Old September 7th, 2014, 10:29 AM   #1
Danger13Fox
Motorcycle(s): 2009 Ninja 250
Help! Bike won't go anywhere!!
Hey all, first off im pretty new to riding, only been going at it about 6 months and am not really up to speed on the mechanics portion yet. Now, to the issue. Last night after a long hard ride, i pulled off into a parking lot near my house. When i jumped on to go again, the bike didn't go anywhere! It shifts just fine, and will idle just fine, it will roll by itself in first gear, but with a little throttle does nothing. with a lot of throttle, does nothing. I am really confused. I will try to upload a video here shortly so you can see exactly what is going on. BTW this is on my 2009 ninja 250, about 3400 miles on it and have no issues before.
Danger13Fox is offline   Reply With Quote
Old September 7th, 2014, 10:42 AM   #2
Danger13Fox
this is the youtube link to the video, couldnt figure out how to embed it into the response.
Last futzed with by Alex; September 7th, 2014 at 01:16 PM. Reason: fixed video. Just put the video ID between youtube tags.
Old September 7th, 2014, 11:29 AM   #3
MrAtom
MOTM - July '15
That is so weird. I'm actually really interested in seeing what the problem is.
Old September 7th, 2014, 11:31 AM   #4
Danger13Fox
ya... i would really like to know, seeing as i cant go anywhere and was planning a ride to the tail of the dragon....
Old September 7th, 2014, 11:31 AM   #5
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Sounds like the clutch is bad.
Was there any issues before?
You could change the oil and look for debris, if the is some it could be a sign.
Old September 7th, 2014, 11:45 AM   #6
Danger13Fox
no issues before, she used to run like a champ, i am about to change the oil so ill post back if anything has changed or not. now, when i purchased the motorcycle from the dealership i got the GTPP extended warranty will that cover it if there is a clutch issue?
Old September 7th, 2014, 11:51 AM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Not sure, read all the fine print. But, I would think it would.
Old September 7th, 2014, 12:07 PM   #8
M42
Wrench wench
M42's Avatar
Motorcycle(s): TWO HUNDRED FORTY EIGHT CUBIC CENTIMETERS (R.I.P.), SIX HUNDRED FORTY FIVE CUBIC CENTIMETERS
Well, the throttle's revving up, so it's not that... something is amiss in the transmission probably.
M42 is offline   Reply With Quote
Old September 7th, 2014, 12:08 PM   #9
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
clutch ain't working right. Start with checking the cable at the lever and go down to the linkage on the case cover. If it checks out, some thing internal got FUBARED.
Old September 7th, 2014, 12:15 PM   #10
cuong-nutz
cuong-nutz's Avatar
What up! 13F, 13B here!
Do what Asspire said, check the cable and linkage first. it sounds like either your clutch pack is warn or the clutch isn't engaging fully and it's slipping A LOT.
HalfFast Racing Team
Old September 7th, 2014, 12:16 PM   #11
M42
Wrench wench
M42's Avatar
Actually, that reminds me - my bike did that when I pulled the clutch adjuster (on the handlebar) almost all the way out.
Old September 7th, 2014, 12:45 PM   #12
Danger13Fox
Just did oil change nothing funky came out. I did notice that the clutch lever feels like it has to go out all the way for it to engage so I'll check that now.
Old September 7th, 2014, 01:00 PM   #13
M42
Wrench wench
M42's Avatar
Yeah, sounds like the adjuster then. The farther you pull it out, the farther the bite point is. Screw it in a few mm.
Old September 7th, 2014, 01:20 PM   #14
Danger13Fox
OK just adjusted the clutch lever feels like it engages sooner. However, it feels like the plates are sticking somewhat. The bike does die now when I just let go of the clutch so that's an improve. But I'm still having the same issue of getting any response out of the bike. Out of the gate getting going again from the first clutch release feels good then it quickly goes down hill and I get nothing. I can get into second gear and then rock back on the throttle and nothing comes.
Old September 7th, 2014, 01:21 PM   #15
Danger13Fox
Originally Posted by cuong-nutz View Post
What up! 13F, 13B here.
Shout out!
Old September 7th, 2014, 03:21 PM   #16
cuong-nutz
cuong-nutz's Avatar
Go to the clutch cover and look at clutch shifter rod that the clutch cable connects too. You should be able move the rod a little back and forth which means the clutch packs are fully engaged. If it doesn't move and you notice that your cable line is taught which means that the outer cable housing adjuster is too tight. Loosen the locknut at the clutch cover housing some to release the tension so the clutch pack can engage. You might have to adjust the adjuster out at the clutch lever for it to give you some wiggle room.
Old September 7th, 2014, 03:41 PM   #17
Danger13Fox
ok since i'm totally bike mechanic illiterate ill just say what i did then you can maybe bring to latence terms for me. I adjusted the locknut up by the handle bar, and made it shorter (brought the cable closer to the clutch lever) and that seemed to give the clutch more life. Are you talking about adjusting the clutch cable down by the motor where the oil goes in?
