Notices
Old November 13th, 2019, 02:54 PM   #1
Most excellent key copying experience!!!
U$D 0.58 key blank/embryo from AliExpress
U$D 1.09 key copying in S.F. Chinatown
$ 1.67 TOTAL - WORKS PERFECTLY!!
Couldn’t be better! I had original masters made from key-code under helmet lock 3-yrs ago when I got bike-in-boxes puzzle. I lost 2nd backup couple months ago and really like new-gen style key a lot with its big cover. None of usual key vendors had pre-gen key in new style, so I got one from Ali.
First thing I noticed is it’s longer! Tip to shoulder is about 1.5mm longer than factory key. So I made sure to instruct guy cutting key to cut from shoulder to tip and cut off extra at end in process. This is cause of most people’s issues with these keys from Ali. If you cut from tip up, it won’t match and copy won’t work!
With that out of way, he went off in back and I could hear key-grinding taking place as I wandered around looking at knick-knacks. Afte 5-minutes, he came back with my new key and it worked perfectly!!!
Old November 13th, 2019, 07:59 PM   #2
SibSerge
it's funny I got the same blank from ali but in blue 3 for 8 US delivered
The blank from Kawa dealer was 15CAD
Paid 5.80 CAD - about 4.5 US for 2 copies. Worked well
Not as cheap as yours though.
Old November 13th, 2019, 09:18 PM   #3
I got mine over year ago before tariffs kicked in, might have been U$0.99 in shipping or something.
I hesitated in getting copy made because of such bad experience previously. Originally I went to hardware store in Nob Hill and they found blank that matched. Cut me key and I went home and tried it, nope, only worked partially. I could turn it ON, but it wouldn't turn to LOCK. Trick was shoulder had to be pushing on lock and this one had shoulder that was much higher, about 3-5mm. Damn locksmith should've laid keys on top of each other and noticed it right away, idiot! I think it was an Ilco blank or some such.
Went back to have them try again and he refused, even after I showed him what problem was. And they refused to give me full refund and just gave me back just $3 for key-blank out of $17 I had spent there...grrr... So I was pissed and took over year to research this topic and get familiar with keys. Figured I'd get my own blank to make sure it's compatible. Ali one was close enough and I know all negative reviews were due to operator-error in cutting.
Got my blank in post and just hung onto it while researching locksmiths and trying to figure out who could possibly cut this correctly and not mess up. Tried big-box stores like Home Depot and they've dummied key-cutting to automated machines any yute can operate. However, your vehicle must be in machine's database in order for them to select it on screen, then it tells them which blank to use and stick in original and copy is spat out. Nope, no Ninja 250 in database, so no luck there.
Luckily I was walking back to office after retrieving dim-sum for lunch and walked past this place! Good to know there's still competent locksmiths who know how to properly operate manual key-cutting machine! Also probably helped being able to speak Chinese!
Feng Cai Trading Co., Chinatown, SF
Last futzed with by DannoXYZ; November 16th, 2019 at 01:05 AM.
Old November 14th, 2019, 06:29 AM   #4
Neat. Does it work in the fork lock?
I got a cheap blank and the local hardware store guy wouldn't take any money after he made the key for me. It works fine in the ignition switch and seat lock, but it was too short to work in the fork lock. If I remember right I cut some off the handle part of the key for clearance and it works in the fork now.
Old November 14th, 2019, 06:54 AM   #5
SibSerge
We had our big box stores transitioned to the dumb machines too. Both home depot and canadian tire refused to make a copy for me saying the machine does not have the key in the system. Me pointing to the key vise standing beside it did not help. They said that they stopped doing it. I had to make at least 5 calls to different locksmiths to find one that makes copies for motorcycles. The guy turned out to be a rider as well rebuilding his Vulcan. We had a nice chat.
Speaking the language of the buisiness does help oftentimes. I had a developer girl in my team. She was from Harbin and she was getting good tea for us in China town for half the price
Old November 14th, 2019, 09:27 PM   #6
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Interesting side story: I had an issue with Perigee where the key wouldn't turn for the gas cap and it looked like some corrosion or similar might've been binding it up. After trying the simpler solutions (like a lubricant) I had a spare key made and then, using it, did a fairly gentle rubber mallet hit and it got everything reseated properly without risking my original key.
"most folks racing this bike get it in a competitive state of being with much less invested than you've already put in Saturn." - Alex
Old November 15th, 2019, 09:39 AM   #7
I don’t have fork lock on mine. Lock position on ignition switch works perfectly!
Yup distance from tip to shoulder is critical for getting it to work. To move from OFF to LOCK position, shoulder has to depress lock inwards. Most problems stem from tip-to-shoulder being too long, thus you can never depress lock inwards before tip bottoms out (my Nob Hill copy).
Luckily in your case, problem was reversed and increasing distance from tip to shoulder allowed it to depress lock properly.
Last futzed with by DannoXYZ; November 16th, 2019 at 01:08 AM.
[motorcycle.com] - Michelles Excellent Australia Adventure Ninjette Newsbot Motorcycling News 0 January 16th, 2018 02:21 PM
[motogp.com] - Excellent showing from both Espargaro brothers Ninjette Newsbot Motorcycling News 0 February 26th, 2014 08:00 AM
Excellent Afternoon to Ride in Seattle dcj13 General Motorcycling Discussion 3 February 2nd, 2014 09:05 PM
[visordown.com] - Caption That: Excellent rear view Ninjette Newsbot Motorcycling News 0 November 19th, 2013 04:10 PM
Photo Editors - Free and Excellent g21-30 Off-Topic 8 February 11th, 2009 10:18 PM
