June 24th, 2013, 04:52 PM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja 250R - Kawi Green Posts: 138
Motor leak?
Thought I should ask about this before I did the oil change... This was after cleaning the entire underside of the motor then it sat for 2-3 days and remained clean, then I rode for about 10 minutes and I got this...
How should I go about diagnosing and fixing this? |
June 24th, 2013, 05:13 PM | #2 |
there is a rubber o ring if you take that cover off (use like a 50c coin or something and some pliers) if you drain the oil out, then remove that cap, you can replace the o-ring inside and it should fix the leak
June 24th, 2013, 05:19 PM | #3 | |
Any chance you know the size or should I go straight to dealer... It's safe to just screw it back on hand tight...can't imagine how I would torque that.. Lastly, I can only do this while the oil is drained, correct? |
June 24th, 2013, 05:24 PM | #4 |
Lean the bike against something on the right side. No need to drain. To torque: use toonie and your fingers till it's finger snug. Then a little bit more so it doesn't vibrate loose.
Part #: 671B2540 |
June 24th, 2013, 05:26 PM | #5 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
June 24th, 2013, 05:35 PM | #7 | ||
In the past 2 days ill have done SS braided front brake line, EBC HH pads, fresh brake fluid in rear, spark plugs, oil change, coolant, fix front fork leak and now this... Here's hoping she runs great afterwards.. |
June 24th, 2013, 05:40 PM | #8 | |
June 24th, 2013, 05:54 PM | #9 | |
Would you recommend draining the rear fluid and then new or just bleeding until all the old is out while topping up with new? |
June 24th, 2013, 09:00 PM | #10 |
The latter of the two
June 25th, 2013, 06:39 PM | #11 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
If the O-Ring looks good, you can use just a touch'e of high-temp silicone around the upper portion of the threads of this inspection hole cap. No need to go crazy with the silicone.
[Fyi : Race orgs mandate it]
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
[roadracingworld.com] - MPT Industries Named "Official Motor Oil" Of New Jersey Motor | Ninjette Newsbot | Motorcycling News | 0 | January 19th, 2015 10:40 AM |
Is this a leak? Anyhow, I want it gone | the big mike | 2008 - 2012 Ninja 250R Tech Talk | 19 | August 13th, 2012 08:23 AM |
Rear brake fluid leak (container leak?), any advice appreciated. | deaddemon | 2008 - 2012 Ninja 250R Tech Talk | 5 | November 6th, 2011 01:52 PM |
[hell for leather] - Motor cop injured at memorial for motor cop killed in head on co | Ninjette Newsbot | Motorcycling News | 0 | June 7th, 2011 12:40 PM |
[topix.net] - Motor cop killed in head-on collision with motor cop | Ninjette Newsbot | Motorcycling News | 0 | May 28th, 2011 02:30 AM |
