Old March 6th, 2022, 06:01 PM   #1
NinjaFinally
Motorcycle(s): GPX250R 2006
Do the gear change levers wear out?
My gear change lever has a fair bit of side to side play, and also a smaller amount of up and down play. This is while holding the linkage under the lever still. I see that the lever has a bearing material of a black color - does that wear out? I also wonder whether the correct washers are installed - it has a washer with a small hole on the bike side and a thinner washer with a large hole on the allen head side. Any help is appreciated.
NinjaFinally is offline   Reply With Quote
Old March 7th, 2022, 12:16 AM   #2
NinjaFinally
I manufactured a washer from a piece of aluminum can and placed that between the outer washer and the head of the allen bolt. That got rid of 3/4 of the play. I tried a second washer but then it was too tight. I will take it for a test ride and see how she goes.
Apparently Al can is approx 0.097 mm ie about 0.1 mm. That is 1/254 of an inch, or 4 thou.
Thanks for looking.
Old March 7th, 2022, 10:19 PM   #3
Good job!
Wear your gear. Electronic M Videos 7 January 29th, 2016 12:34 PM
Please wear ALL of your gear.... jdoucet93 Motorcycle Gear 23 October 11th, 2012 04:31 PM
Wear your gear!!! You never know. EMSRacer07 !%@*#$%!)@#&!%@ I crashed! 23 October 4th, 2012 09:44 PM
Wear your gear?...because this is why... Gorilla25 Videos 25 October 2nd, 2012 08:26 AM
wear your gear massacremasses Videos 52 June 27th, 2012 09:18 PM
