Old June 26th, 2009, 12:23 AM   #41
headshrink
headshrink's Avatar
Mine should be here Monday
Where is a good place to tap into a switched source? I have been studying the service manual, but the electrical schematics are a little over my head.
Old June 26th, 2009, 12:37 AM   #42
I used one of the wires around the sensor that you'll be replacing. There is a big connector next to the gas tank area. Use a multimeter and identify any one of those wires that is switched. Use the supplied tap to connect to the wire.
Old June 26th, 2009, 01:43 AM   #43
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
I ran from the license plate light.
pantera is offline   Reply With Quote
Old June 26th, 2009, 12:22 PM   #44
Mo1981
Mo1981's Avatar
Motorcycle(s): 2008 Ebony Ninja 250R
I ran mine off the same wire as Kelly.
Posted via Mobile Device
Mo1981 is offline   Reply With Quote
Old June 27th, 2009, 08:02 PM   #45
headshrink
headshrink's Avatar
According to the service manual, the temp sensor is supposed to have silicone sealent on the threads. Did you all get special stuff at the dealer, or is there something cheaper/easier to find at HD/Lowes?
Old June 27th, 2009, 08:09 PM   #46
just screw the supplied one in. it already has thread sealant (teflon) tape on it, correct?
Old June 27th, 2009, 08:13 PM   #47
headshrink
headshrink's Avatar
I'll look.... it isn't due to arive until Monday. I have some teflon tape if not, as long as you're saying it works for this application.
Old June 27th, 2009, 08:14 PM   #48
I didn't use any sealant. I'm pretty sure the new sensor comes with tape already on it.
Old June 28th, 2009, 09:42 PM   #49
randomwalk101
self wrencher
randomwalk101's Avatar
does this thing has back light that lights up for visibility at night?
Old June 28th, 2009, 09:54 PM   #50
headshrink
headshrink's Avatar
Yes, kkim says in his original post that it has a blue one. Which should blend in.
EDIT: I don't know why I said that, or where exactly I thought I saw that.... but mine is green. Blue would have blended better, but an aftermarket velcroed gauge is really more about function than form.
Last futzed with by headshrink; July 1st, 2009 at 12:35 AM.
Old June 28th, 2009, 09:56 PM   #51
headshrink
headshrink's Avatar
Are there any other options for dressing the wires?
Old June 29th, 2009, 08:04 PM   #52
headshrink
headshrink's Avatar
I'm working on a DIY (with pics) tonight for this mod, so I have to ask a couple more questions..... please bear with me. I want the DIY to answer all the little questions in a straight forward and simple way, so I gotta get it first
- Where did some of you ground out to?
- Anyone else want to chime in on the switched wire?
- The wires on the unit are pretty long.... did anyone trim them down, or is it best to bunch and zip-tie (they have nice connectors at the end?
- As far as dressing the wires, is this necessary, or just nice? Is it only for the exposed portion, or also under the fairing? I purchased some wire loom (similar to Kelly's) and the package says it is rated to 200 degrees... does it get any hotter under the fairing?
- I am looking for alternative mounting positions.... take a look at the picture below, does this look like it would be secure enough with the included Velcro?
Old June 29th, 2009, 08:09 PM   #53
Bob -
Consider writing it up in the wiki rather than as a new post here in the tech section. I think many, if not most, of the DIY's will eventually find their way over there, and as we create new ones now, may as well put 'em there in the first place. If you do decide to wiki it up, ping me if you run in to any issues throughout and I'll work through 'em with you.
- Alex
Old June 29th, 2009, 08:11 PM   #54
headshrink
headshrink's Avatar
Originally Posted by Alex View Post
Bob -
- Alex
Good idea Alex, I'll do that.
Old June 29th, 2009, 10:20 PM   #55
headshrink
headshrink's Avatar
Ahhhh.... multimeter broke and I don't have enough wire to get to the tail! I need more hints on that switched wire.... pllllease.
Am I looking for brown/white?
Old June 29th, 2009, 10:28 PM   #56
I used a multimeter to find a switched wire at that connector. can't tell you what color the wire was. I also ran the ground wire down to that area and bolted it under one of the bolts in that area, too.
you need to make sure the location you select is not going to interfere with turning at all. turn the handlebars from lock to lock and see if the meter hits anything. I wouldn't trust the Velcro to support the meter in that location. If anything, get some industrial strength Velcro or some 3M dual lock to make sure the meter stays put.
Old June 30th, 2009, 12:50 AM   #57
headshrink
headshrink's Avatar
It is finally done. Thanks for the help kelly.
The wire was red w/blue stripe - I studied the manual over, and over, and over until I was brave enough to tap into the central nervous system of my little ninjette.
I'm working on a DIY on the wiki.... it should be done shortly.
Old July 1st, 2009, 12:39 AM   #58
headshrink
headshrink's Avatar
DIY Wiki is DONE... check it out!
http://www.ninjette.org/wiki/DIY_Day...ter_Temp_Gauge
Old July 1st, 2009, 12:44 AM   #59
good job!
Old July 1st, 2009, 01:57 AM   #60
randomwalk101
self wrencher
nicely done.
Old July 1st, 2009, 10:32 AM   #61
Added a link to the wiki entry from the DIY sticky at the top of the tech section.
