October 18th, 2010, 02:00 PM | #1 |
Join Date: Oct 2010 Motorcycle(s): currently: Yamaha YZF 250 dirt/motard Posts: 787
Crack or Roll?
Once you enter a corner what do you do with the gas? Crack it on, roll it on, hold it neutral, maintenance throttle, wait for the apex to roll on? How does this affect the stability of the bike?
Misti
"Leap and the net will appear!" superbikeschool.com www.motomom.ca |
October 18th, 2010, 02:11 PM | #2 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
Are we talking on track or on road?
Road: roll on at about the apex Track: Faster "roll on", almost a crack, at the point that I start to turn in at The bike is designed to be weight proportioned during acceleration, so during acceleration the bike is at its' most stable. |
October 18th, 2010, 02:48 PM | #3 |
Join Date: Jul 2010 Motorcycle(s): 2010 Ninja 250R Posts: 306
October 18th, 2010, 03:16 PM | #4 |
Twist of the Wrist II, Read the book, buy the dvd, learn!
Throttle Control Rule #1 Once the throttle is cracked open, it is rolled on evenly, smoothly, and constantly through out the remainder of the turn. Teaser: http://www.youtube.com/watch?v=XAeFrk7CU_w |
October 18th, 2010, 03:28 PM | #5 | |
October 18th, 2010, 03:35 PM | #6 |
Nope. Just putting my 2c in on the question at hand! Plenty of guests browse the forums for advice, someone can learn a thing or two from reading the book.
After you mentioned it, I did see she is an all-star rider that is quizzing the forum? |
October 18th, 2010, 08:57 PM | #7 |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
I ride mostly on busy streets....so my answer is: it depends.
If it's a corner I'm taking slow due to traffic, debris, or because I have to stop almost immediately after the turn, I'll ride the turn with steady maintenance throttle and let the turn slow me down naturally. Any other time I'm rolling on, either slowly throughout, or progressively more aggressive depending on how froggy I'm feeling that day. The bike seems to like it best when I'm accelerating through the turn. The harder the better. Mind you my turning skill sucks, so accelerating "hard" for me isn't saying much. |
October 18th, 2010, 09:26 PM | #8 |
Mr. 988
I'll take a crack at it . Start to sneak the throttle on as you apex the a turn and start to lift the bike up. Roll on throttle progressively from that point. One thing for sure, if you chop the throttle, after the apex, you destabilize the bike by overloading the front wheel and unloading the rear. Throttle picks up the chassis slightly and balances the bike between the front and rear.
Close? Jeff
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix Cancer |
October 19th, 2010, 04:59 AM | #9 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Roll on smoothly as soon as possible in the corner. This is of most importance when lean angle is greatest and on or near the edge of traction, but is a good habit to develop even when not.
The bike is much more stable while on the throttle. I typically start a slow, smooth roll-on as soon as my lean is set and really open it up when I can gauge and see through the corner. Well? B+ answer?
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
October 19th, 2010, 05:28 AM | #10 |
I never crack the throttle unless I am going in a strait line and trying to get around traffic. During a turn, it's always a roll, usually starting somewhere after the apex, with the maintenance throttle before. But on the streets, I try to avoid being so close to the limits that a little throttle manipulation ("is that grass on the road up there? better slow down a bit and get the bike more upright") won't put me on my butt.
And sneaky sneaky, Misti . |
October 19th, 2010, 05:30 AM | #11 |
On our 250? Hold it at 100% like the rest of the lap.
October 19th, 2010, 06:27 AM | #12 |
Smooth in the groove, crack will put me on my back. Seriously on the 600 (street riding) I find it really feels stable and likes a smooth roll on just prior to the apex. Possibly because I am braking extra hard entering the turn (the ABS makes it so easy to grab a ton of brakes prior to turning in).
Putting it back to you Misti, since Keith Code has determined the S1000RR the best training bike ever, do you see riders now coming into corners much faster and then braking much harder than they would due to the ABS? Also do you see them getting on the gas sooner and harder due to the traction control on those bikes? |
October 19th, 2010, 07:57 AM | #13 | |
Mr. 988
October 19th, 2010, 10:38 AM | #14 |
Only two choices? I'm usually still on the brakes as I enter a corner.
