June 7th, 2010, 06:39 PM | #1 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000 Posts: 95
Pessimistic fuel gauge
I've noticed the fuel gauge on the 250R-J is a bit pessimistic. Upon "E" I still have 100 miles of range. True "E" is hard on the peg after about 45 miles. Anyone else gettin' this?
June 7th, 2010, 07:13 PM | #2 |
Join Date: Sep 2009 Motorcycle(s): 09 Ninja 250R SE Posts: 376
I haven't run to E or anywhere near it. I think if you do a search, you'll see a thread or two about how many miles people get out of a tank. I did notice that it is a bit pessimistic, but I tend to fill at about 220 miles or so on the trip meter. And when, I fill it up, it is significantly less than 4 gallons. I calculate the milage most times and it is in the 50 mpg range. Resetting the trip meter each time you fill up is a good alternative and additional way to judge when it is time to refill.
June 7th, 2010, 07:34 PM | #3 |
FORMER MOTORCYCLE RIDER
Join Date: Dec 2008 Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10 Posts: 758
June 7th, 2010, 08:18 PM | #4 |
I ran out of gas at 264 miles. The guage was alittle above "E". I don't chance it anymore and just fill up around 200-220.
June 8th, 2010, 12:34 AM | #5 |
I tend to get around 70-75 mpg. I don't know if break-in had anything to do with that. I average about 70mph consistently.
June 8th, 2010, 04:11 AM | #6 |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
Well documented issue, like the CDI faults. The only fix is to replace the sender.
In the mean time, use your trip odometer and fill up around 200-220 miles and you should never go wrong.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
June 8th, 2010, 04:24 AM | #7 |
The fuel gauge is a total waste of time. It doesn't read full when it's full, it reads empty when it isn't empty. What exactly is the point of the stupid thing?
I do what I've always done... set the trip meter and fill up at 200 miles or so. It's simple, easy to remember and way more reliable. I suppose I should put something more useful over the fuel gauge. Maybe a ninja turtle sticker or something like that. |
June 8th, 2010, 04:58 AM | #8 |
June 8th, 2010, 05:10 AM | #9 |
IC2(SW)
June 8th, 2010, 05:14 AM | #10 |
Now we are talking...
June 8th, 2010, 01:05 PM | #11 | |
When I heard that, I installed the Daytona water temp gauge instead and dropped the FI temp gauge idea. I haven't confirmed if what I was told was true, but I found a work around, so I'm good. |
June 9th, 2010, 02:32 PM | #12 | |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
Well not quite the same amount of mileage, but close to yours also! My gas gauge has been like that since day 1, 1.5 yrs and 8,000 miles later its STILL the same! |
June 9th, 2010, 02:36 PM | #13 | |
Ive ran on vapors once, and only filled up with like 4.12 gallons! 4.8 gallon Tank, MY ASS! |
June 9th, 2010, 02:42 PM | #14 | |
while the fuel gauge is almost worthless to calculate how much gas is left, I would much rather it be pessimistic than optimistic. I always just use the trip meter to determine when it's time to fuel up. |
June 9th, 2010, 11:48 PM | #15 |
super ninja
Join Date: Feb 2010 Motorcycle(s): 2009 kawasaki 250r Posts: 127
omg are you guys serious!! 200 miles!!! wtf is up with mine, i always fill it up to the rim when it gets to the tiny line before E and i never get more then 110 miles! and thats if i stay out of the throttle jeez guys just wtf
2009 Ninja 250r aftermarket parts *HotBodies double bubble* *Swing Arm Sliders* *Sylvania Sliverstar Ultra* *Akrapovic Slip-on* *Shinto Clip-Ons/Grips/Bar Ends* |
June 9th, 2010, 11:50 PM | #16 |
how many gallons go in when that happens?
June 10th, 2010, 07:31 AM | #17 | |
June 10th, 2010, 07:33 AM | #18 |
self wrencher
Dude it's not the gauge, it's the sensor mang!!!
Posted via Mobile Device |
June 10th, 2010, 07:37 AM | #19 | |
Just wondering if we can adjust the guage to the sensors error...
June 10th, 2010, 08:39 AM | #20 |
Hi Jason -
Those that have taken apart the sensor (from past threads) have made it seem like what you're suggesting (modifying the gauge reading) won't work. The sensor is sending an "empty" when the tank isn't empty. Moving the gauge up to show 1/3 full, would then mean that it would stay at 1/3 full even as the tank itself goes down all the way to empty.
