Old April 3rd, 2013, 06:45 PM   #1
skilletmo
InfoWhore
skilletmo's Avatar
Motorcycle(s): 2008 Ninja 250 StreetFighter ~~~~ 2005 KTM 450 EXC
Vapor Trail Tech Question/Help
Ok so i have done alot of research on mechanical speedos and before i pull the trigger that @Motofool helped me with ( I love him so very such btw) i wanted to research some trail tech vapors i found on ebay new 95$. The mechanical speedo with the tach is 85$. So as you can see i will be willing to spend the few bucks to get a better one with more features. But before i get into that i wanted to see which one i would need and how it stands against the mechanical speedo i chose. I tried contacting @smokinsingle, but i dont think he got the message
So the question is: Did you get the Vapor Kit: 75-600 (sv-650) or the Vapor Kit: 75-300 (KX/KXF/KLX 125/250/450/500 04-13)
This ninja wiki says i should buy the 75-300 but im reading many threads saying that you should get the sv650 (75-600) one? Please explain! Thanks
Everyone, go buy a dirtbike hurry
skilletmo is offline   Reply With Quote
Old April 3rd, 2013, 09:53 PM   #2
skilletmo
InfoWhore
skilletmo's Avatar
HERRP
Old April 4th, 2013, 07:15 AM   #3
Undeserved kind words, Skilletmo, thanks !
These things use a magnet and sensor attached to the front wheel for measuring speed and traveled miles.
This article explains how to calibrate them:
http://faq.ninja250.org/wiki/Install...er#Calibrating
I don't know, but I would choose the one suitable for the SV650.
The reason is that the front tire of that bike is 120/60-17", while the tire of the YZ125 and KLX250S are 80/100-21".
The adjustable range of the second one may be off your 17" wheel setting, but I don't know for sure.
Old April 4th, 2013, 07:44 AM   #4
mike_k
mike_k's Avatar
Motorcycle(s): '08 Ninja 25 (track), '02 Honda 919, '04 Honda NSR-50 (track)
I use a Vapor on my track '08 250, so I never hooked the speed sensor up. I probably would have if there was a simple and easy way to mount it, but I didn't see any...
It looks like the only significant difference between the 75-600 and 75-300 is the magnet kit. Not sure which one would work better... Hopefully someone else here knows.
For getting the tachometer to work, you'll need the cable with the series resistor in it. See this thread:
http://www.ninjette.org/forums/showthread.php?t=75999
I think you can just unscrew the brass coolant temp sensor from the little hose coupler from either the 75-600 or 75-300, and replace the existing temp sensor in the thermostat housing on the new-gen 250. That's what I did with mine, and it works well.
mike_k is offline   Reply With Quote
Old April 4th, 2013, 08:02 AM   #5
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
I've got a Vapor on my "06, and I have the non-curved wheel sensor, which you can bolt to the brake caliper bracket, where it will pick up nicely from a magnet mounted to the brake disk. I don't think the curved, fork-slider mount will get the sensor close enough on this bike to the disk for a good speed pickup.
You do need the resistor tach wire for the Ninja 250.
I, too, replaced the stock temp sensor with Trail Tech's unit - same thread size - and it seems to provide an accurate temp reading.
Best things about this unit are ease of mounting, simplicity, functions, and incredible lightness, compared to almost everything else.
Good luck with your project. Here's mine:
Chicagobob is offline   Reply With Quote
Old April 4th, 2013, 08:32 AM   #6
psych0hans
psych0hans's Avatar
That's a sweet looking gauge... Quiet reasonably priced too, compared to koso...
Old April 4th, 2013, 09:18 AM   #7
skilletmo
InfoWhore
skilletmo's Avatar
Which one was that the 75-300 or 75-600?
Old April 4th, 2013, 09:23 AM   #8
skilletmo
InfoWhore
skilletmo's Avatar
And also, mostly I was wanting to know what version I need becuase I know the tach needs the certain resistors. Or do they all come with the resistors and I just need the one that matches the front wheel size? Which will probably be the 75-600 as motofool the great said.
