August 29th, 2012, 03:11 PM | #1 |
Join Date: Nov 2011 Motorcycle(s): 2007 BMW F800S; 2012 Ninja 250; 2013 Moto Guzzi V7 Stone, 2016 Triumph Street Triple Rx; 1996 Ducati 900 SS CR Posts: 77
Ninjette: Horsepower and Speed
Was fooling around with an online horsepower/drag calculator, which I found very helpful in explaining the real world experience of riding the 250. I'm sure this is well known to the engineer types.
Based on my assumed variables, I get the following horsepower requirements for these speeds: 60 mph only requires 10 horsepower (30% of max) 65 takes 12.5 HP (41%) 70 needs 15.4 HP (51%) 75 takes 18.7 HP (62%) 80 takes 21 HP (70%) 85 takes 26.8 HP (89%) 90 takes 30 HP. (100%) This is presumably why I find the "sweet spot" for cruising to be 60-65 mph--still lots of HP in reserve, great fuel economy. 70-75 is ok too, but the engine is definitely reaching its limit. But if you are running 70 mph and hit a sudden gust of 15 mph headwind, you will suddenly need to go from 50% of max power output to 90%! That's probably why cruising more than 75 seems like a strain to me, because it is often pretty windy where I ride. Also of interest. Assuming my inputs are correct, if it takes a full 30 HP to run 90 mph, it would take an additional 7 horsepower just to increase speed to 95 mph. So even if your performance mods get you a few extra HP, it gains you very little in terms of top speed. (I assumed a CD of .5 and 12 square feet of frontal area. If anyone has more accurate data, I'm interested in seeing it) |
August 29th, 2012, 03:40 PM | #2 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Out of curiosity how did you come up with the CD?
August 29th, 2012, 03:52 PM | #3 |
Jigglin' your Jiglets
MOTM - Apr '13
Cool stuff though your numbers are quite a bit off. A stock ninjette on a good day will do 26hp and I believe stock will make it to 100mph indicated (~95mph)
Also 100% hp occurs at only 1 specific point, the rest of the time your power is already limited. In case you want to play around with some more accurate numbers heres a 2fiddy dyno
August 29th, 2012, 04:39 PM | #4 |
For the CD I just used the low end of the suggested cd range for motorcycles. Seems like I read somewhere that the ninjette was pretty aerodynamic. Would be interested in knowing the actual figure.
August 29th, 2012, 05:38 PM | #6 |
Maybe in a full tuck? Idk I think I have to take a fluids course next year. I'll get back to you more on that then.
August 29th, 2012, 05:49 PM | #7 | |
The exponential relation is only natural. A Hayabusa needs 280 HP's to reach 220 mph http://www.schultzengineering.us/aero.htm A pretty accurate Cd can be calculated this way: http://en.wikipedia.org/wiki/Drag_coefficient For force, use power/speed.
August 29th, 2012, 06:09 PM | #8 |
I'm thinking my CD is probably too low, and the HP is too high at 30 for a stock bike. Guess you need to base the calculation on rear wheel HP, not at the crank.
August 29th, 2012, 06:10 PM | #9 |
MOTM - Apr '13
Yup
The applied force is generally the one that matters
August 29th, 2012, 08:21 PM | #10 |
not an actual panda
[faster and faster] - Triumph Castrol Rocket: 1000 horsepower, 640kph top speed | Ninjette Newsbot | Motorcycling News | 0 | September 6th, 2014 11:30 PM |
Turning Water into Horsepower | Motofool | General Motorcycling Discussion | 1 | June 10th, 2013 09:27 AM |
What is Torque and Horsepower? | Sungfooo | General Motorcycling Discussion | 105 | May 2nd, 2012 08:11 PM |
Loud, Cool, Horsepower Goodness | RaceBikeRentals | 2008 - 2012 Ninja 250R Tech Talk | 74 | July 5th, 2009 07:11 AM |
[SoupKast] - Episode 10, Free Horsepower | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2008 01:13 PM |
