Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old July 19th, 2017, 06:31 AM   #1
Tang415
Motorcycle(s): 2016 Ninja 300 abs
Rear set for ninja 300 abs
Hello guys I'm looking rear sets for my ninja 300 abs any advice or some information please ? Thank you
Tang415 is offline   Reply With Quote
Old July 19th, 2017, 01:07 PM   #2
Timpo
Motorcycle(s): 2013 Ninja 300
https://www.revzilla.com/motorcycle/...ninja-250r-300
Timpo is offline   Reply With Quote
Old July 19th, 2017, 06:29 PM   #3
snot
sammich maker
snot's Avatar
MOTM - Apr '15
I have Vortex. They are not cheap but I like them.
Old July 19th, 2017, 10:25 PM   #4
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
I just use the Yoshi Adapter, it works great. However, Woodcraft & Vortex will do.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old July 19th, 2017, 11:28 PM   #5
Timpo
For the price of Yoshimura adapter, you can get a Chinese rearset for the same price.
http://www.ebay.com/itm/Foot-pegs-Re...v3diyA&vxp=mtr
Old July 20th, 2017, 04:11 PM   #6
MLR
MLR's Avatar
The Ebay rear sets that I purchased (very typical to the link supplied) didn't fit, I contacted the supplier about the fitment and, after my sending pics with them attached to show how they didn't fit (I used a small steel ruler to show the measurements that were out for the master cylinder and the brake lever) they sent me a electrical harness to connect the rear brake, which, although it is pointless, was nice
They did supply a big bag of fittings and bushes, sadly, after trying every configuration we couldn't get the master cylinder and the linkage from the brake level to line up and push straight, the master cylinder mounting point needed to be about 20mm rearward and out about 7mm more out to line up for a straight push on the piston.
As for the shift side, well that was another case of fail.
So now I have some rear sets that don't fit (they do bolt to the frame but thats about it) and a harness which I cannot use.
Don't do what I did, spend a bit more, the fitment and adjustability of the better quality items is well worth the extra cash.
In the end I ended up with some very expensive nuts and bolts to put in my nuts and bolts tin.
MLR is offline   Reply With Quote
Old July 21st, 2017, 01:03 AM   #7
Tang415
The Chinese rearset is not good quality and always get trouble
Old July 21st, 2017, 07:16 AM   #8
Sulman
Sulman's Avatar
Motorcycle(s): Ninja 300
I use the Yoshimura brackets on mine.
One thing to be aware of: You will have to create clearance for the brake line that connects to the ABS tubing; this is a matter of lifting the rubber hose out of its holder so the line has sufficient play to allow fitting of the rear set.
Sulman is offline   Reply With Quote
Old July 21st, 2017, 03:09 PM   #9
Tang415
Seems like complicated for ninja 300 to modification
Old July 21st, 2017, 05:07 PM   #10
algs26
Motorcycle(s): ex300, gave up looking for a 250
I had to wire in a pressure sensitive brake switch for my Vortex install.
Also the master cylinder has to be flipped which changes the distance to the brake caliper. For ABS bikes, you may need a longer brake line to the ABS.
algs26 is offline   Reply With Quote
