Old December 1st, 2014, 07:49 AM   #1
Proteus
Daily Ninjette Rider
Proteus's Avatar
Motorcycle(s): 2012 Ninja 250R, 2015 Vespa GTS 300 IE Super, 1989 Honda Elite 80 (SOLD)
Replace Fuel Gauge with Fuel Light?
I'm planning on replacing my stock gauges with a Trailtech Vapor. The Vapor takes care of tach, speedometer, and coolant temp. I'm going to get the 022-PDA dashboard holder that gives you 4 indicator lights as well to use for neutral, hi-beam, turn signal, fuel etc.
I'd like to use the fuel light - I know that everyone says to use the trip odometer and I do that as well but I also like having a visual indicator in case I forget to reset the odometer.
Can the signal from the fuel gauge be used to trigger a low fuel light? I'd imagine that it's just sending variable voltage to the gauge, so maybe with a resistor it could trip the light at the correct voltage?
Check out my music at http://www.proteusmusic.com
Proteus is offline   Reply With Quote
Old December 1st, 2014, 07:09 PM   #2
Proteus
Proteus's Avatar
Still can't find anything on this with the Google.
Old December 1st, 2014, 08:05 PM   #3
Originally Posted by Proteus View Post
........... Can the signal from the fuel gauge be used to trigger a low fuel light? I'd imagine that it's just sending variable voltage to the gauge, so maybe with a resistor it could trip the light at the correct voltage?
Using the original sending unit, you will need some electronic brain to recognize specific Amps (yes, voltage remains the same while current changes with fuel level) and to command the light.
The simplest way is replacing the sending unit with a switch, but then, you introduce a spark inside the gas tank: no good.
Take a look at this:
http://auto.howstuffworks.com/fuel-gauge.htm
Old December 1st, 2014, 08:45 PM   #4
Hero Danny
Inline 4!!!
Hero Danny's Avatar
I know this doesn't answer your question... but.. Just use your odometer.. I go by mine since my fuel gauge is off by a little bit.
Be careful. Remember you are
invisible
Old December 1st, 2014, 08:52 PM   #5
MrAtom
MOTM - July '15
I just shake the bike side to side and hear how much gas is sloshing around in there.
Old December 1st, 2014, 09:04 PM   #6
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I usually just refill every 150 miles.
TEAM ALFALFA
www.apexassassins.com
Old December 2nd, 2014, 07:42 AM   #7
Proteus
Proteus's Avatar
I'd still like to have some sort of visual indicator, because I'm forgetful and the TT Vapor dash has spots for four lights and it would just bug the hell out of me to not use all four. @Motofool thanks for the link - there should be a way to trip a light at a certain current. Going to talk to one of my electrician buddies to see if we can figure it out.
Old December 2nd, 2014, 08:19 AM   #8
Somchai
Freedom for Germany
Motorcycle(s): Ninja 250R-FI
@Proteus, if it's ok for you to translate from german to english then maybe this could give you some idea or maybe even help to find your solution
http://www.tl1000.de/FAQ/umbauten/tankanzeige.html
Good luck
Old December 2nd, 2014, 08:33 AM   #9
Proteus
Proteus's Avatar
Nice, thanks! Google translate does some funny stuff with it though:
Note:
"Be sure to position the element eighth Zueineinader. Have fun, when holes are."
My video on how to fix the fuel sender for your fuel gauge Klint 2008 - 2012 Ninja 250R Tech Talk 1 November 2nd, 2013 09:04 PM
fuel gauge light doesn't work. jon.b.calderon 2008 - 2012 Ninja 250R Tech Talk 1 January 20th, 2013 11:03 PM
Fuel tank/Fuel gauge issues coolcatjames 2008 - 2012 Ninja 250R Tech Talk 10 August 23rd, 2012 06:25 PM
Fuel gauge not working jdoucet93 2008 - 2012 Ninja 250R Tech Talk 6 September 15th, 2011 10:07 PM
fuel gauge shellneil General Motorcycling Discussion 8 November 1st, 2009 02:26 PM