October 19th, 2010, 10:53 AM | #15 |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
Usually I set my speed and gear just before entering a turn so I am at my entry speed when I start my turn. Push the right bar as I enter (talking about a right turn) to start my lean and and give a tad bit of throttle to maintain. As I enter the apex of the turn I start to roll on the throttle so as I come out if the apex I am in re powerband start to straighten up as I gas it. I can't say I remember backing off the throttle on any turn and if I end up comming in to hot I just nut up push the bar a bit more and hold the turn and trust the bike will hold. If I come in so omfg going to crash into the side of the mountain as I hit a turn I keep the bike straight emergency slow/stop tecnique then gas and start my turn a bit late.
I am not sure if I am doing it right though so please offer feedback. I like this misti perso. Like our own private tutor! Last futzed with by Havok; October 19th, 2010 at 11:02 AM. Reason: Added stuff |
October 19th, 2010, 04:45 PM | #16 | |
Mr. 988
-has skills. Hope she sticks around.
October 19th, 2010, 04:58 PM | #17 |
October 19th, 2010, 07:16 PM | #18 |
October 19th, 2010, 07:25 PM | #19 |
Internet Slut
October 20th, 2010, 08:52 PM | #20 | |
I agree that during acceleration the bike is at its most stable. A lot of people have said that the bike feels more stable when they are rolling on the gas and that being twitchy with the throttle or rolling it off mid corner will make the bike feel unstable. As you said it has to do with the weight proportion. When you roll on the gas you are transferring some of the weight off the front and moving it towards the back. This puts the bike in the sweet spot so the suspension can work more effectively. With this being said, wouldn't the goal always be to get the bike to be stable as soon as possible? What would be the reason why you would wait for the apex to roll on the gas when riding on the road? Wouldn't you want the bike to be stable as soon as you turn in? Misti
October 20th, 2010, 09:14 PM | #21 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
I can think of one reason you don't want the bike "stable" in a corner on the road. Assuming that a road rider is staying safe and at reasonable speeds on the road, once you're locked into a turn at full-tilt, like on the track, the ability to change the bike's direction significantly is diminished. Too little traction available.
However, on the street, rarely should one be this locked and committed to a corner, simply for the sake that one would be grossly illegal. The other reason why I say the bike should be slightly "unstable" on the street, is so that the turn can be changed as is needed, to miss a pothole, to miss a car, well, I guess, to miss any hazard that might be in the road, sand, etc, etc. Having a more unstable bike, in my mind anyway, means having a more maneuverable bike, and that's kind of important on the road. Thus, once one is at the Apex, and can see that the exit is clear and safe, one can then completely commit to that corner by rolling on the throttle as fast as you feel the rear tire will hold. What say you Misti?
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
October 20th, 2010, 09:15 PM | #22 | ||
That being said, I'm sure that the ABS inspires more confidence in the braking and students may feel more comfortable trying to go into a corner faster and braking harder. However, at the school several our sessions start out with NO BRAKING and light brakes so there is more emphasis on gauging correct entry speed and working on other skills, like throttle control. Similarly, I'm sure that the traction control gives students more confidence when learning to roll on the gas and they may feel more comfortable rolling on harder than if they were on a different bike. But we do want the students to be smooth with their entries and with rolling on the gas so we would be on the look out for ones that are "charging" the turns and coming in too fast, braking too hard, being late with getting back on the gas and with trying to make up for lost time by hammering back on the throttle. Did that answer the question? Cheers! Misti
October 20th, 2010, 09:19 PM | #23 | |
I think there is a misunderstanding of HOW MUCH throttle it takes to make a stable bike. We are not talking about rolling on the gas so hard or so much that you are hauling ass through the corner, we are just talking about enough of a roll on to put the suspension in the correct range. How much roll on do you need in order to get your bike "stable?" Misti
October 20th, 2010, 09:21 PM | #24 | ||
October 21st, 2010, 05:22 AM | #25 | |
Ninja chick
October 21st, 2010, 06:01 AM | #26 | |
Thanks, I think so. I kind of equate it to my driving a car with ABS all these years, but starting on a car wtih 4 wheel DRUM brakes, I could still jump in a non ABS car and stop safely in different conditions. On the other hand my daughter has never driven a non ABS car would be in for a surprise stopping quickly in the rain or sand. |
October 21st, 2010, 06:42 AM | #27 | |
MOTM - Oct '15
October 21st, 2010, 07:31 AM | #28 |
Resident Old Guy
October 21st, 2010, 07:37 AM | #29 |
Mr. 988
I believe what Misti is getting at is that you should be using the brakes or the throttle all the time. It is a dynamic thing, this motorcycle riding, no?
