Old April 4th, 2021, 04:16 PM   #121
JayVapes
JayVapes's Avatar
Motorcycle(s): Ninja EX250
righteous
Old April 7th, 2021, 05:27 PM   #122
This 250 refurb completed today, can't do any better than these, note EX500 rail filter plugged in. Tighter, it has more of a tendency to stay put. Found the 250 filter on these displaced and wedged up inside the fuel line an inch or so.
Last futzed with by ducatiman; April 9th, 2021 at 07:55 AM.
Old April 8th, 2021, 02:01 AM   #123
JayVapes
JayVapes's Avatar
I recommend your work always!
Old April 8th, 2021, 09:02 PM   #124
JayVapes
JayVapes's Avatar
xp that was my filter down inside that line. I have no idea how the motorcycle even ran!
Old April 9th, 2021, 05:13 AM   #125
Haha, I had no idea that was you responding in the thread here, JT!
If it ran (at all) before, it should run awesome now. We shall see.
Old April 9th, 2021, 05:16 AM   #126
note kink in the vent line i referred to, textbook otherwise.
Old April 13th, 2021, 12:16 PM   #127
EX500 carbset refurbed today, these for sale, my property
Old April 16th, 2021, 10:28 AM   #128
^ SOLD ^
with yet another 500 set in the works, again my property, will be for sale
Last futzed with by ducatiman; April 18th, 2021 at 05:57 AM.
Old April 22nd, 2021, 05:34 PM   #129
today, knocked off a set of ZR750 Kaw carbs, Keihins reminiscent of 2# linked EX250 sets.
Old April 23rd, 2021, 12:04 PM   #130
back to EX500's today
Old April 25th, 2021, 12:16 PM   #131
Echo blower and Craftsman weed whacker both got running today, both needing carb work....belonging to my (lucky) next door neighbor. Ditto on his pressure washer just a couple weeks ago.
Old April 26th, 2021, 05:54 PM   #132
back to a 250 carbset today
Old May 6th, 2021, 03:10 PM   #133
received at 10am, refurbed and shipped back out by 4:30 today. Not too shabby if i don't say so myself. Now bolt on runners, problems included missing pilot screw orings and a frozen in place decel valve diaphragm.
Last futzed with by ducatiman; May 6th, 2021 at 04:49 PM.
Old May 6th, 2021, 07:51 PM   #134
JayVapes
JayVapes's Avatar
so modest
Old May 8th, 2021, 11:38 AM   #135
finished another set of 500's today which underwent quite a transition. Both pilot jets and emulsion tubes were clogged, badly varnished.
Old May 9th, 2021, 06:51 AM   #136
been advised of Mikuni/Ducati carbs incoming
Old May 15th, 2021, 06:22 PM   #137
especially nasty Ducati/Mikuni's still in process. A couple before/after shots. To update when done tomorrow.
Old May 16th, 2021, 03:56 PM   #138
all done, 1 more before/after shot
Old May 19th, 2021, 07:24 PM   #139
a nasty set of EX500 carbs here for normal refurb. Final pics tomorrow. Lets see if we can wake these up a bit.
Old May 20th, 2021, 11:24 AM   #140
yup, now awoken to bolt on runners.
Old June 7th, 2021, 07:35 AM   #141
Today 3 items incoming from landscaper to me.
The first, a non-starting Craftsman pressure washer already done. Required a carb pull/clean (NO parts). New fangled carb featuring plastic body/internals......now starts 1st pull , goes into reliable steady idle.
Last futzed with by ducatiman; June 7th, 2021 at 02:05 PM.
Old June 11th, 2021, 06:15 PM   #142
Vulcan 500 carbset refurbed today, using a new general cleaner. Worked out well, restored brass tuning components like new, carb bodies greatly improved over what was received.
Old June 19th, 2021, 01:49 PM   #143
These 2 fitties came out no less than spectacular today. Using a newfound cleaner...as clean inside as outside. Wet tested, fuel levels tweaked, ALL circuits confirmed clear...these'll bolt on and GO (the general idea)
Old June 20th, 2021, 05:09 PM   #144
Knocked these 500's off today, will be fine runners. Note restored to like-new factory supplied brass tuning components.
Last futzed with by ducatiman; June 20th, 2021 at 06:17 PM.
Old June 25th, 2021, 09:36 AM   #145
Today a set of 4 banger Keihin FCR39 for Honda CB900RR on the bench. A ton of parts, better pics to follow. So far, findings include 3 of 4 pilot jets totally clogged. Further advised bike has sat for 7 years.
Last futzed with by ducatiman; June 25th, 2021 at 07:29 PM.
Old July 6th, 2021, 12:45 PM   #146
the FCR's await seals. In the meantime........
Old July 7th, 2021, 09:02 AM   #147
Oh oh, torn diaphragm on 250 set i'm currently doing.
Old July 7th, 2021, 04:08 PM   #148
new diaphragms installed, carbs done, they worked out quite nice. EX500 mesh rail filter installed.
Last futzed with by ducatiman; July 7th, 2021 at 05:10 PM.
Old July 8th, 2021, 12:29 PM   #149
and a set of fi' hunnerts done today.
Old July 10th, 2021, 03:55 PM   #150
seals (not supplied in kits) finally arrived today allowing me to complete these FCR39's from a Honda CBR900.
Old July 12th, 2021, 11:21 AM   #151
today, in quite the transition, i'm on a single carb from an older '82 Honda CM250. Worked out well.
Old July 13th, 2021, 05:32 AM   #152
This thread is not good for my diet......
Too many carbs.....
Old July 13th, 2021, 12:57 PM   #153
Working on poorly set up 250 carbs today. Inactive, dead slides...replacement diaphragm rubbers incorrectly installed, and dead floats.... amongst other problems.
Completed pics will follow.
Last futzed with by ducatiman; July 14th, 2021 at 07:08 AM.
Old July 24th, 2021, 03:52 PM   #154
500's done today turned out textbook perfect.
Old July 27th, 2021, 01:01 PM   #155
Near done today , a Keihin set from a Honda CBR250RR MC22 (Australian model) aka "Babyblade" here for a "functional clean".
Refurbed original jetting installed, the kit the owner supplied used different sizes....opted to stick with OEM 105/102 mains (note inner and outer main jets are sized differently)
Not perfect, but greatly improved in a visual sense, I do anticipate will be fine runners.
Old July 27th, 2021, 05:53 PM   #156
finished this evening
Old July 28th, 2021, 07:41 AM   #157
Old August 8th, 2021, 01:52 PM   #158
Rained near all day here.....perfect time to tackle some equipment maintenance prior to knocking this 250 set off, which came out near perfect.
Old August 10th, 2021, 08:22 AM   #159
rained yet again.....so I knocked off these EX500's. What the heck, can't ride anyways.
Old August 17th, 2021, 01:23 PM   #160
Nope, not the same, but another set of 500's came out nice today. Bolt-on runners, yup. Shiny brass, yup. All original tuning components restored/reused.
[roadracingworld.com] - â??Racers Edge Performance Hosting Track Day/ Practice Day Ap Ninjette Newsbot Motorcycling News 0 March 25th, 2015 02:20 PM