Old April 4th, 2013, 09:31 AM   #9
Chicagobob
Chicagobob's Avatar
Wheel size doesn't matter, as you'll be setting up the speedo to match yours, whatever it is, by measuring the wheel rollout and entering that measurement into the unit's settings.
You can read the mounting instructions on Trailtech.net, and if you call them, they'll give you the details of what you need for your application.
That's one of the nice things about electronic speedos, you will no longer have any speedo error. I've checked mine by GPS, and it's spot-on.
You will need the 600K .25W resistor that Trail Tech sells. If you don't get one with your unit, they'll probably send you one for free, or maybe for a $7.95 shipping fee, which is what I paid. Their customer service is very helpful.
Old April 4th, 2013, 09:59 AM   #10
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
The SV650 kit comes with a resistor already wired into the tachometer lead. Not exactly sure what it's rated for, but I used the SV650 kit on my Honda Hawk 650.
k-os is offline   Reply With Quote
Old April 4th, 2013, 09:59 PM   #11
skilletmo
InfoWhore
skilletmo's Avatar
Ok thank you all! I just bought the sv650 kit which was the 75-600 for 92$ shipped. I will update picks once i put the whole front set up together! Its going to look like a whole new bike from the front.
Old April 5th, 2013, 05:43 AM   #12
k-os
Where'd you end up ordering it? I'll probably be getting another one for my third Hawk.
Old April 5th, 2013, 10:33 PM   #13
skilletmo
InfoWhore
skilletmo's Avatar
Here!
Old April 6th, 2013, 04:10 AM   #14
MistahT
Motorcycle(s): 2012 FZ6R, 2006 Ninja 250, 1977 Suzuki GS550
Subbed! GREAT info here. I might soon be putting one on my project Ninja
2012 Yamaha FZ6R (mine)
2004 Kawasaki Ninja 250 (wife)
2003 Kawasaki Ninja 250 Street Fighter project
MistahT is offline   Reply With Quote
Old April 6th, 2013, 10:37 PM   #15
skilletmo
InfoWhore
skilletmo's Avatar
Ill be posting updates so you can see how it works out
Old April 10th, 2013, 09:27 PM   #16
skilletmo
InfoWhore
skilletmo's Avatar
Just got it in! Here it is, noob question incoming...
The resistors should be NOT visible right? They should be in the RPM wires?
The manual says its here but shows it highlighted in the middle of the wire but i see nothing because im guessing it inside. But i might be wrong, can anyone confirm please.
Old April 11th, 2013, 06:41 AM   #17
Chicagobob
Chicagobob's Avatar
The resistor is under shrink wrap a few inches from the connector on the red tach wire.
Old April 11th, 2013, 03:13 PM   #18
skilletmo
InfoWhore
skilletmo's Avatar
Ok so they are not visible, good. I will be posting updates this weekend.
Old April 12th, 2013, 01:42 PM   #19
skilletmo
InfoWhore
skilletmo's Avatar
I am installing my TT Vapor tomorrow. I wanted to know a few things before i put it on.
What do you guys input for these settings, i know what to put for temp but want to see what you guys put it at. For the Pulses per revolution(Example:.5, 1, or 2) and wheel size (Example:2110):
-Program wheel size:
-Pulses Per revolution:
-High Temp:
-Over Temp:
For the Pulses Per Revolution there are 3 steps if PPR changes over a certain RPM, Do our ninjettes change PPR over certain RPMS?
08-12's please. Unless the pregens are the same settings.
Old April 12th, 2013, 06:26 PM   #20
Chicagobob
Chicagobob's Avatar
-High Temp:
-Over Temp:
Doesn't change - set it at 1PPM.
Old April 12th, 2013, 10:20 PM   #21
skilletmo
InfoWhore
skilletmo's Avatar
And wheel size is? Or do i keep that 2110 too? Also just to see what other are putting, what did you put for over temp and high temp?
