August 23rd, 2009, 08:34 PM | #1 |
Join Date: Feb 2009 Motorcycle(s): 08 Black Ninja 205r - SOLD, Now -> a Z750 Posts: 101
Improperly disengage clutch ~ revs high, lower speed.
I kept wondering why I rev high and yet the speed doesn't justify with it. 100km/h for 8.5k on 6th. 140km/h for 13.5 on 6th.
So I ask my buddy on his green ninja what's his rev on 100km/h? he told that its around 7-7.5k. Then i checked with 250r maintenance book (courtesy from kkim ) ... i found that my clutch lever isn't properly fixed. the clutch did not disengage properly, leading to higher revs but didn't deliver the speed. I fix as per instructed and now the bike cruising 7.5k on 100km/h..... after 14 months had her!. so you guys better check what ever mentioned in the Ninja book. |
August 24th, 2009, 01:41 AM | #2 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
i just got back from a 30~40 Km ride and noted that i have the same issue (problem?) when im in 6th gear and going 100 Kmh, the rpm reads between 8500 to 9000. i thought this was normal? im not a heavy guy, about 62 Kg, which is around 130 pounds i think.
it was a little windy, but it wasn't like a 100mph head wind or anything, lol any tips as to what page in the service manual i need to look into, or if there is a simple way to see if the clutch is fully engaged when i release it? i do have this feeling that the RPM doesn't rise very linearly to the speed. |
August 24th, 2009, 01:54 AM | #3 |
Join Date: Aug 2009 Motorcycle(s): 07 GSXR600 (N250 sold :( ) Posts: 415
August 24th, 2009, 02:26 AM | #4 |
huh, i have the manual, but on page 2-23 there is this:
different manuals? |
August 24th, 2009, 03:30 AM | #5 |
umm im not sure, i dont have the book itself, just look in the link.
August 24th, 2009, 04:26 AM | #6 |
The manual at that link is for the FI bike, not the carbureted one.
Here's the one for the US bikes: http://www.scribd.com/doc/15021361/K...ervice-Manual2 |
August 24th, 2009, 07:17 AM | #7 |
self wrencher
lever not adjusted properly? you mean the lever should have about 2-5mm of free play?
August 24th, 2009, 09:32 AM | #8 | ||
i did mine and it runs smoothly for 5 days now. anybody done this yet.? |
August 24th, 2009, 05:44 PM | #9 |
August 24th, 2009, 07:24 PM | #10 |
just twist the screw towards the lever not the other way. make sure the locking screw and the cable screw meet close together.
August 26th, 2009, 08:25 PM | #11 |
So you didn't have to remove the fairing ?
August 26th, 2009, 08:42 PM | #12 |
i played around with the clutch cable on the steering wheel end, and there has not been any change. there is about 3~5 mm of free play, which should be right.
im wondering if my Speedo is calibrated differently...? i checked it out again yesterday, cruising at 100 Km/h in 6th gear, with no strong wind, the bike is doing 8500 Rpm... im still 1000 Rpm over the norm it seems. i haven't done any mods. all stock, almost 2000 Km done with lots of oil + filter changes during the break in. any way to know if the clutch is engaging properly when fully released besided the speed/rpm thing? taking off the engine/clutch plate cover is also a little out of the question, since it might be nothing. |
August 26th, 2009, 10:48 PM | #13 | |
that's for the lower link, i did on the handle part.
i way to know is 1) the shift from 1 to 2 is smooth and not as loud as before 2) you can feel that the momentum when the clutch is released. 3) you could also see the speed - rev is relative. btw, it is also possible that the speedo - tachometer need to be calibrated or replaced. there's a case here and it's the instrument defect. generally, you don't have to rev or stress the engine just to cruise 100km/h. right? this time try to use human intuition |
Clutch Won't Disengage | Gmon | 1986 - 2007 Ninja 250R Tech Talk | 21 | September 23rd, 2019 09:31 PM |
Clutch issues. Won't disengage, searched, tried, help | mr2peak | 1986 - 2007 Ninja 250R Tech Talk | 21 | May 5th, 2014 04:32 PM |
High revs | tehcarguy | 2008 - 2012 Ninja 250R Tech Talk | 11 | July 16th, 2012 04:57 AM |
Clutch doesn't fully disengage power when pulled in. | reaubideux | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 3rd, 2011 10:11 AM |
Another Clutch Issue...Cannot Disengage! | Littlefreak | 1986 - 2007 Ninja 250R Tech Talk | 8 | March 13th, 2011 09:15 PM |