Of course, each situation, track or street places different demands on the rider. But either way it is all the same. Get all your braking done then crack, sneak, roll, or tickle that throttle to keep the bike stable. Adjust as you go. It is that transition to throttle from brake that separates the women from the girls, so to speak. In Nick Ienatsch's book, Sport Riding Techniques, Nick talks about how the fastest riders in the world have the slowest hands and the ability to just make the tiniest movements of the throttle to adjust bike speed and stability. He mentions imagining stretching the throttle cable a tiny bit or visualizing the opening of the throttle bodies a hair to get a picture of the small amount of throttle control that is used. Misti is saying get on that throttle right away after slowing down, even it it is just a whisker of twist.
October 21st, 2010, 07:53 AM | #30 |
Internet Slut
Let me ask this, let's say my entry speed for a turn is 45 mph and I roll the throttle at the apex of the turn, would it be better to enter the turn a bit slower but rather then maintenance throttle I stay on the gas a bit as I go through increasing how much gas I give it as I go through the turn, would my exit speed be faster with a more stable bike and end up going through the turn faster?
October 21st, 2010, 08:12 AM | #31 |
I think part of the reason you want to get on the throttle early is so that everything remains nice and taught (ie: the throttle cable and chain). I find that when I'm being lazy with the throttle and turning, that getting on the throttle is much more difficult because I have to take up all the slack in the throttle cable AND the chain....this results in a moment where I'm slowly turning the throttle and nothing's happening, then THWACK, the chain slack has been taken up and the bike starts accelerating again.
Having that happen mid turn sucks |
October 21st, 2010, 08:34 AM | #32 | |
Internet Slut
Don't get me wrong I am not worrie about speed right now I am more concerned with my technique then any thing. I figure speed will come naturally any way. I adke questions from all sides as it helps me understand better |
October 21st, 2010, 08:41 AM | #33 | |
Mr. 988
October 21st, 2010, 08:47 AM | #34 | |
Internet Slut
October 21st, 2010, 10:23 AM | #35 |
Don't forget that as you lean the bike over, the rolling diameter of the tires gets smaller, which will slow the bike down. So that little bit of throttle is needed just to maintain the entry speed you selected as you entered the corner.
This is covered in Sport Riding Techniques (Nick Ienatsch) or Proficient Motorcycling (David Hough)... I can't remember which... probably both.
Kevin 2009 Ninja 250R |
October 21st, 2010, 10:27 AM | #36 |
Mr. 988
David Hough covers it quite extensivly. Two really good books to read BTW.
October 21st, 2010, 10:40 AM | #37 | |
Internet Slut
October 25th, 2010, 02:04 PM | #38 | |
He also explains, " Averaging 1.0 mph faster (60mph vs 59mph) through one short turn gives you 3/100's of a second improvement in lap time or puts you about 2.6 feet ahead of a competitor traveling 1.0 mph slower than you; that's about 1/3 bike-length." (there is more to this paragraph but I don't have time to type it all out So yes, overall you should have a faster exit speed with a more stable bike. We often have our students work on slowing down their entry speed a bit so that they are able to get on the gas much earlier in the turn. Once they feel how much better the bike handles we get them to slowly work on increasing their entry speed so they they end up entering at the same speed that they were before but getting on the gas ASAP once the bike is turned instead of waiting until the apex. Hope that helps! Misti
October 25th, 2010, 02:06 PM | #39 | ||
Misti
October 25th, 2010, 03:59 PM | #40 |
Internet Slut
I think and I am just winging it here it would be after the lean is set and at the angle as speeding up the back tire as you are changing how much rubber is being applied to the road could cause the back tire to slip and low side? I right? Do I get a cookie or the dunce hat?
You guys on crack? | duggram | General Motorcycling Discussion | 41 | May 15th, 2014 01:38 PM |
sidewall crack | Cringer | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 21st, 2012 09:31 PM |
Grinding The Crack | csmith12 | Off-Topic | 5 | January 23rd, 2012 09:00 PM |
What If you ride into a Crack! | ScorpionNinja | Riding Skills | 10 | May 23rd, 2010 10:54 AM |
crack on fairing | lilninja | General Motorcycling Discussion | 9 | April 11th, 2010 08:42 PM |