Old April 13th, 2013, 05:54 AM   #22
Chicagobob
Chicagobob's Avatar
For the most accurate speedo, you should measure the wheel's rollout. Position the bike so the valve stem or some other reference point is at the bottom and mark the ground there, then roll the bike forward (while sitting on it) so that the wheel makes one full turn. Measure the distance in mm and enter that figure into the Vapor.
You can set the temp warning wherever you want it. Most engines are designed to run at 180-200F. The boiling point in a pressurized system should be above 212F, so maybe set it at around 200. That way, you'll have some warning of overheating before it becomes critical. My Vapor (mode 3 records all your maximums) shows I hit a max of 208 degrees.
Last futzed with by Chicagobob; May 13th, 2013 at 08:26 AM.
Old April 13th, 2013, 07:55 AM   #23
skilletmo
InfoWhore
skilletmo's Avatar
Ok thanks for the info. I am installing it now. For the speed sensor, did you just attach it with the adhesive or did you do something to make it more secure? it seems like it would be weak with just the adhesive, unless im wrong. Also it come with 2 magnes, a screw one and a single magnet. Do i use both or just one,
Old April 13th, 2013, 08:10 AM   #24
skilletmo
InfoWhore
skilletmo's Avatar
Never mind i out the magnit screw in the rotor bolt. When attachin the speed sensor does it have to be alllighned with it exactly? I might need a picture for this one....
Old April 13th, 2013, 10:59 AM   #25
Chicagobob
Chicagobob's Avatar
Magnet should pass near the end of the sensor. All this is spelled out in the manual, which is on Trail Tech's web site.
Old April 13th, 2013, 11:40 AM   #26
skilletmo
InfoWhore
skilletmo's Avatar
I got everything working, thanks for all the help. Ended up stripping the adhesive off the magnet and glue welding it on. Rpms are prefect with that resistor. Now im planning a way to mount it.
Old April 16th, 2013, 06:07 PM   #27
UnshavenCanuck
UnshavenCanuck's Avatar
Motorcycle(s): 2005 Ninja 250
Does anyone know the ohm rating on the resistor? I have a koso with a jumpy tach. I put in a 100k resistor and it improved the signal a great deal but its still jumpy at higher rpm
Thanks
Also @skilletmo im trying to find your write up on the cluster wiring you did on the knockoff gauge but cant seem to find it. its the same wiring for the pregen and czroe was inquiring.
UnshavenCanuck is offline   Reply With Quote
Old April 16th, 2013, 06:20 PM   #28
skilletmo
InfoWhore
skilletmo's Avatar
Ill post the thread link and resistor up tonight, im at work and replying on my phone. Need my laptop! Give me an hour or so.
Old April 16th, 2013, 07:34 PM   #29
skilletmo
InfoWhore
skilletmo's Avatar
Thanks
Do you mean this?
Oil: Blue/red (my Speedo had everything but the oil pressure... So that was empty on my connector)
High beam:red/black (in other 3 pin connector with the right turn signal)
N:light green
Speed: On cable for front wheel
coolant temp:red/yellow
fuel:light green/black
left turn:green
right turn:grey(on different connector with the High beam (3pin) )
back light multiple colors but in my case i didn't need that because mine ran on one led circuit.
power -:AKA ground wire black/yellow
power+:brown or red/blue (you can use either one) In my case i only needed one power + not many becuase mine was led and didnt need all those back light wires my original speedo had. Just one led light altogether on one wire.
rpm:black
spare power(power that is always connected to battery): You need to make your own, its very simple. Grab a wire long enough to go from your speedo to your battery and on one side put a connector for the harness and another a connector for the battery.
The thread is here
Old April 16th, 2013, 09:51 PM   #30
skilletmo
InfoWhore
skilletmo's Avatar
Thanks
I have to look at the resistor on my bike, i couldnt get the chance today since i went from school to work to the gym. So right after school i will take the tach apart and check it out for you. It should say on the resistor. @CZroe, I didnt forget about you either!
