5th, 2010, 04:02 PM | #5 | |
To really diagnose it for sure, you can take a sample of the oil and send it in for an analysis. I use Blackstone Labs for my cars. http://www.blackstone-labs.com/ Their analysis well tell you if there is too much fuel in the oil.
July 5th, 2010, 04:26 PM | #6 |
Wait... I've never heard of the oil level rising due to gas mixing with the crankcase oil enough so that it raises the oil level by the amount he's referencing due to short trips. If anything, a stuck float valve I can believe, but not due to overly short trips.
I think it's a matter of not reading under the same conditions as pointed out. how are you determining it's varying by +/- 500ml? |
July 5th, 2010, 06:02 PM | #7 |
Yeah, it would be really extreme for it to be visible as a 500ml difference. Usually we're talking about trace amounts of fuel. I could see it adding up over the course of months if the oil never gets up to operating temp, but even one 20 minute ride should get the oil hot enough for long enough for the fuel to volatilize.
I also suspect it boils down to random error in reading the level.
Fork oil level | Sipper' | 1986 - 2007 Ninja 250R Tech Talk | 1 | June 25th, 2014 04:08 PM |
oil level | RogerPapaMike | 1986 - 2007 Ninja 250R Tech Talk | 1 | May 4th, 2014 02:54 PM |
Oil Level | tnr4 | 2013 - 2017 Ninja 300 Tech Talk | 26 | June 14th, 2013 10:33 AM |
Oil Level when running | kamikaze | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 16th, 2010 08:16 AM |
