Old May 8th, 2013, 05:34 AM   #1
Bones85
Gasket, Exhaust Pipe C (11009-1667) fell apart? Replacement options?
When I took my muffler off yesterday, the gasket just fell out and I noticed it was in pretty bad condition. I can't even mount the muffler anymore with the gasket because of the deterioration.
This is the part: http://www.cmsnl.com/products/gasket...e-c_110091667/
Do I need to buy an OEM one or are there cheaper replacements? Also, where exactly does the gasket go? I never saw it before it fell out yesterday.
Thanks.
Bones85 is offline   Reply With Quote
Old May 8th, 2013, 06:35 AM   #2
cuong-nutz
cuong-nutz's Avatar
I think you're probably stuck with OEM gasket unless you can find gasket of similar size that'll fit at the auto parts store.
HalfFast Racing Team
Old May 8th, 2013, 09:05 AM   #3
Bones85
Would there be any damage done if I rode without the gasket?
Old May 8th, 2013, 09:10 AM   #4
cuong-nutz
cuong-nutz's Avatar
Other than the sound of a leaking exhuast, I think you should be okay while you wait for a new gasket to come in. I'm not sure how much the of the exhaust is being shield with the gasket. You could get some exhaust wrap or exhaust patch tape from the auto store for the time being.
Old May 8th, 2013, 10:02 AM   #5
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
I had this happen on my r6 the other day, I used some rtv high temp liquid silicon gasket for the time being ($5 at wally world, clicky clicky) and it seems to have worked. I had a bad exhaust leak and now I don't feel it leaking at all. I'm hoping for it to be a permanent fix but my hopes aren't too high and It takes 24 hours to cure too.
I started my bike up after it cured and it sounded a lot more throaty than before so I knew right away that it worked. I turned def after reving my bike with my head right next to it checking for leaks lol.
Live2ride is offline   Reply With Quote
Old May 8th, 2013, 10:31 AM   #6
bfpower
ninjette.org mafioso
bfpower's Avatar
I've used high temp rtv before on my car with good results. Not so great if you want a 100% watertight seal IMO, but for exhaust it would do the trick.
If it were me I'd buy the OEM part and ride with the leak until it came in.
bfpower is offline   Reply With Quote
Mid pipe options Locklear318 2008 - 2012 Ninja 250R Tech Talk 7 May 14th, 2014 09:50 AM
WTB: Gasket, Exhaust Pipe C (11009-1667) Bones85 Items Wanted 0 May 7th, 2013 07:28 PM
Head Gasket Replacement tjkamper 2008 - 2012 Ninja 250R Tech Talk 10 August 13th, 2012 01:58 PM
Cylinder base gasket replacement kevlar250 1986 - 2007 Ninja 250R Tech Talk 1 October 22nd, 2011 07:19 AM
Pre-gen ninja 250(88-07) OEM Clutch Cover Gasket 11009-1872 speedgsx98 Motorcycle-related 2 April 4th, 2011 08:17 PM