Old April 17th, 2013, 04:34 AM   #31
UnshavenCanuck
If it has color bands on it those would be much appreciated, I can figure out the resistance from the colors
Thanks again
Old April 17th, 2013, 07:10 AM   #32
Chicagobob
Chicagobob's Avatar
Do you mean this?
N:light green
left turn:green
rpm:black
The thread is here
If you are running a Trail Tech Vapor, you can buy their "dashboard" indicator light surround. You'll see that it comes with rubber light sockets that are identical to those in your stock instruments (at least with a pregen), so you can just yank them out and insert them into the new surround. Takes about 5 minutes.
Old April 17th, 2013, 07:13 AM   #33
skilletmo
InfoWhore
skilletmo's Avatar
Thanks again
Ill find out the resistor ohm's and the color after school.
Old April 17th, 2013, 07:39 AM   #34
mike_k
mike_k's Avatar
I'm pretty sure it's a 600k ohm resistor that comes in the "resistor cable" from Trail Tech.
Old April 17th, 2013, 08:04 AM   #35
Chicagobob
Chicagobob's Avatar
On their site, Trail Tech recommends, for an erratic tach, that you "Try tach sensor lead with the built in resistor (part # 7000-1004). If you are capable of soldering and would like to install a resistor yourself, it is a 600K OHM ¼ watt resistor. It should be placed about 3 inches down from the connector."
Old April 17th, 2013, 01:58 PM   #36
skilletmo
InfoWhore
skilletmo's Avatar
Thanks again
It has a black color band/tape, it says " 25°C VW-1 (.040)". I believe it is a 600k ohm like they said.
I posted a picture of how it looks, might be hard to read but i tried with my ****** phone lol
Old April 17th, 2013, 02:04 PM   #37
Chicagobob
Chicagobob's Avatar
Thanks, but those markings refer to the shrink wrap, not the resistor. If you slide off the wrap, you'll be able to see the resistor and record its color bands.
However, they are a little hard to find (not available at Radio Shack, anyhow), so I still think Trial Tech is the easiest source.
Old May 11th, 2013, 01:46 AM   #38
infinitewhiskey
meh
Motorcycle(s): 2002 EX250F Cafe/Streetfighter Project
What did you end up setting the tire size to? I'm running a 100/90 sport demon and I got 1753 (rounded up). However when I'm riding, it's says I'm at ~ 70 MPH when I'm probably at 40-50, which is based on the speed limit and the speed other cars were going.
Also I can't seem to find the page for the wire with the resistor on Trail Tech's website.
infinitewhiskey is offline   Reply With Quote
Old May 11th, 2013, 06:05 PM   #39
skilletmo
InfoWhore
skilletmo's Avatar
For the resistor you will have to go and call them, if you bought it from them they will most likely give it to you for free. If they dont it should be really cheap!
For the tire size and accuracy i will personally go out in a few and check on a gps even though it seems accurate when im riding beside people. Ill go do a double check one more time at a speedo sign thing that are posted around town and update. Ill also update the wheel size
Old May 11th, 2013, 11:01 PM   #40
infinitewhiskey
meh
Unforunately I bought it off eBay
I'll get in contact with 'em to see what'll happen.
Alright I'll be waiting. Thanks man.
SoCal 626/951
instagram | youtube | modifications
Ninja 250 Vapor Trail Tech skilletmo 2008 - 2012 Ninja 250R Tech Talk 35 October 1st, 2017 04:10 PM
Trail Tech Vapor Idiot lights RogerPapaMike 1986 - 2007 Ninja 250R Tech Talk 3 January 19th, 2015 10:11 AM
Trail Tech Vapor Review Kruse08 1986 - 2007 Ninja 250R Tech Talk 7 August 19th, 2014 02:55 AM
Trail Tech Vapor and mount rugbert 1986 - 2007 Ninja 250R Farkles 12 September 2nd, 2013 11:36 AM
Trail Tech Vapor Tach experience? Chicagobob 1986 - 2007 Ninja 250R Farkles 5 April 19th, 2013 05:23 AM
