Old July 13th, 2013, 01:18 PM   #1
Insan3guy
Insan3guy's Avatar
Motorcycle(s): 2015 zx6r
Thumbs up Is this supposed to be here? (hole in pregen airbox) [yes it is]
So I'm doing the carbs while I have a couple days off, and I figured that I'd clean up the bike a bit. I was cleaning out the airbox (just using air and a rag, didn't want to take the chance on a chemical that might eat the plastic), and I found a strange hole... It looks drilled, but I'm really not sure whether or not it's supposed to be there?
It's on the left section of the box(looked for one on the right, none there); looking at it from the left side, it's on the bottom right. I'll attach some pics.
Also, if it's /not/ designed like that, what can be used to plug it? I have some ABS cement left over from a fairing repair, would that be okay to use?
Thanks in advance!
Last futzed with by Insan3guy; July 14th, 2013 at 10:20 PM.
Insan3guy is offline   Reply With Quote
Old July 13th, 2013, 01:22 PM   #2
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
I think its a drain hole as mine also has the same hole.
Old July 13th, 2013, 01:24 PM   #3
Insan3guy
Insan3guy's Avatar
thanks for the fast reply!
Yeah, I figured that since it already had a drain hose it shouldn't have any more holes in it. Oh well
Thanks!
Old July 13th, 2013, 01:39 PM   #4
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Mine has the hole!
Old July 14th, 2013, 10:06 PM   #5
jayman87
Motorcycle(s): 2007 ninja ex250
Mine has that too. Oil started leaking out of it and dripping down the side of the bike. I couldn't figured out where that was coming from for a min. Found it and plugged it with some Permatex. I hope that was the right thing to do. Or more so that it doesn't cause problems.
jayman87 is offline   Reply With Quote
Old July 14th, 2013, 10:09 PM   #6
Insan3guy
Insan3guy's Avatar
If it's there from the manufacturer I can only assume it's important to the operation of the bike.
Oil coming out of it is probably to keep that same oil from going somewhere more important, like the carbs
Old July 15th, 2013, 02:19 AM   #7
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Too much oil in your filter? As it drips down and pools in the bottom, there is a convenient little hole for it to drain through.
baxtc1 is offline   Reply With Quote
Old July 15th, 2013, 02:25 AM   #8
fishdip
fishdip's Avatar
I was thinking it was for water to drain out if it enters from the top of the box.
Old July 15th, 2013, 02:33 AM   #9
baxtc1
baxtc1's Avatar
Correct.
Old July 15th, 2013, 04:14 PM   #10
jayman87
I thought that's what the hose in the front of the airbox was for. Not the crank case breather but the little hose with the plug. I make sure to check that often after I clean and oil my filter, but the last time it I guess I didn't check it enough. Every time I came back to the bike, more oil was leaking. I was leaving oil stains everywhere so I plugged it. The comment about the water drainage makes me nervous though. I don't think anything could reach the carbs but it would definitely reach the crankcase.
Old July 15th, 2013, 04:34 PM   #11
baxtc1
baxtc1's Avatar
The hose at the lower front of the airbox is to drain any oil/condensate that builds up in your airbox, mostly from your crankcase breathing. The hole before the filter is there to drain any water that might get into the air inlet before the filter. If you get a little generous with oiling your filter (read, too much oil), the oil will drain down from the filter due to gravity, some of that oil will drain through the hole. That hole is before the filter so is not considered an air leak, the drain hose at the front lower of the airbox should be kept plugged to maintain the seal of the airbox and to prevent allowing unfiltered air into your engine. The crankcase breather hose should be connected to the crankcase and airbox for the same reason.
If you have oil running from that hole, you probably have too much oil on your filter.
Re-reading your post, is the oil coming from the hose or the hole near the filter? If it is from the hose you may have excessive breathing from your engine, or too high an oil level.
Round front hole on airbox? baz666 1986 - 2007 Ninja 250R Tech Talk 7 March 23rd, 2014 03:21 PM
What are you supposed to do... corksil Off-Topic 13 December 17th, 2013 01:13 AM
WTB: rust / hole free pregen gas tank CynicalC Items Wanted 9 April 15th, 2011 10:07 AM
When is your fan supposed to come on? 20ninja03 1986 - 2007 Ninja 250R Tech Talk 3 February 26th, 2011 01:37 PM
pregen airbox lid ckholloway Items Wanted 2 March 18th, 2010 01:04 PM