June 10th, 2010, 08:53 AM | #21 | |
June 10th, 2010, 09:19 AM | #22 | ||||
Psychic war veteran
The fuel level sender uses a coil and a wiper, with the coil stationary and the wiper attached to a long arm float. Part of the problem with making any adjustments to the gauge is that the sense coil is wound in a differential manner to compensate for the shape of the tank (and yes, a good one will indicate properly, showing about 1 gallon per tick, or about a 4 gallon spread from FULL to EMPTY). The sense coils are closer together on one end than they are on the other end, and that's how the shape of the tank and variable useage/volume of fuel is compensated for. Another issue is that the wire often shifts on the coil backer, even if the wire isn't stretched.* The usual indication of this problem is inconsistent readings at any fuel level. Rock the bike from side to side and it'll remain stable, but it should shift a little rocked front to back. If you get nearly no change rocking front to back with about 1/2 to 1/3rd tank AND inconsistent readings when you KNOW you're full or KNOW you're empty, you might have streched or shifting sense wires. Yet another issue is that the tension on the wiper is such that it often stretches the wire on the backer, making for inconsistent readings. * The usual indication of this problem is the gas gauge hanging up at one particular reading, then suddenly dropping (or not) once you go over a heavy bump, or rises only from where it's stuck to full when you gas up. Further, the sense button on the end of the wiper is very soft, so that over time it rubs off onto the sense coil, shorting across some of the wires, and reducing sensitivity and giving false readings. * The usual indication of this problem is that the fuel level indicated remains relatively constant from full until it goes dead flat empty. If your fuel gauge is not reading properly as above, you could have any or ALL of the above issues. The needle is only displaying what it's told by the sender. To find out what problem you have (and thus how to properly adjust the gauge, if possible), you have to remove the sender. Once you do that, you're already 1/2 there to replacing it anyway, with no way to ensure another of the problems won't occur later on. Quote:
Pull the fairings, pull the tank, pull the sender.....reverse. Ride. Or use the Odo, as indicated above.
June 10th, 2010, 04:15 PM | #23 | |
IC2(SW)
On the FI 250r the temp sensor is two parts. One part is for the ECM, and the other for the gauge. Will have to check, but I'll bet the meters are the same(fuel/temp)..... just a different face In the pic, D = ECM & E = temp gauge |
June 10th, 2010, 04:45 PM | #24 |
you could very well be correct. My info was from a dealer in England... he may not have known what he was talking about.
June 10th, 2010, 05:27 PM | #25 | |
IC2(SW)
That info is out of the FI manual, you would think it was correct Gauge between the two are a tad diff. temp - 120deg is 210 ohms, 248deg 21 ohms. Fuel - Empty is 100 ohms, full 10 ohms..... Now we need somebody in the UK that knows whats up, to get us some parts |
July 12th, 2010, 06:57 PM | #26 | |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
anyhow, i need to know what ohms Ω i need to progam in. it has a range from 100Ω to 510Ω, atm its set at 100Ω, is that correct for our Ninjettes? Thanx!
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield |
July 13th, 2010, 12:46 AM | #27 |
Join Date: Jun 2009 Motorcycle(s): Kawasaki Ninja 250R Posts: 50
yeah... i like it... it's correct bro... I allready try at 510, it didn't drop altough the tank empty..
www.anekaban.com Chemonk Modified Authorized Dealer in Bali The Best Body Kit Quality in Indonesia |
July 13th, 2010, 12:08 PM | #28 |
Join Date: Jun 2009 Motorcycle(s): 09 250R, 08 connie 14, 08 honda ruckus(gave to mom) Posts: 92
I hit the trip meter reset at every fill up, there is usually 250 miles on it. 61mpg on the last tank. Mine stays on "E" for the last 60 miles.
July 13th, 2010, 12:34 PM | #29 |
Risky business but I guess you would know your bike better than me...
July 13th, 2010, 12:59 PM | #30 |
Join Date: Mar 2010 Motorcycle(s): Ninja 250r Special Edition 25th Anniversary Posts: 17
What model is that ?
July 13th, 2010, 06:24 PM | #31 |
its a Koso RX2-n
replacement speedometer, with a custom bracket and voltmeter, Matt (ztrack157) can get them for you but he would have to send it over to Peru and that might be a problem, and add to the expenses http://www.ninjette.org/forums/showp...&postcount=150 http://www.ninjette.org/forums/showp...&postcount=152 more pics and info on those link there
Replace Fuel Gauge with Fuel Light? | Proteus | 2008 - 2012 Ninja 250R Tech Talk | 8 | December 2nd, 2014 08:33 AM |
My video on how to fix the fuel sender for your fuel gauge | Klint | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 2nd, 2013 09:04 PM |
Fuel tank/Fuel gauge issues | coolcatjames | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 23rd, 2012 06:25 PM |
Fuel gauge not working | jdoucet93 | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 15th, 2011 10:07 PM |
fuel gauge | shellneil | General Motorcycling Discussion | 8 | November 1st, 2009 02:26 PM |