Old July 1st, 2009, 07:36 PM   #62
randomwalk101
self wrencher
need to get one of this baby. Is Shindy is same as Daytona? I noticed that Shindy only has 2 wires as compared to Daytona with 3 wires?
Old July 1st, 2009, 07:55 PM   #63
headshrink
headshrink's Avatar
As far as I have heard on this board, Shindy does make it. I didn't know there was a 2 wire one.
I wish I would have gotten mine sooner, but summer is a good time to get one in. I get up to 220F sitting at lights in mid 80s!!!
Old July 1st, 2009, 08:55 PM   #64
almost40
ninjette.org Monkey Spank
almost40's Avatar
Has anyone seen a regular dial gauge for our little ninjas? Im just not that into the digital ones.
Black 250R
Full Area P QC
Old July 1st, 2009, 09:23 PM   #65
randomwalk101
self wrencher
I suppose if you caught the overheating light when it came on, you might be okay, but most times it is not caught early and by the time you notice, the engine is toast. If I read over 200 when I ride, I start to monitor the temp more closely.
So basically the bike's cooling system is not sufficient in cooling the bike sitting idle on a hot day (radiator/fan and all?)
Old July 1st, 2009, 09:44 PM   #66
it will work for a little while, but an important component of the cooling system is air being flowed through the radiator. A fan can only do so much and eventually the system can be overloaded... any system can.
Old July 16th, 2009, 12:24 PM   #67
ankh26
Motorcycle(s): KLR 650, vulcan 900, ninja 250
Where is the cts sensor located
ankh26 is offline   Reply With Quote
Old July 16th, 2009, 12:45 PM   #68
almost40
almost40's Avatar
I beat you Kkim....
I WIN. lol
Black 250R
Full Area P QC
Old July 16th, 2009, 12:45 PM   #69
Old July 16th, 2009, 02:13 PM   #70
Performance chip posts moved to this thread.
Old July 19th, 2009, 08:02 AM   #71
randomwalk101
self wrencher
finally got a chance to install this yesterday...haven't had a chance to ride it yet though..today after work....work on weekends sucks i tell you man...arghhh
anyways...the gauge back light is green..wish it was blue though...
i mounted it on top of the Scott steering damper...works for now
Old July 22nd, 2009, 08:36 AM   #72
randomwalk101
self wrencher
Anyone tried to tee in the stock wire into the new daytona's wire so the stock light works too? Is this doable?
Old July 22nd, 2009, 01:52 PM   #73
HKr1
IC2(SW)
HKr1's Avatar
The oil temp gauge says its blue.
Old July 22nd, 2009, 06:53 PM   #74
headshrink
headshrink's Avatar
Ahhh.... so they are liars
Old July 23rd, 2009, 05:56 PM   #75
Momaru
Momaru's Avatar
Any fellow 'blue enthusiast' toyed around with the idea of replacing the interior LED or whatever they use for a lighting method? Or is it not that simple?
Proud member of the Blue Army
Old July 23rd, 2009, 08:33 PM   #76
headshrink
headshrink's Avatar
The unit is sealed (it is waterproof) so I wouldn't want to break it. I believe the instructions said the battery is not serviceable by the end user anyways,which would be the same for LED, and you would have to send it into the factory to be replaced. Unless the clock is important to you, the battery isn't even needed. The unit defaults to temp when the key is on anyways.
Now that I am thinking about it.... it would be a better unit if they used digital LED displays instead of LCD.... this would take care of the display blackout issue on 100+ degree days.
Old July 26th, 2009, 05:59 PM   #77
randomwalk101
self wrencher
Okay...here is mine
So finally took a pic of my Daytona.
I spliced the original wire into the Daytona signal wire so the stock light will light up if temp reach 230F or something like that...More way to alert of a problem is a good thing.
Here is a pic
Old July 26th, 2009, 10:48 PM   #78
headshrink
headshrink's Avatar
Could you please clarify what you mean by this?
You have a steering damper I haven't seen one on a 250 before.
Old July 27th, 2009, 05:26 AM   #79
randomwalk101
self wrencher
7/0 `
just strip the Daytona's wire and solder in the stock wire (the one that you have hanging), then tape it up..that's it
Steering damper? That come stock on the bike no?
Old July 27th, 2009, 11:26 AM   #80
headshrink
headshrink's Avatar
So this triggers the "idiot light" on the dash at ~230 degrees? If this is true, that has got to be the simplest hack yet.... I'm surprised no one has mentioned it yet.
Daytona Water Temp Gauge Problem?? kenji_808 2008 - 2012 Ninja 250R Tech Talk 2 December 28th, 2011 04:23 AM
Water Temp Gauge etiainen 2008 - 2012 Ninja 250R Farkles 5 November 4th, 2011 04:30 PM
Daytona Water Temp Gauge Keyoa 2008 - 2012 Ninja 250R Farkles 2 April 3rd, 2011 06:13 PM
Daytona Temp Gauge wellcraft General Motorcycling Discussion 0 January 26th, 2010 07:24 PM
Daytona Temp gauge whylee 2008 - 2012 Ninja 250R Tech Talk 9 January 20th, 2010 08:50 PM
