Old November 24th, 2019, 04:25 PM   #1
Tylerscott86
Tylerscott86's Avatar
Motorcycle(s): 1999 Ninja 250
Fuel leak
So took my bike out for it's first official ride after getting her going today. Got a little low on fuel and stopped to fill her up. Now it's leaking from some where. Wasn't leaking when I put the initial gallon in there after all my work. So now I'm sitting at the gas station waiting for it to reach a level where it's not leaking so I can get back home. It's not coming from the petcock. Looks to be from a seam in the tank. Can't really tell though. Any thoughts?
Tylerscott86 is offline   Reply With Quote
Old November 24th, 2019, 05:19 PM   #2
Did you have hole in tank from fairing bolt at front? That's high up, so tank needs to be at least 3/4" full for it to leak.
Leaking petrol can be dangerous...
Old November 24th, 2019, 05:58 PM   #3
Tylerscott86
I don't think I did but I just let it sit until it stopped leaking completely. About half a tank now. I wiped up any fuel I saw left on the bike. Them drive home. I'll have to tear into it and see what's up I guess.
Old November 24th, 2019, 07:24 PM   #4
Did you unbolt the fairing side panels from the tank?
Old November 25th, 2019, 05:24 AM   #5
Tylerscott86
That's the plan once I get a free day. Working 2 jobs leaves little time. But when I bought it, it was in pieces so the fairings have been put on recently. Guess either I did it putting it together or the PO did it and I found it.
Old November 25th, 2019, 08:18 AM   #6
Read through this section - https://faq.ninja250.org/wiki/How_do...l_tank,_etc%3F
Old November 25th, 2019, 06:28 PM   #7
Fixit
Fixit's Avatar
Motorcycle(s): Harley XL1200C, Kawasaki ex250
Mine was like that too.
PO has installed wrong screws and made the hole top right.
Get yourself a 6mm set screw and some gaska-cinch or other fuel resistant glue. There are many out there. Hopefully you have a 6mm tap as well. We ran the tap through so the the tank itself had the proper threads, make that thread, most likely one. Put sealant on the set screw and run it in. ensure that it is just proud of the tank itself.
Just to be sure put more sealant around the outside of the set screw and between the plate and the tank while keeping it off the threads of the plate itself.
If worried put the tap in and out of the plate.
After the appropriate time for your glue put some gas in the tank if it was empty, no need to fill it, just lean the tank over to the leaking side and see if it leaks.
Bikes from small to large.....2005 Ninja 250 --- 1974 Harley XLCH 1000 --- 2006 Harley XL1200C
Not as old as the picture to the left makes me look, just feel that way sometimes.
Fixit is offline   Reply With Quote
Old November 27th, 2019, 09:29 PM   #8
Tylerscott86
Something along these lines is the plan. Thanks for the directions. Just gotta find the time now.
Old November 28th, 2019, 07:46 AM   #9
As additional safety measure, you can fill gap between tank and plate with strong 2-part epoxy. This will seal plate so anything getting past threads won’t go anywhere.
Old December 9th, 2019, 02:37 PM   #10
dukeswift
dukeswift's Avatar
Motorcycle(s): 02 Aprilia RS70 97 Ninja 250
When I purchased my 250 I had no clue about the fairing bolt-gas tank problem. Filled up with gas on the maiden ride home and found out the hard way as half my body was soaked in fuel by the time I got home. Plus it was only about 38F outside.
I JB-Welded my tank holes and they are holding up just fine!
dukeswift is offline   Reply With Quote
Fuel Leak - New One on Me - and Question for Ducatiman Triple Jim 1986 - 2007 Ninja 250R Tech Talk 5 February 25th, 2018 02:28 PM
Carbs leak while fuel is on Jaytibba 1986 - 2007 Ninja 250R Tech Talk 29 July 21st, 2016 02:22 PM
mysterious fuel leak 10inja 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2013 05:04 AM
Help, fuel leak. Stangrider 2008 - 2012 Ninja 250R Tech Talk 3 June 24th, 2013 09:34 PM
Weather=fuel leak? 48newrider 1986 - 2007 Ninja 250R Tech Talk 5 March 13th, 2013 07:09 PM
