Old November 21st, 2017, 08:06 PM   #1
Credigy
Motorcycle(s): 2013 Ninja 300SE (EX300A)
Bike not starting......
Have a 2013 300 that will not start. Here's what I got.
-Starter locked up so it got replaced.
-Bike sat for probably 9-ish months without being ran.
-Just bought a new battery today because the old one was dead.
-Bike turns over and starter functions properly but bike wont fire up.
-Lots of strange clicking and buzzing coming from what I assume is either the primary or secondary tps.
Any gurus out there with wisdom to bestow would be greatly appreciated.
Credigy is offline   Reply With Quote
Old November 21st, 2017, 09:02 PM   #2
Hi and welcome!
Some clarifications please.
Was it starting and running OK before starter died? Any idea why starter locked up?
What is battery-voltage before cranking? And battery-voltage during cranking?
Not TPS, but throttle-butterflies. Could be them... but... can you get video & sound of this?
Also do you have access to oscilloscope? This is literally a 5-minute repair with oscilloscope.
Old November 21st, 2017, 09:21 PM   #3
Credigy
Ran great before the starter went out. Not sure what caused it to lock up. I'll get a video of it right now.
Old November 21st, 2017, 09:28 PM   #4
Credigy
this is the noise
Old November 21st, 2017, 09:32 PM   #5
Credigy
Maybe this will work better https://youtu.be/DrMSGInlNVs
Old November 21st, 2017, 09:33 PM   #6
Also how many miles on bike?
Please list any repairs & maintenance done in the past year.
Old November 21st, 2017, 09:34 PM   #7
Credigy
10k miles on the bike. Other than a replaced battery and starter, nothing outside of routine maintenance .
Old November 21st, 2017, 09:37 PM   #8
That sounds like a relay clicking. The starter's not even turning and the engine's not turning. What state of charge was battery in when you installed? Really need to get voltage of resting battery and voltage while cranking. Very useful data.
I think the clue is figuring out why the previous starter died. It dying may only be a symptom caused by actual problem. That problem may still exist.
Can you bump start bike in 2nd-gear? Does that turn engine or does it just skid rear-tyre?
Old November 21st, 2017, 09:41 PM   #9
Credigy
I didn't try to start it in the video, that noise happens when I turn the key on. Neighbours will bitch if i try to start it. Haven't tried to push start it yet.
Old November 21st, 2017, 09:45 PM   #10
Credigy
Ill get a video up in the AM of the bike cranking.
Old November 22nd, 2017, 06:47 AM   #11
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
put the battery on a charger and get it fully charged. be honest how many times and how long did you hold the start button before the other starter went out? holding it too long with a weak battery burns those bad boys out.
I was also thinking of bump starting it too.
TEAM ALFALFA
www.apexassassins.com
Old November 22nd, 2017, 07:25 AM   #12
Credigy
Battery is brand new with a battery tender on it. As i stated previously i do not know why the starter went out. One day it worked the next it didnt. I know enough about automotives not to hold down a starter when an engine wont start. I am at work and will post a video of it as soon as i get home.
PS: Super classy signature. Glad to know who rhe adults are.
Old November 22nd, 2017, 07:27 AM   #13
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
1. you let the bike set for 9 months
2. Clicking like that means there is not enough juice going to the starter.
3. some of us have been around longer then you and have a sense of humor.
TEAM ALFALFA
Old November 22nd, 2017, 07:29 AM   #14
Credigy
I am actually bisexual and don't find homopgobic slurs in the least bit funny.
Old November 22nd, 2017, 07:36 AM   #15
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
There you go again making assumptions. Thinking you know something you don't, thats 2 times in the last 10 minutes.
TEAM ALFALFA
Old November 22nd, 2017, 07:42 AM   #16
Credigy
You have done nothing but the same lol. I can see this is going nowhere fast so i will just end it.
