Go Back   ninjette.org > General > Pictures
Old February 14th, 2009, 03:33 PM   #1
Scorpielle
Scorpielle's Avatar
Motorcycle(s): 2009 Black Ninja 250R
My latest Mod - Rim tape!
As I wait for the spring to come, there is time to do some personalization!
So here is my little Baby Ninjette, next to my Husband's KTM, which makes it look even smaller than it already is LOL!
My only consolation is that it dwarfs his sportbike too.
Both the KTM and my Ninjette got new stripes.
So here's the regular view:
And here is the super Glowing Look in the flash:
What else do you do on Feb14th besides work in the garage on you bike! LOL
Scorpielle is offline   Reply With Quote
Old February 14th, 2009, 03:37 PM   #2
Did you each do your own? Great contest to see who has the steadier hand. Bikes do look great with them on.
That's your garage??
Old February 14th, 2009, 03:41 PM   #3
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Nice job Elle! I especially like the color you chose
Old February 14th, 2009, 03:51 PM   #4
Scorpielle
Scorpielle's Avatar
Thanks! Yup that's our garage,, the "workshop" ,since no regular cars have ever been in it. We did have an old Austin Mini a few years ago, it took up the back 1/2 lol
But now it's just for the bikes and the work bench.
I picked the Blue cause it would work with my leathers too, (black/white/blue) it really pops though, i like it.
(and no I left the application to the expert, my husband, since he's put it on a few bikes in the past as well, I didn't want to have it wobbling all over the place if I tried it LOL )
Here's everyone back in order again, put away for the night:
Last futzed with by Scorpielle; February 14th, 2009 at 05:46 PM.
Old February 14th, 2009, 07:18 PM   #5
jpnfrk
Her name is Itoshii
jpnfrk's Avatar
Motorcycle(s): 2007 Kawasaki Ninja 250
I brought some of those too and as any good DIY gurl I'm installing them myself (though I must confess I don't have the steadiest hands either, LOL)!!
Did you by any chance notice how long it took your husband to put the rim tape on your ninja?
"A frog in a well can not see the ocean" ~ Japanese proverb
jpnfrk is offline   Reply With Quote
Old February 14th, 2009, 08:47 PM   #6
Scorpielle
Scorpielle's Avatar
Well it was a team effort, I cut them apart as they came on 1 large sheet and he put them on,, so I'd say for the 4 sides... hmmm an hour the most,, just depends how steady your hand is and how quickly you stick it on, but just a warning, clean your rims with rubbing alcohol and once you stick it on you can't peel and re-position. Have fun and post pics!
Old February 14th, 2009, 09:19 PM   #7
jpnfrk
Her name is Itoshii
jpnfrk's Avatar
Thanks for the help! I'll get the rubbing alcohol next time I go to the store. My wheels are stock aluminum color right now, I think the rim tape (reflective magenta) will look better on a black rim though.
For now I'm debating whether to DIY the paint job or take it to a pro...
Old February 14th, 2009, 09:23 PM   #8
how long do you anticipate keeping the bike? If a long time, take it to a pro and have them powdercoated.
Elle- Are you sure it was rubbing alcohol and not isopropyl alcohol?
Old February 14th, 2009, 09:36 PM   #9
jpnfrk
Her name is Itoshii
jpnfrk's Avatar
kkim, I anticipate keeping Itoshii for as long as I humanly can... no intentions to "upgrade" to a bigger bike.
Any idea how much for powdercoating the rims?
Old February 14th, 2009, 09:55 PM   #10
It depends on your area, but forum member Beast had his done for about $600 in California, if I remember correctly. You can PM him and ask to get an accurate amount.
Old February 14th, 2009, 10:02 PM   #11
jpnfrk
Her name is Itoshii
jpnfrk's Avatar
$600!!?!?!?!
I guess I'll shop around diff paint shops for estimates and cross my fingers it won't be that expensive.
I did see some paint made for car engines (heat resistant and all that jazz), shouldn't that hold up?
Old February 14th, 2009, 10:16 PM   #12
It should, but powercoating is usually more durable than paint. Check around your area for both and see what they quote you.
Your silver rims are looking better and better, aren't they?
Old February 15th, 2009, 12:17 AM   #13
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
I asked about this also. Got quoted $100 a wheel and they would strip off the old paint and power coat them.
But you need to replace the bearings and add in the labor to take off the tires and remount them.
Old February 15th, 2009, 09:10 PM   #14
Scorpielle
Scorpielle's Avatar
Hmmm... rubbing alcohol is isopropyl alcohol
http://en.wikipedia.org/wiki/Isopropyl_alcohol
Old February 15th, 2009, 09:47 PM   #15
I understood rubbing alcohol was 70% isopropyl and 30% water with oils mixed in for use when rubbing. I have found a few that says they contain oil online, but most just list 70/30 alcohol/water. It seems I was mistaken that all rubbing alcohols contain oil.
My point being, if you used a rubbing alcohol that contained oil you could be putting something with a lubricant in it to clean the rim making the rim tape not stick as well. I usually use 99% pure isopropyl alcohol when I want to clean things of oil and grease before application.
Old February 15th, 2009, 10:40 PM   #16
noche_caliente
everclear would work just fine too 200 proof ethanol, and God knows, you wouldn't want to actually drink the stuff!
