January 22nd, 2014, 02:10 AM | #1 |
[motorcycle.com] - 2012-2013 Zero Motorcycles Recalled for Buggy Controller Firmware
Zero Motorcycles is recalling 2013 FX and 2012-2013 XU, S and DS models because of a problem with its controller firmware that could cause a motorcycle to suddenly shut down. According to documents released by the National Highway Traffic Safety Administration, the controller firmware on some models may disconnect power to the motor in response to certain signal faults. The faults are random, infrequent and unrelated to the controller module, and should not affect the motorcycle function, so the controller should disregard them instead of reacting by cutting off power. Ironically, the controller and firmware were initially installed to correct a separate recall campaign on 2012 S and DS models related to a sudden engine shut-down. That issue was caused by a motor encoder position signal drift outside the signal limits recognized by the motor controller. After Zero received reports of similar sudden engine shut-downs, it discovered they were caused by those unrelated system faults. Zero Motorcycles personnel traveled to England to meet with Sevcon Limited, the manufacturer of the controller and firmware. Together, they concluded the signal faults were unavoidable during the life of a motorcycle, but the controller firmware should deal with them in a way that doesn’t result in the motor shutting down. Zero dealers will update the firmware on affected vehicles so that they will be better able to respond to these random faults. 2012-2013 Zero Motorcycles Recalled for Buggy Controller Firmware appeared first on Motorcycle.com News. Click here for full story...
[motorcycle.com] - Victory Motorcycles Recalled for Fuel Pump Issues | Ninjette Newsbot | Motorcycling News | 0 | January 9th, 2015 12:20 PM |
[motorcycle.com] - 2013 Triumph Trophy SE Recalled for Centerstand Problem | Ninjette Newsbot | Motorcycling News | 0 | January 2nd, 2014 04:00 PM |
[motorcycle.com] - 2012 Ural Sidecars Recalled for Breaking Rims | Ninjette Newsbot | Motorcycling News | 0 | November 19th, 2013 12:40 PM |
[motorcycle.com] - 2013 Can-Am Spyder RT and ST Models Recalled for Fire Risk | Ninjette Newsbot | Motorcycling News | 0 | August 30th, 2013 05:50 PM |
[motorcycle.com] - 2012-2013 Moto Guzzi Griso, Norge, Stelvio NTX Recalled in Canada | Ninjette Newsbot | Motorcycling News | 0 | August 1st, 2013 11:20 AM |
