#1 |
Fear the Beard
Idle Adjust location?????
The idle adjust is hangin loose, vibrating, and adjusting itself. kinda weird the first time u go from 1200 rpm at one stop light to 3k at the next.
it's on a bracket with 2 boltholes... WHERE DOES IT GO????? ![]() thanks yall.
Women and roads need curves. |
#2 |
its probably not actually moving the idle adjust... my money is on clogged jets or improper choking
#3 | |
Fear the Beard
the bracket it's mounted to will rotate with it hanging free, so maintaining an adjustment is impossible while riding. if i can figure out where to mount it i have a feeling it will solve this issue cause it wont be flopping back and forth against the engine case. i just bought this bike two weeks ago and i'm finding all the things that were done half-assed before i got it. but this isn't my first rodeo.
#4 |
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#5 |
note that photo is backwards. the screw normally faces the left-hand side. that diagram has the engine-side of the carb facing toward the viewer.
#6 | |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
Here another image showing the idle screw holder on the first gens ![]()
#7 |
Fear the Beard
Dino, you rock. Thanks!
#8 |
You probably know this already but put a little dap of blue Loctite on those screws to keep it from happening again.
#9 |
Fear the Beard
Ha!! The screws are still in the carbs!!! it was just reassembled without the bracket mounted cause i didn't know where it went. it was hangin' when i took the carbs off to soak (float bowls stuck...after PO let it sit up) so i let it continue to hang. figured i'd get it hung when i found out where to put it.
#10 | |
#11 |
Fear the Beard
i've been wrenching since phones had wires, and only lately have i started forgettin' stuff... i think i'm gettin' old too. i'm already high mileage!
Location, location, location | monjorrow | General Motorcycling Discussion | 12 | March 3rd, 2015 07:39 PM |
Idle issues - Idle is different every time I start up. | 106 | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 13th, 2014 04:57 PM |
How to Adjust Idle Speed | 2013 kawi girl | 2013 - 2017 Ninja 300 Tech Talk | 6 | October 23rd, 2012 07:02 AM |
Idle jumps to 9000 rpm on choke then wont stay idle after off | Shawn250 | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2012 06:45 AM |
Valve Adjust - whoa! Idle Speed? | bungie4 | 1986 - 2007 Ninja 250R Tech Talk | 23 | August 2nd, 2011 06:02 PM |
