Old December 13th, 2018, 09:49 PM   #1
drbninja
Motorcycle(s): 09 Ninja 250R
Ignition coil troubleshooting
So the service manual shows checking the resistances in the picture below.
but I can only get readings when I do it as shown below.
Am I doing it correctly? And if so, is the manual showing it wrong?
(I hope the pictures show.. im new to this)
drbninja is offline   Reply With Quote
Old December 13th, 2018, 11:08 PM   #2
no
no
what ranges are you setting meter to for each test?
Old December 13th, 2018, 11:42 PM   #3
drbninja
For primary winding its set to 200 and for secondary its at 20K.
Old December 13th, 2018, 11:43 PM   #4
drbninja
Its a bit confusing as the readings I am getting are in spec.
Old December 13th, 2018, 11:56 PM   #5
range for primary-winding measurement should be good.
If theses are within specs, then coil is good.
What's the problem you're trying to troubleshoot?
Do you have an oscilloscope?
Last futzed with by DannoXYZ; December 14th, 2018 at 10:26 PM. Reason: typo fixed
Old December 14th, 2018, 12:15 AM   #6
drbninja
Troubleshooting no spark. I only have a multimeter. Waiting for parts to build a peak voltage tester to complete testing pickup coil and ignition coil. Safety switchs shouldnt be an issue as it cranks and battery voltage is good as it is being supplemented by another bike. I wish I had another cdi box to swap, but if everything else looks good I'll probably just buy a new one.
Old December 14th, 2018, 02:01 AM   #7
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
why dont you put stick coils on? it's easy and painless
https://www.ninjette.org/forums/showthread.php?t=241339
https://www.ninjette.org/forums/show...9&postcount=62
"trying not to get old"
Old December 14th, 2018, 06:39 AM   #8
range for primary-winding measurement should be higher than 3.2k.
That must be a typo.
Daniel, the manual is showing that the secondary winding is grounded to the iron of the coil. It's also showing the wrong way to measure the primary, so yes it appears the diagram is incorrect. My "base manual" for the pregens shows the measurement of the primary correctly, like your photo.
You're saying your coil secondary is not connected to the coil iron, so I don't know why there's a discrepancy. Many coils are made like the one you have, so it's possible that various batches that Kawasaki bought are not all the same, or it's possible the diagram is wrong there too.
If you're reading 2.6 ohms for the primary resistance and 13.8k (13,800) for the secondary, it's not showing a problem. The coil may still be bad and not showing that with resistance readings, but by this test method the coil seems to be OK.
If I had a spare coil I'd check it to see if it's like yours, with the secondary not connected to the iron, but I'm sorry I don't. Maybe check your other one and see if it's the same.
Old December 14th, 2018, 10:12 PM   #9
Tell us more on history of this bike and this problem. Also read this thread:
https://www.ninjette.org/forums/showthread.php?t=300809
Any one of following can cause no spark (not inclusive, there are others):
- fusebox and fuses
- wiring between fusebox to ignition box
- ignition switch
- plugs
- plug wires
- wiring between ignition switch to ignition box
- wiring between ignition switch to coils
- wiring between ignition box to coils
- crank-triggers
- crank-trigger pickups
- crank-trigger wiring and connectors to ignition box
- ignition coils
- ignition box itself
Without testing each of these stages (follow the electrons), you might as well replace ALL parts above
Cheapo USB pocket-scope and 'noid light are better tools to use in this case.
Easiest to start at end and work backwards:
1. Plugs, test on other bike that runs
2. Plug wires, measure resistance end-to-end
3. Coil, measure resistance primary, secondary. Manually trigger spark test. Chances of both coils going bad simultaneously is extremely rare, pretty much impossible.
4. Measure for +12v at ignition coil
5. Use noid-light to test for grounding pulses at coil
6. Test for grounding pulses at ignition box
7. Measure for +12v at ignition box
8. Measure for ground at ignition box
9. Measure diodes
10. Measure stop switch (this is culprit lots of times)
11. Pull out ignition and main fuses to measure resistance across their legs
12. Measure resistance of wiring segments end-to-end
13. Measure impedance of pickup-coil
14. etc.
As quick test, ground green/black wire from ignition box and see if it runs
Last futzed with by DannoXYZ; December 15th, 2018 at 09:22 AM.
Old January 30th, 2019, 11:02 AM   #10
drbninja
Thank you to everyone for your suggestions and sorry for the delay, ive been a bit busy. i made a noid light and peak voltage tester. swapped coils/wires/plugs to another bike. everything kept testing good so i decided to get a icm/cdi box. they are like 80 bucks used on ebay so i got an 07 for 20 bucks. attached it using female blade connectors on the box side and single strand 20 gauge wire on the quick disconnect side. i didnt wanna cut the harness. it started right up and ive been riding it for two weeks now trying to see if the problem comes back. it seems to have fixed the problem. on a side note all the safety features (kickstand killing bike/kill switch/etc) still work. some ppl seemed to have problems when swapping boxes. redlines also a bit higher but of course there it doesnt make any more power up that high. i used to two threads below if anyone is interested. thanks again for everyones suggestions.
https://www.ninjette.org/forums/showthread.php?t=254632
https://www.ninjette.org/forums/showthread.php?t=26765
Old January 31st, 2019, 03:11 AM   #11
Awesome work!!!
Kawasaki ZX Ignition Coil Pack/ coil over plugs (CoPs) modification. Ghostt 1986 - 2007 Ninja 250R Tech Talk 44 June 10th, 2019 03:48 PM
Ignition Coil outside of specs MCPhotographer 1986 - 2007 Ninja 250R Tech Talk 5 May 9th, 2018 11:08 PM
Ignition coil cylinder 1 calcined ... Reason ? XacTiu 2008 - 2012 Ninja 250R Tech Talk 6 August 28th, 2015 06:42 PM
Ignition coil shorting? The_big_dill General Motorcycling Discussion 1 April 11th, 2015 09:54 PM
Ignition coil wire leads headshrink 2008 - 2012 Ninja 250R Tech Talk 7 June 25th, 2014 05:59 PM
