June 26th, 2014, 03:51 AM | #1 |
Biker Noob
Join Date: Apr 2014 Motorcycle(s): 2004 Honda Shadow 750 Aero Posts: 176
Shift Linkage coming unscrewed
Ok, so I installed my new shift linkage last night. This morning i go about 5 mils and come to find out I can't shift up or down. So I pull over to see what is going on. I find out that my shift linkage screws are unscrewed. I am having to pull over to fixd the issue. See pics blow. how do I i keep these from coming unscrewed? Please see pic. some of the pics are of how the shift linkage and shifter pedal should be and some are what is happing.
Riding as I stole it. Last futzed with by reroka; June 26th, 2014 at 03:53 AM. Reason: adding p |
June 26th, 2014, 04:14 AM | #2 |
Board Member
If needed use loctite. Otherwise you need to tighten them well to prevent loosening.
June 26th, 2014, 06:29 AM | #3 |
June 26th, 2014, 07:44 AM | #4 |
Biker Noob
How long does it take to dry?
Riding as I stole it. |
June 26th, 2014, 07:50 AM | #5 |
Board Member
give it 1 hour to be sure. It doesn't take that long if you clean the area with solvent first.
blue is right. one drop of blue Loctite. |
Suggestions for a better option to stock shift linkage. | nealt | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 2nd, 2012 12:09 PM |
WTB: New gen shift linkage + shift knuckle + Woodcraft rear sets | 675Raisinator | Items Wanted | 1 | July 30th, 2012 05:59 PM |
Shift arm linkage placement | Redsvt | 2008 - 2012 Ninja 250R Tech Talk | 1 | March 11th, 2012 08:43 AM |
shift linkage bolt | b_eastep | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 20th, 2010 01:53 PM |
[crash.net - MotoGP] - Pedrosa unscrewed. | Ninjette Newsbot | Motorcycling News | 0 | December 29th, 2009 04:12 AM |