Old November 22nd, 2017, 09:16 AM   #17
ducatiman
ducatiman's Avatar
Provided the battery is adequate and cranking...i'd suggest to drain the tank and float bowls....9 month old ethanol fuel is not conducive to proper combustion. Proceed start attempts using 100% fresh fuel.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old November 22nd, 2017, 09:30 AM   #18
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
his signature is the [you ]tag; put it somewhere and it says anyone's name that looks at it... kinda lowbrow but wasn't aimed at you in particular
Old November 22nd, 2017, 09:34 AM   #19
JohnnyBravo
Old November 22nd, 2017, 09:47 AM   #20
I had signatures turned off. Didn't even realize he had that signature. That's funny!!!
Old November 22nd, 2017, 09:57 AM   #21
JohnnyBravo
Right
Old November 22nd, 2017, 03:50 PM   #22
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
A Ninja 300 is not going to have float bowls to drain.It is a fuel injected motor.
pantera is offline   Reply With Quote
Old November 22nd, 2017, 04:30 PM   #23
ducatiman
ducatiman's Avatar
^ ouch, gettin' my threads mixed up...but, FI or not.... the comment on refreshing 9 month old fuel still stands
Custom Carb Service
Old November 22nd, 2017, 04:31 PM   #24
Credigy
For what its worth:
Got the bike to start by popping the clutch on a hill. After doing so the bike will start up and run. However, it sounds like the starter motor is trying to engage every time I hit the kill switch. (Potentially why the original starter locked up.)
PS: JohnnyBravo thanks for clarifying that. I appreciate it.
Regardless thanks to everyone for giving it a shot.
Old November 22nd, 2017, 05:32 PM   #25
JohnnyBravo
Anytime
Congrats!
Old November 22nd, 2017, 06:13 PM   #26
Sounds like you may have shorted wiring and/or switches. Use voltmeter to verify you have voltage when and where there should be and none when/where there shouldn't be.
Old November 23rd, 2017, 10:27 AM   #27
Credigy
First and foremost Happy Thanksgiving!
Did what Jac said and started checking voltages. Starter is getting 12v THE ENTIRE TIME the bike is running. That most certainly explains why the last one crapped out. Trying to check where exactly the issue is coming from (relay, starter switch, etc.) but sadly it's pouring rain here right now. I will put up some more info as soon as i get it. You have been a great help @JacRyann. Thank you!
Old November 23rd, 2017, 10:51 AM   #28
What terminal did you measure? The main one should have 12v on it all the time. It's the solenoid terminal that should not, once the button is released.
Edit: this doesn't apply to a Ninja 250, which has only one terminal on the starter motor.
Old November 23rd, 2017, 10:57 AM   #29
Credigy
@ Triple Jim Measured the voltage from the post directly on the starter and the terminal on the solenoid. Both have 12v as soon as the bike starts.
Old November 23rd, 2017, 11:04 AM   #30
Credigy
These are the terminals I measured from
Old November 23rd, 2017, 11:49 AM   #31
Sorry, I was thinking of one of my other motorcycles. The 250 has only one terminal, and that should not have 12v on it unless you're actually cranking the engine to start it.
Old November 23rd, 2017, 12:51 PM   #32
Starter button is shorted somehow. Verify that it's sending out +12v when key ON but not pressed. Most likely it's mechanically broken, spring's not working to disconnect contacts. Or contacts inside bent and switch is "pressed" all the time.
Bike stalls out instead of starting Ballardst 2008 - 2012 Ninja 250R Tech Talk 10 September 27th, 2016 11:28 AM
Bike not starting.... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 2 April 29th, 2012 07:33 PM
Bike not starting?! nightrider 2008 - 2012 Ninja 250R Tech Talk 32 September 5th, 2011 04:44 PM
starting bike james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 April 3rd, 2010 12:12 PM
Bike is not starting now :( bikermunda 2008 - 2012 Ninja 250R Tech Talk 6 January 3rd, 2010 10:02 PM
