Old September 14th, 2015, 02:10 PM   #1
rubber side down
rubber side down's Avatar
Motorcycle(s): 01 gixxer 1k, 02 gixxer 600, 02 ninja 250, a slew of dirt bikes
bike wont start with clutch pulled in
This weekend I have gravity take me to the asphalt while doing a track day. Now for some reason it wont crank with the clutch pulled in. Put the bike in neutral and clutch out and it cranks and fires up just like normal.
Any one else ever have any issues after putting it one down on a track day?
Also anyone have an extra coolant pipe that is on the left side? It must have cracked when it went down. I looked and they are on back order at bike bandit, and I have another track day weekend coming up in 2 weeks.
Thanks.
https://www.youtube.com/watch?v=hw9yP5U1V8I
There is the link to vid of me putting it down.
rubber side down is offline   Reply With Quote
Old September 14th, 2015, 03:39 PM   #2
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The obvious first step is to make sure the clutch switch isn't unplugged or broken.
Old September 14th, 2015, 04:15 PM   #3
rubber side down
I checked the obvious. Not broken or unplugged. But I do believe I have it fixed, I took a pvc pipe and bent the clutch handle back out away from the bar. Seems to work now. Not sure why pulling it in neutral wouldn't allow the engine to crank, considering you don't need to pull it in neutral. Oh well 1 gremlin down.
Still not sure about the antifreeze/coolant pipe. I took it off and it only has 2 iddy bitty tacks on it. Almost like it was fused somehow at the factory. It is leaking right at the 90* factory bend/fuse.
- - -Bike Wont Start - - - Triple R 2008 - 2012 Ninja 250R Tech Talk 1 July 31st, 2014 06:54 AM
Friend's bike wont start... ideas? setasai General Motorcycling Discussion 7 August 3rd, 2011 07:41 PM
bike wont start after new flasher relay onizthegnome 2008 - 2012 Ninja 250R Tech Talk 7 December 12th, 2010 12:32 PM
Bike wont start, please help? zev42 2008 - 2012 Ninja 250R Tech Talk 11 November 9th, 2010 01:02 PM
uhh, bike wont start. ajaygraci 2008 - 2012 Ninja 250R Tech Talk 37 June 24th, 2009 06:39 PM
