#1 |
Join Date: May 2014 Motorcycle(s): '07 Ninja 250r, Honda CBR 500r, Ducati multistrada, MV Agusta Brutale Posts: 34
Mods
So I love my little 07 250. I have the forks rebuilt with 10 w oil. I will probably replace the forks and front wheel. I want ex500 front end to rebuild and a front 17 inch wheel. I will also change out the front caliper. How much of a weight difference is there? I have a ninja 600 fat boy shock coming. I have installed a full Muzzy exhaust. I rejetted the carbs to a 110 main, 3 washers under the needle, and 4 turns out on the air fuel screws. She runs good at 6000 foot elevation. There is also the stock air box with a uni filter. I also put in irridium plugs. I might keep the back swing arm and just order 130 x 16 front tire and mount on back.
She is such a fun bike to throw around. I did have some over heating issues. I lost a bolt that holds the line out of the water pump. She shot all the coolant out while I was about 70mph in a corner. She got hot enough where the thermastat and fan switch have failed. Replaced and fixed she runs great. I have also gone thru the valves and all. The rear wheel removal is the worst design I have ever seen. ![]() Them flames add 3 hp. ;P
Current bikes: Kawasaki Ninja 250r, Honda CBR 500R, Ducati Multistrada, MV Agusta Brutale |
#2 |
Old and slow
Join Date: May 2014 Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250 Posts: 889
#3 | |
dirty boy
MOTM - Apr '14
I don't have a pre gen but I'm running new gen, with pod filter, + full race exhaust and currently have 110 main at 1000-2500' elevation and I am considering going down to a 108 IDK though? Just struck me as odd, u ![]()
I love the smell of burning pre-mix in the morning I don't think I'm a lot dumber than you thought that I think that I thought I was once. ![]() |
#4 | |
EX500 full of EX250 parts
The NewGen swingarm should bolt right into the PreGen frame (the 500's is a bit wider at the pivot), if you want to go 17" back there too. Once again, I'm not sure about the wheel/brake details, but the swingarm itself should be pretty PnP.
![]() *** Unregistered, I'm not your mom and I'm not paying for your parts, so do whatever you want with your own bike. *** |
#5 | |
I got the zx600 shock today. I emptied the old oil and added bel ray 7 w fork oil. I put 15 lbs of air pressure back in her. Boy does she feel better. The loose pogo stick action is gone. She is much tighter.
#6 |
No sticky gas cap but I have lots of fun on her.
Mods | Old Lemon | 2008 - 2012 Ninja 250R Farkles | 20 | May 5th, 2012 12:37 AM |
First Mods | FoxRacerX78X | 2008 - 2012 Ninja 250R Farkles | 5 | April 4th, 2012 03:24 AM |
Yes or no on these mods? | Kerberos | General Motorcycling Discussion | 19 | December 13th, 2011 10:33 AM |
Some mods | Highalltheway | Pictures | 4 | August 23rd, 2011 07:23 PM |
Best looks and mods | A7xschecter6661 | 1986 - 2007 Ninja 250R Farkles | 12 | August 11th, 2011 07:54 PM |
