Old June 30th, 2011, 05:27 PM   #1
mohns6062
Motorcycle(s): Kawasaki ZZR 250
Bike dies after start up
So this morning I started my bike up to go to work. Rode it down the block and when I came to the stop it died instantly. It wouldn't start back up so I had to cage to work. Later this afternoon my dad started it up and it started up and idled just fine. He took it for a good ride and had no problems with it. When he brought it back to the house and pulled up the drive it still everything worked fine. He put the side stand down and it dies in neutral. Now it won't start.
Any help?
mohns6062 is offline   Reply With Quote
Old June 30th, 2011, 05:35 PM   #2
Any history on the bike? how long's the gas been in it, how new is the bike to you, any jetting changes, any work done to it recently? etc etc
Old June 30th, 2011, 05:36 PM   #3
Snake
Snake's Avatar
Sounds like your kickstand safety switch either has a short in the wires that lead to it or the safety switch mounting screws are loose.
Old June 30th, 2011, 05:39 PM   #4
oooh the part about the sidestand didn't click in my head when I read it. Try that. check faq.ninja250.org and read thru the electrical stuff partaining to the sidestand. That should help a bit with background info on that. I'm still wondering why it died when you were riding it to work. did you put the sidestand down on your ride when it died like with your dad?
Old June 30th, 2011, 05:40 PM   #5
I think it could also be the clutch switch or the neutral sensor rather than the sidestand switch. If the sidestand is down, it still shouldn't turn off if either it is in neutral or if the clutch is pulled in.
Old June 30th, 2011, 06:01 PM   #6
mohns6062
It is sitting in the drive way on the center stand now. 2006, recently did a valve adj, cleaned carbs, new tank of gas as of yesterday, has ran great since engine work, we adjusted the idle mixture screws as it is running with no result, it idles then slowly keeps reving lower until it dies. When it is running and we rev it up there is a funny sound coming from the airbox/ battery area. It makes a sort of click sound at about 4000 rpm or so.
Thanks for the responses.
Old June 30th, 2011, 06:09 PM   #7
mohns6062
thinking it has to be the ignition module or kickstand switch or whatever. It won't even start with the kickstand down and to get it started (it is warmed up) you have to have the throttle on wide open.
Old June 30th, 2011, 06:17 PM   #8
But it definitely just gets slower and slower and then dies? vs just cutting out instantly like when you flip the kill switch? that likely rules out switches. Double check all the hoses on the carbs; I've forgotten to connect the vacuum lines and what happened is just like what you described.
did this just happen randomly? you said it's been running fine since the engine work. Did you do all the work at the same time and it worked fine and suddenly this is happening? or have you done the carb work/ valve check at different times?
Old June 30th, 2011, 07:01 PM   #9
this is probably over simplifying the problem but does your choke work properly? if you put the choke on does it act like the choke is on? when you take it off does it act like you took the choke off? maybe the choke cable was disconnected and never reconnected after the service
Old June 30th, 2011, 09:19 PM   #10
Timon
Timon's Avatar
Motorcycle(s): Ninja EX250R
I agree with the fact of it NOT being a switch on the clutch or on the side stand simply because it died while in neutral with the stand down. The bike will only kill itself if you put the stand down and try to drive off in gear with it still down, then it will instantly die as soon as you release the clutch.
Timon is offline   Reply With Quote
Old June 30th, 2011, 09:19 PM   #11
mohns6062
I have used the choke after the service
Old July 1st, 2011, 12:18 PM   #12
mohns6062
It was on its side stand in a heavy rain... could that hurt the electronics in anyway?
Old July 1st, 2011, 01:11 PM   #13
no. Mine's been sitting in the rain multiple times. no worries about that
Old July 1st, 2011, 03:31 PM   #14
what about in neutral?
Old July 1st, 2011, 06:47 PM   #15
what are your idle jets set at? that would explain the hard starts and possibly the low idle
Old July 1st, 2011, 11:32 PM   #16
mohns6062
Yes all the work was done at the same time and it was working before then the problems started randomly
Old July 1st, 2011, 11:36 PM   #17
mohns6062
Turning the idle screws didn't change the idle while it was running
Old July 2nd, 2011, 10:25 AM   #18
mohns6062
So this morning it started up unassisted (no choke, no throttle). It seems to idle decently but if I rev it it will hover at about 3 thousand and eventually comes down to"normal" idle speed. So new issue is the hovering idle speed after it gets rev'd up
Old July 2nd, 2011, 11:20 AM   #19
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
It's idling rich, I don't know enough about these bikes to tell you why though, unless someone messed with the screws or unplugged a hose they shouldn't have
Edit: Oh I see now that you did mess with the screws. You went too far, lean it out a bit. When you get it right it should rev quickly with no bogging and when it comes down it should come right back to idle. If it hangs above it's too rich, and if it dips below and comes back up it's too lean
Felipe the Ant is offline   Reply With Quote
Old July 2nd, 2011, 12:44 PM   #20
you have it backwards.
hangs= lean
dips=rich
http://faq.ninja250.org/wiki/How_to_...r_idle_mixture.
Old July 2nd, 2011, 12:58 PM   #21
Felipe the Ant
derp
Yeah that's what I meant
Old July 3rd, 2011, 09:53 PM   #22
...that's why I asked what your pilot jets were set at, even though I called them idle jets because I wasn't thinking.
If they're in too far it makes the bike hard to start and it hangs terribly when you blip throttle (lean). it will also make the bike die from starving it of fuel. Try backing them out 1/4 turn at a time until you get good response off idle and it drops back down to idle quickly without dropping below idle (rich). then test ride it and see how it feels.
take it for a ride and get it warmed up before you adjust the idle mix screws
Old July 5th, 2011, 11:35 AM   #23
mohns6062
So while i was out of town my dad cleaned any suspect electrical connections. He pur di-electric grease on them. He jumpered te side stand swith and he dried out the air box ( not really anything in there). Headjusted the carbs again and he took it for a good half hour "shake down". He says it seems to be real good.
(It was also cooking this past weekend without a cover on in 25+ degrees celcius weather)
Old July 5th, 2011, 06:16 PM   #24
what did he end up doing to the carbs when he adjusted them?
Old July 10th, 2011, 02:38 PM   #25
mohns6062
He said he just adjusted the pilot screws
Old July 10th, 2011, 07:37 PM   #26
Glad you got it fixed. now go ride it and love it!
Old July 10th, 2011, 07:48 PM   #27
mohns6062
Just heading to her now, bought new boots so I'm going to try them out
How to properly start a ninja? Dies on me Black knight 2008 - 2012 Ninja 250R Tech Talk 14 April 7th, 2013 08:18 AM
bike dies John D 1986 - 2007 Ninja 250R Tech Talk 4 September 3rd, 2012 06:50 AM
Bike has no throttle and dies? Chubbs032 2008 - 2012 Ninja 250R Tech Talk 4 March 31st, 2010 12:46 AM
cold start-bike dies??? fiberoptx 1986 - 2007 Ninja 250R Tech Talk 17 October 31st, 2009 11:51 AM
HELP! Bike will start but once put in gear dies TreyE 1986 - 2007 Ninja 250R Tech Talk 6 September 3rd, 2009 12:45 PM
