Old November 29th, 2012, 12:52 AM   #1
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Motorcycle(s): 2007 Sportster XL1200C
Shell Rotella T5 anyone?
So I went into the local NAPA to pick up an oil filter for my CTS. What do I find sitting on the shelf in he oil section? Shell Rotella T5 (10W40) heavy duty oil. I know that the 15-40 Rotella T is popular amongst riders, and Rotella T6 (5W40) synthetic is becoming popular as well.
Coincidentally, I was speaking to a friend of mine about what oil I would run during the summer. Problem solved, Shell Rotella T5 (10W40) full syn heavy duty oil...
Unfortunately, I have only seen this at NAPA; the T6 is available at Walmart along with the regular Shell Rotella T 15W40.
ricomtzjr is offline   Reply With Quote
Old November 29th, 2012, 03:30 AM   #2
YunMing
Motorcycle(s): (Sold) 2007 Red Ninja 250r, 2003 Cbr 600 F4i
Been using Mobile 1 10w - 40 and recently switched to Rotella T6. Honestly I can't really tell the difference
YunMing is offline   Reply With Quote
Old November 29th, 2012, 01:21 PM   #3
josefmd
josefmd's Avatar
Motorcycle(s): 2014 Yamaha Bolt
Just did my first oil change at 600 miles, and put in Rotella T 15-40. At the next change I am going to switch to full syn either T6, or T5 if I can find it without too many issues.
josefmd is offline   Reply With Quote
Old November 29th, 2012, 01:59 PM   #4
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Your wallet has more money in it after oil changes.
menikmati is offline   Reply With Quote
Old November 29th, 2012, 05:44 PM   #5
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Same here, I bought Rotella T6 not knowing about T5.
Looks like Rotella T5 will be my summer fill.
Menikmati, how are you getting your fuelly logo on here, every time I use the links, it ends up like this below...
Old November 29th, 2012, 07:31 PM   #6
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
my first 2 oil changes in syn I use T6.. I found the T5 also at napa and am running it now.
I can't tell any diff, I just feel better using a 10w-40
My replies are intended for street riding only, plz do not provide track only replies.
Visit my new MotoVlog Channel !!
Old November 29th, 2012, 07:46 PM   #7
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Yeah, especially in the hot Texas summers...the T6 is good for El Paso's 30-40s mornings and 60s afternoons...
But yeah, it's just a peace of mind thing for me too.
Old November 29th, 2012, 08:47 PM   #8
tapdiggy
Humble Observer
tapdiggy's Avatar
Motorcycle(s): 2009 Yamaha XT250
I don't recall, what is the recommended oil weight for ninjas?
Everything I post is "IN MY HONEST OPINION".
Why is "Parking Lot Enduro" not a thing?
tapdiggy is offline   Reply With Quote
Old November 29th, 2012, 08:52 PM   #9
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
According to the manual, anywhere from 10W30 up to 10W50 and 20W40 to 20W50.
Old November 29th, 2012, 09:01 PM   #10
tapdiggy
Humble Observer
tapdiggy's Avatar
K.
So I'm curious on the "peace of mind" aspect concerning the use of T6 5W-40 over the T5 10W-40, . I don't imagine the oil is going to stay in the cold range long enough to scrape up the cylinder or hurt a valve.
Old November 29th, 2012, 09:18 PM   #11
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Yeah, I see where you're coming from. From what I would understand, a syn 10W40 will flow below 0*F and the 5W40 will go further than that...I used to do that for my vehicles, but now I just stick with 5W30 for my car and truck.
I may just stay with 5W40 syn. Year round...my worry is that I just bought it in October with 1 mile and purchased a year of extended warranty. I just don't want to void my warranty since a 5W40 isn't on the recommend listing...
Old November 29th, 2012, 09:30 PM   #12
tapdiggy
Humble Observer
tapdiggy's Avatar
That is a good reason. Never know if you bought the bike with an wonky engine that suddenly blows a top end (seriously, it happens). Dealers can be sticklers to avoid free work. Moral is, if you are gonna do your own maintenance, don't buy extended warranties. I guess. I am kinda cheap so I consider them anyway.
Old November 29th, 2012, 09:41 PM   #13
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Well, my own maintenance is limited to all the basic preventive maintenance and DIY projects. I am not experienced nor do I have the tools to do major work like an engine rebuild, which is why I purchased a year extension.
Old November 29th, 2012, 09:46 PM   #14
tapdiggy
Humble Observer
tapdiggy's Avatar
Word. Comes back to the peace of mind thing. like I said, I'm cheap. I'll buy the expensive thing that will hold up, or the cheap thing that I don't mind replacing. Can't really do that with bikes, so I get your point.
Old November 29th, 2012, 09:52 PM   #15
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Rotella T5 is not a JASO MA certified oil. It is an energy conserving oil which can promote clutch slippage. See http://www-static.shell.com/static/c...c_brochure.pdf for specifications.
geeker is offline   Reply With Quote
Old November 29th, 2012, 10:15 PM   #16
tapdiggy
Humble Observer
tapdiggy's Avatar
If the 300 riders get "slipper" clutches, shouldn't everyone?
Old November 29th, 2012, 10:36 PM   #17
geeker
geeker's Avatar
Sure. Why not? But a slipper clutch doesn't slip while accelerating. It slips when not enough throttle is applied during downshifting to prevent rear wheel lockup.
Old November 29th, 2012, 10:40 PM   #18
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Well, I could have sworn it was a JASO MA cert oil. I'll have to look at it again at NAPA. Not that I am doubting you, since your reference is a Shell website...I just thought I saw it on there...so if I am, in fact, wrong then I retract my previous statements about Rotella T5.
Old November 29th, 2012, 10:49 PM   #19
EsrTek
EsrTek's Avatar
Interesting... I admit I know nothing really about oil, figured if they sold it on same shelf as others it was the same. I only wanted to run 10w-40 because that is what the dealer put in it. They have many more yrs Exp then me, so figured it was better to keep my choices along same guidelines.
Old November 29th, 2012, 10:52 PM   #20
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
There is a lot of hype for and against dealer recommendations...
I have read oil articles where some have run nothing but auto oil and never had a problem. It's your bike, I say put want you want in it.
Old November 29th, 2012, 11:01 PM   #21
geeker
geeker's Avatar
A good read: http://www.ducatimeccanica.com/oil.html
Old November 30th, 2012, 01:04 AM   #22
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
That was some really good reading...another reason as to why I chose to use shell Rotella T6. One thing though, I would stay away from "energy conserving" starburst oils.
For my 600 mile change, I went with the petroleum Valvoline mc oil for about $4/qt. Now I am approaching 2000 miles and am ready to do another oil change, this time with Shell Rotella T6 syn; it cost me a whole $23 for a gallon, which is good enough for 2 fills.
Shell Rotella 6T Question... Fakker 1986 - 2007 Ninja 250R Tech Talk 14 July 10th, 2014 04:01 PM
Shell Rotella T6 Rebate - Offer valid March 1 - May 31, 2013 Motofool Motorcycle-related 7 June 10th, 2013 07:01 PM
Shell Rotella T6 5W-40 Synthetic Motor Oil $11 after $5 MIB (1 gal.) mfresh Motorcycle-related 0 March 3rd, 2013 07:59 PM
rotella T akcalhoun 2008 - 2012 Ninja 250R Tech Talk 4 November 30th, 2012 09:09 AM
Shell Rotella Oil randomwalk101 General Motorcycling Discussion 23 September 19th, 2010 07:34 PM
