Old June 22nd, 2013, 08:41 PM   #1
indr
Need Visual Confirmation of Carb Hose Routing
Hello.
This is a picture of a stock Ninja 250 carburettor from the top.
See how the hoses running on top of the left carb are criss-crossed? Could some one please verify which ports these go to on the right carb?
I ask because, even tho hoses in all carb photos are crossed, if I were to plug them on crossed holes, they wouldn't fit.
I.e. if the fat hose was going to the port on the engine side of the carb, it'd be too big (the hose's inside diameter). And if the skinny hose was going to port closest to the airbox, it'd be too small (the hose's ID). So, does the small hose route around the big hose underneath and between the two carbs?
indr is offline   Reply With Quote
Old June 23rd, 2013, 02:22 AM   #2
tubarney
The photo you posted is correct.
Old June 23rd, 2013, 09:05 AM   #3
indr
Yes. But I can't see which hose goes where.
Old June 23rd, 2013, 07:49 PM   #4
tubarney
I'm assuming your talking about the right carb.
The fat hose goes engine side and the thin hose goes airbox side. They start off the other way around on the left carb and cross over each other before connecting to the right carb.
There should be some connections that pivot so you can move them around to make it easier to connect the hoses.
Hope it helps. Not exactly sure what you want to know.
2008 250R Carb hose routing? devildogae 2008 - 2012 Ninja 250R Tech Talk 12 November 6th, 2016 04:32 PM
Carb Hose Routing jschatte 1986 - 2007 Ninja 250R Tech Talk 6 July 8th, 2014 08:30 AM
vacuum hose routing Sebastian f7 1986 - 2007 Ninja 250R Tech Talk 2 July 28th, 2013 07:06 AM
Routing for fuel overflow hose haze5736 1986 - 2007 Ninja 250R Tech Talk 3 July 7th, 2011 07:09 PM
Routing for 'side hose' on fuel tank kobachi 2008 - 2012 Ninja 250R Tech Talk 11 December 12th, 2010 05:00 PM