Old September 7th, 2014, 03:54 PM   #18
cuong-nutz
cuong-nutz's Avatar
Yes sir
Old September 7th, 2014, 04:07 PM   #19
Danger13Fox
ok so the clutch cable does move back in forth down at the bottom and isnt taught at all.
Old September 7th, 2014, 07:29 PM   #20
Sure seems like there is an issue with the clutch to me as well. It's possible the friction plates are worn excessively or something broke. It's also possible that the previous owner used automotive oil with Friction Modifiers that build-up on the clutch plates and caused them to slip. All of that is kinda rare on a 250cc cycle with 3400 miles.
Maybe the previous owner consistently slipped the clutch excessively while learning. What does the oil look like? Is it dark and does it have a burned smell?
Chances are the warranty doesn't cover "normal wear items" like the clutch, brake pads, tires, etc.
Do you have free-play between the lever and the mount (as cuong noted)? Here's info on adjusting the cable - http://faq.ninja250.org/wiki/Adjusting_the_clutch_cable
Old September 7th, 2014, 08:03 PM   #21
Danger13Fox
I did the oil change today and it didn't smell burnt or anything like that. It was dark but that's probably my neglect I haven't changed it since I put about 600 miles on it. I don't know what type oil was previously used. I know I just topped her off with the rotela diesel oil. Is it possible the clutch just took a crap? And any insight on how much it would cost to repair?
Old September 7th, 2014, 08:36 PM   #22
Danger13Fox
Just wondering could this issue of stemmed from it sitting for long periods of time? The previous owner bought it new in 2009 and over 5 years only put 2500 is miles on it. Could it of caused a minor issue that just imploded on my face?
Old September 7th, 2014, 08:47 PM   #23
M42
Wrench wench
M42's Avatar
No, clutch doesn't deteriorate with time, only with use (improper use at that).
Old September 7th, 2014, 09:12 PM   #24
Flying
Motorcycle(s): 2010 Ninja 250
Check and adjust the cable and linkage again from bottom to top, except give yourself 1mm of free-play at the lever (instead of the recommended 2-3mm) and see what happens:
You said your oil didn't look or smell funky, it's probably normal. Don't worry about the blackness, that's normal as well.
Idea: We all agree the problem LOOKS like a typical slipping clutch. I'm assuming that your clutch cable was improperly adjusted from the start and put excessive wear on your clutch plates. Several thousand miles later the plates are just at the limit of slipping, you come back from a ride, things cool and shrink, suddenly next morning you have a clutch that won't engage and is continually getting worse as it slips. Again, this is all of my speculation.
No way to actually know without doing another oil change and visually inspecting the plates. Bring it to a dealer or shop if the cable adjustment doesn't do the job.
Old September 8th, 2014, 04:46 AM   #25
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Old September 8th, 2014, 03:46 PM   #26
Danger13Fox
Soo... We can all probably agree that its the slippage issue. From here if I've tried to adjust the clutch at both ends with little success, then should I be looking at replacing the plates? And if so, anyone know exactly what parts I should order or is it best just to but the puppy open and check her out?
Old September 9th, 2014, 05:02 AM   #27
Flying
If you want to do it yourself:
Go to the dealer or any of the wholesale parts sites for part #11009-1872 (GASKET, CLUTCH COVER)
Buy more oil.
Read this multiple times, execute.
https://www.ninjette.org/forums/showthread.php?t=25301
Replacement clutch friction discs: KG Powersports #KG252-5HPK
Replacement clutch steels: Barnett #401-35-078002
INSPECT ORIGINALS BEFORE ORDERING FRICTION/CLUTCH PLATES
Old September 11th, 2014, 03:29 AM   #28
Linkin
Down Under
Linkin's Avatar
Motorcycle(s): Kawasaki ZXR250C Ninja
Based on how my ninja sounds when you start releasing the clutch, your clutch is not fully engaging. Check the cable play/adjustment and lube the clutch line as well.
Linkin is offline   Reply With Quote
Old September 11th, 2014, 09:29 AM   #29
Danger13Fox
Thanks everyone for the help so far. I've been out of my house the past week and won't be able to get to my bike until Friday. But will try multiple things here.
Old September 11th, 2014, 06:07 PM   #30
Flying
Take pictures!
Bike Won't Start momoru 1986 - 2007 Ninja 250R Tech Talk 6 June 18th, 2014 08:34 AM
Bike won't rev Pretzel 1986 - 2007 Ninja 250R Tech Talk 5 December 24th, 2012 09:01 PM
Bike down...won't start Lurkable 2008 - 2012 Ninja 250R Tech Talk 17 November 23rd, 2009 02:49 PM
Bike won't start, help! demp 2008 - 2012 Ninja 250R Tech Talk 10 November 10th, 2009 01:45 PM
