Old August 30th, 2013, 06:19 PM   #1
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Wiring Kill switch after MP throttle, anyone?
So I bought a motion Pro throttle, and decided I needed a slimmer kill switch for the right clipon. Fortunately, MP sells this. Unfortunately, I'm not great at electrical. Haven't even started opening up wires yet, but thought I'd check if anyone has already done this mod yet. I used the search button, but no findy.
Thanx for any input.
Cheers,
Joel
JBinSD is offline   Reply With Quote
Old August 31st, 2013, 04:45 PM   #2
9lives
Motorcycle(s): Daytona 675
Here's a link Joel it's not a plug n play like I expected it to be.
http://www.youtube.com/watch?v=B9J8Fsd4sAY
9lives is offline   Reply With Quote
Old September 1st, 2013, 02:38 PM   #3
JBinSD
Thanx Walt, I watched those, and followed the directions all the way to the end, where it tells me to find the appropriate terminals to fit in the stock housing. . . Grr I went to 5 electronics stores looking for these little buggers, and got bupkiss.
If anyone knows where to get these, please let me know. Otherwise, I'll haveta hack my OEM harness and do some splicing. . . .
Old September 1st, 2013, 02:47 PM   #4
9lives
Get me a better picture of that connector that you're looking for Joel. In that picture it just looks like a spade connector.
Old September 1st, 2013, 03:17 PM   #5
JBinSD
Thanx Walt, its a small male crimp-on terminal that goes into a Molex-like 6 pin connector, per the MP instructions, I was supposed to remove the terminals from the male connector, cut off the crimps on the MP switch, find additional terminals and use those to put into the OEM male connector (green). It would probably be easier to just cut and splice the OEM line between the switch and connector, although I was hoping to find the terminals so I could keep both intact.
Old September 1st, 2013, 03:27 PM   #6
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
May not be what your looking for since I didn't use the connector but It couldn't hurt to have more picture.
pics toward the bottom
http://www.ninjette.org/forums/showthread.php?t=112922
Old September 1st, 2013, 03:44 PM   #7
JBinSD
Thanx Jason, did you bypass both connectors, or did you just splice the MP switch into the male connection harness, and use the OEM connectors? Thats probably where I am at this point, unless Walt can find me those particular crimp-on spade connectors. . . :-)
Old September 1st, 2013, 04:11 PM   #8
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
like in the pics in my thread I crimped all the wires(MP switch and Bike) with the supplied bullet connectors then heat shrinked it all when I was done. Finding the correct opposing connector so you wouldn't need to cut the bikes wiring harness would be the best way to do it but I didn't want to waste the time searching for it.
Old September 1st, 2013, 08:01 PM   #9
JBinSD
Gotcha, so you cut the harness on the bike and the MP switch, and just connected wire to wire, without any connectors? I guess thats one way to do it. . .
Old September 1st, 2013, 08:53 PM   #10
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I used the single wire individual connector that came in the kit, just look at the DIY part of that thread i linked to and you'll see what I mean.
Old September 2nd, 2013, 09:41 AM   #11
9lives
Okay that picture is pretty good Joel. You're going to have a hard time finding the correct mating pins. The easiest thing to do would be to replace both connectors with new 6 pin Molex connectors. If you were closer I could do it for you in about 10 minutes and I probably have the connectors and pins in the garage.
Old September 2nd, 2013, 12:44 PM   #12
JBinSD
Yeah, after checking Radio Shack, Fry's and Pep boys, I'm just going to re- wire the OEM harness. Thanks though :-)
Old September 2nd, 2013, 01:38 PM   #13
9lives
Do it the way I suggested Joel it'll keep it clean and simple. No splicing you really don't want to be doing that. Just looking for trouble down the road. If you want Joel just leave it alone and I'll do it for you at Chuckwalla.
Last futzed with by 9lives; September 2nd, 2013 at 02:45 PM.
Old September 2nd, 2013, 03:57 PM   #14
JBinSD
Thanks, but I spliced the MP line into the OEM line just after the connector, so I maintained the stock harness connector. Seems to be working just fine, but I appreciate the offer. Is it Round 1 yet?
Kickstand Kill switch - Inert omarcarbomb 1986 - 2007 Ninja 250R Tech Talk 10 March 13th, 2015 12:45 PM
Kill Switch Countersteer General Motorcycling Discussion 6 May 6th, 2012 12:55 AM
hidden kill switch? petiteninja 2008 - 2012 Ninja 250R Tech Talk 4 May 26th, 2010 04:09 PM
Engine Kill Switch won't kill .KiT 2008 - 2012 Ninja 250R Tech Talk 53 November 15th, 2009 11:43 AM
