Old June 28th, 2012, 04:55 PM   #1
fizzer914
fizzer914's Avatar
Motorcycle(s): 2010 250 se
front brake PROBLEM
Originally Posted by my boy kraazy
Wuzzzz up , my people!
PLEASE HELP!!!!
Just did 500 fork swap and twig replacement (lol eddikay). ( much thanks to the Pfizzer Foundation for the donation) and urbanninjas install shop on my pre gen everything seem like it accepted it well all except the front caliper just grabbing the a 1/4 of the rotor making pad fall out with every compression. Any help would be appreciated and of course get me back on the damn road already!!!! What u guys think ?every one of the guys in put has got me swapped already just got work out the bugs..
Lemme know :
Do I need new rotor?
Caliper?
Tire/rim?
Moos bracket?(YouTube)
What the hell!!!!
Please help!!!! That tech day seems good .... I'll RSVP now!! Thanx
fizzer914 is offline   Reply With Quote
Old June 28th, 2012, 07:36 PM   #2
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
front brake-fork prob ?
This forum always come tru so....my pal is still waiting for an RSVP on pre-gen tech...here's the situation...I know you guys out west are still awake:
HE PUT FORKS FROM A 500 ONTO A PRE-GEN NINJETTE:Originally Posted by my boy kraazy
PLEASE HELP!!!!
Lemme know :
Caliper?
Tire/rim?
What the hell!!!!
Old June 28th, 2012, 07:39 PM   #3
translation:
Just did 500 fork swap. the front caliper is only grabbing about 1/4 of the rotor making pad fall out with every compression.
solution:
make the pad grab more of the rotor.
Old June 28th, 2012, 08:01 PM   #4
eddiekay
eddiekay's Avatar
LIKE I SAID...THIS FORUM ALWAYS COMES THRU...
Thanks alex...I'll have krazzy come to this forum.
Please correct me if I'm wrong here but...
I was thinking the pregen rotor was not of sufficient diameter to fully get into the caliper...when the caliper was mounted to a 500 fork. ??? Like maybe the mounting holes for the 500 caliper were 1/2" further away from the center of the wheel ????...because the 500's wheel was 1" bigger ?
Old June 28th, 2012, 08:16 PM   #5
kraazy
We need 1.21Gigawatts now
kraazy's Avatar
Motorcycle(s): 1Badazz2fiddy,ZRV 500
Thanx Eddiekay,
So alex should I replace with a500 rim/wheel ,
Or could I use a bracket of some sort to fill the gap?
kraazy is offline   Reply With Quote
Old June 28th, 2012, 08:18 PM   #6
kraazy
kraazy's Avatar
Or what if I reverse the fork and then mount the caliper? Facing front .
Old June 28th, 2012, 08:28 PM   #7
/merged with dupe thread in pre-gen tech area
Old June 29th, 2012, 12:56 AM   #8
jschatte
jschatte's Avatar
Motorcycle(s): 1988 Ninja 250
DONT DO THAT!
First of all it will just make things more out of wack. Second, the force through braking will work towards ripping the caliper off, not against it as usual.
The easiest solution is to get a 500 rim and rotor.
You can get a new caliper bracket
Or get a larger rotor (probably will need to be custom)
jschatte is offline   Reply With Quote
Old June 29th, 2012, 02:49 AM   #9
fizzer914
fizzer914's Avatar
im not 100% but im pretty sure u dont need to swap out the rim (maby) i think u should try a different rotor but when i had the pre gen it looked like a bolt on swap thats y i got them. is there a bracket on the caliper that has multiple holes try mounting them in in another set of holes thats just my
Old June 29th, 2012, 11:59 AM   #10
looking at the part diagrams for the ex500 forks and the newgen ex250, they look almost identical. if the only issue is that the pregen rotor is too small, finding a larger rotor (ex500, newgen 250) will fix it. though it honestly wouldnt surprise me if it was slightly different. personally i would throw on a 500 wheel and rotor to complete the front-end swap. that way you know the parts were made for each other. the 500 wheel is a 17" just like the newgen 250 wheel, right? you might want to swap the rear end to 17" also if that is the case so you can have consistent tire choices.
Old June 30th, 2012, 07:33 AM   #11
kraazy
kraazy's Avatar
Much thanx for the input and help guys . I m gonna try and move bracket to other threads on bracket if not gonna just try and swap whole front or hopefully find some pregen forks and wipe the sweat off my forehead already.
Thanx again guys going now to play with this damn thing!!!
Old June 30th, 2012, 08:10 AM   #12
fizzer914
fizzer914's Avatar
or sell it for parts and get a new gen trust me it was the best move i did considering i gave my old one away.
Front bolt / fork question razingman 2008 - 2012 Ninja 250R Tech Talk 4 July 12th, 2013 06:38 PM
Front Fork Repair ? Ninjesterai 2008 - 2012 Ninja 250R Tech Talk 7 March 25th, 2012 02:08 PM
Adjustable Front Fork? Nfiniti 2008 - 2012 Ninja 250R Tech Talk 17 November 20th, 2009 12:03 PM
Clonking coming from front fork Nickds7 2008 - 2012 Ninja 250R Tech Talk 1 September 26th, 2009 01:22 AM
Front fork Valve Emulators? empire00 2008 - 2012 Ninja 250R Tech Talk 5 July 21st, 2009 01:30 PM
