Old June 14th, 2013, 10:58 AM   #1
t0sh
t0sh's Avatar
Motorcycle(s): 2007 Ninja 250r
dealership recommendation on parts
Hey peeps!
Haven't posted in awhile..
A few questions here:
Why would a dealership tell me that "I can't put any other NGK spark plugs in my bike other than CR8HSA?"
Reason I'm asking is because I researched some other threads, and there were some recommendations of:
CR8EK
CR8EIX
There was a recommendation here to "Not use CR8HSA":
http://www.ninjette.org/forums/showthread.php?t=61740
Why wouldn't I want to use that model?
Why couldn't I use something that will laster better/longer?
Toward the end of the call, he asked why I am inquiring about other plugs. Which I answered with my requests. He said he won't sell me the other plugs for my bike.
The other concern I have..
Air filters.
Some threads mention K&N or UNI
The dealership only carries the OEM. Again, why wouldn't I want to use something that will last better/longer.
Thanks for any replies.
I have a 2007.
t0sh is offline   Reply With Quote
Old June 14th, 2013, 11:09 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Originally Posted by t0sh View Post
Hey peeps!
CR8EK
CR8EIX
Air filters.
I have a 2007.
For the air filter, the OEM air filter actually filters the air. The K&N is high flow, meaning, more **** gets into the engine.
AFM #676
Supersports are for n00bs
Old June 14th, 2013, 11:50 AM   #3
t0sh
t0sh's Avatar
Kind of helpful, only not really.
Don't all air filters filter air?
Old June 14th, 2013, 11:58 AM   #4
dino74
dino74's Avatar
Check out
http://www.kawiforums.com/ninja-250r...tory-cr8e.html
CVMA #55
Old June 14th, 2013, 12:13 PM   #5
t0sh
t0sh's Avatar
Thank you! I appreciate that.
Old June 14th, 2013, 12:22 PM   #6
beren
beren's Avatar
Nope.
Shhhhh, don't tell Jiggles I am using the [ you ] tag.
beren is offline   Reply With Quote
Old June 14th, 2013, 12:24 PM   #7
dino74
dino74's Avatar
Air filters.
I'd just stick with the stock and follow the directions here.
http://faq.ninja250.org/wiki/How_do_...r_filter(s)%3F
I use a K/N for my track 250 for the better flow, I've never had issues with stuff getting into my carbs even though I ride in dust storms sometimes.
But on my street 250, I'm still using the stock foam. It works fine.
CVMA #55
Old June 14th, 2013, 12:40 PM   #8
t0sh
t0sh's Avatar
Thanks so much for the replies, Dino. Helps when people (such as myself) are learning about auto parts.
Old June 14th, 2013, 06:06 PM   #9
voidrider
Motorcycle(s): 1996 Kawasaki Ninja 250, 2000 Kawasaki Super Sherpa
I've run a K&N filter in my airbox for over 5 years. I have never had an issue.
I don't do a lot of dirt road riding (some forest service gravel roads occasionally).
Once a year I pull the lid off the airbox. The filter I have is nearly box-like and uses hose clamps to attach it to the Helmholtz resonators (the tubes that come down from the lid of the airbox). I clean the filter and re-oil it per the instructions and I am good to go.
Seems like the majority of the filtered debris I find is likely dust, but the numbers of insects can be pretty amazing.
Part Number KA-2586 if you are interested. I can't say Its really created any noticeable improvement, but there hasn't been any problems either.
voidrider is offline   Reply With Quote
Old June 14th, 2013, 06:46 PM   #10
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
Originally Posted by UltrA_09 View Post
The spark plugs that can be used on the 250 is either the NGK CR8E or the Nippon Denso U24ESR-N
Do not purchase the NGK #CR8HSA or Nippon Denso #U24FSR-U as listed on the wiki as that is reffering to the pre-2008 models.
You can use a 16mm plug wrench, or the wrench included in the tool kit; torque specs of 115 lb.
Here's a helpful video of how it's done:
http://www.youtube.com/watch?v=3POFTC_i_N4
I think he was telling that to some one with a 08 and newer bike
Old June 14th, 2013, 08:00 PM   #11
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yes, but some filters filter filterier than other filters
Filter
AFM #676
Old June 18th, 2013, 07:43 AM   #12
t0sh
t0sh's Avatar
Filter
Ok. lol. btw...gratz on your 300
heated grip - recommendation ? tac12345 2008 - 2012 Ninja 250R Farkles 7 November 4th, 2016 11:42 AM
Tire recommendation. Gregg_VA 2008 - 2012 Ninja 250R Tech Talk 26 January 17th, 2014 01:47 PM
headlight bulb recommendation eddiekay General Motorcycling Discussion 13 July 2nd, 2013 09:26 PM
Glove recommendation hirubhaiambani Motorcycle Gear 11 August 28th, 2012 04:52 PM
need recommendation on feeler gauges CThunder-blue 2008 - 2012 Ninja 250R Tech Talk 4 January 6th, 2011 11:27 AM