Old February 15th, 2009, 10:50 PM   #17
we used to have Everclear at work to clean the tape recorder heads back in the days when we were using tape to store data. nothing else would do as it was speced for the heads we were using at the time. stuff tastes terrible, but packs a wallop!!
Old February 15th, 2009, 10:57 PM   #18
CRXTrek
CRXTrek's Avatar
Everclear is 95% alcohol...190 Proof
I've drank far to much in my youth
Old February 16th, 2009, 07:51 AM   #19
BlueTyke
So slow I'm first!
BlueTyke's Avatar
Motorcycle(s): 06 Kawasaki Ninja EX250
What is the width of the tape you used? I found some at a local bike shop for $11.99 and wouldn't mind putting some on Tyke... Just not sure what size would be best.
Learn from the mistakes of others, you cannot make them all yourself. Save yourself the trouble and Learn.
BlueTyke is offline   Reply With Quote
Old February 16th, 2009, 08:29 AM   #20
jpnfrk
Her name is Itoshii
jpnfrk's Avatar
Is it the reflective sort?
Old February 16th, 2009, 09:01 AM   #21
BlueTyke
So slow I'm first!
BlueTyke's Avatar
Looked like it.. According to their website.. Yes
http://www.petescycle.com/eshopprod_...WHEEL_TAPE.htm
In store it was cheaper...
Old February 16th, 2009, 10:28 AM   #22
jpnfrk
Her name is Itoshii
jpnfrk's Avatar
Nice!! I feel ripped off, I paid around $22
Oh well!! The one I got is 5' long and 3/8" wide and should look like this when installed:
http://www.tapeworks.com/Rimstripes/6146.jpg
Old February 16th, 2009, 12:35 PM   #23
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
did you say EVERCLEAR?!?
sorry...had me a not-so-clear ever clear flash back...
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old February 16th, 2009, 10:50 PM   #24
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
What happened if you don't mind me asking?
miks is offline   Reply With Quote
Old February 17th, 2009, 05:28 AM   #25
komohana
komohana's Avatar
the year was 1982, the place, zaragosa air base, spain.
we were t.d.y. there from germany, getting our F-4 jocks some sorties on the bomb range and we had us a little weekend mojo session. you know mojo yes?...take a cooler, the bigger the better...and make this potent alcoholic and fruit drink mixture...add a little ice w/the sliced fruit and everclear firewater...top it all off with these long-ass straws made out of oil sample tubes and commence ta getting stupid...!
i knew we was in trouble when someone tripped and broke the fall with his face...the rest is kinda fuzzy...
Old February 17th, 2009, 01:50 PM   #26
GreezMunky
GreezMunky's Avatar
Motorcycle(s): 09 250r (*sold*), 2010 Daytona 675
Oh jeez, and that's how all good TDY stories start..
GreezMunky is offline   Reply With Quote
Old February 18th, 2009, 02:24 AM   #27
miks
I'm lovin' it.
miks's Avatar
Didn't the fella have hands?
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
Old February 28th, 2009, 06:01 PM   #28
meegari
Motorcycle(s): 2 fiddy
Hi Scorpielle, I also live in canada, where did you buy your rim stripes?
meegari is offline   Reply With Quote
Old March 1st, 2009, 05:25 PM   #29
Scorpielle
Scorpielle's Avatar
Actually , got them on Ebay, I'll try and find the username I bought them from for you.
Old March 2nd, 2009, 12:59 PM   #30
meegari
thanks Scorpielle, that would be great, just awaiting delivery of an 09 candy thunder blue, i'm thinking it will match the color pretty close.
Old March 3rd, 2009, 05:16 PM   #31
Scorpielle
Scorpielle's Avatar
ebay seller for rim tape
Here is the Ebay sellerhttp://myworld.ebay.com/ebaymotors/elite_vinyl_designs/:
Old March 4th, 2009, 12:15 AM   #32
muffinman
muffinman's Avatar
Motorcycle(s): '08 250R (sold), '05 ZX6R / 636
Looks great... definitely stands out. On black bikes, I'm only used to seeing Time Attack (red) stripes
muffinman is offline   Reply With Quote
Old March 12th, 2009, 05:41 PM   #33
Strider
Back on the Black!
Strider's Avatar
Motorcycle(s): 2006 Kawasaki Ninja EX250 (Black)
LOL, I got Red
Strider is offline   Reply With Quote
Old March 12th, 2009, 07:40 PM   #34
Sound Wave
Ramen Rider
Sound Wave's Avatar
hey, what's wrong with a black bike and red stripes?
but that is the good thing about a black bike. black goes well with almost anything.
Pregen rim tape on silver rim? fr1dayn1ght 1986 - 2007 Ninja 250R Farkles 4 August 26th, 2013 04:45 PM
"Rim wrap" + thin rim tape as an alternative to powder-coating? CZroe 2008 - 2012 Ninja 250R Tech Talk 6 July 21st, 2012 02:14 PM
Rim tape. blink General Motorcycling Discussion 14 March 31st, 2012 11:19 PM
Rim Tape!! mohns6062 1986 - 2007 Ninja 250R Farkles 9 April 4th, 2011 07:43 PM
looking for the SE rim tape zartan Off-Topic 11 January 30th, 2009 03:09 PM
