February 11th, 2017, 09:45 PM | #1 |
Join Date: Feb 2017 Motorcycle(s): 2007 Kawasaki Ninja 650R Posts: 9
07 ninja 650R clutch issue
Hello. I figured I would plead for help. I just installed Pazzo Ebay replica shorts on both. Now my clutch is not working. I can go into first without clutching. When I squeeze lever bike is very difficult to free wheel. Works great in neutral. I cannot go up from there. I am new to working on a mc, but wanot to learn and do what I can myself. With being destitute and penniless, it helps.
Would anyone please be so kind to give me some advice? I was told to play with adjuster by lever, no good. Someone else said that I need to adjust cable on right as well, due to short levers not having the full stroke as the stock. ??? |
February 11th, 2017, 10:00 PM | #2 |
Welcome, Christopher !!!
Could you show us a picture of the new and old levers?
February 11th, 2017, 10:18 PM | #3 |
I am new to using this forum as of tonight. I tried adding pics, hopefully they load here. One is of stock lever, we'll one that was on it when I bought the bike, and the other is the cnc short lever
February 11th, 2017, 10:22 PM | #4 |
I think I got it. Here are 2 better ones
February 12th, 2017, 04:59 AM | #5 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
I know people who have had problems with Pazzo shorts on BMW’s they hit the bars long before they should not giving sufficient movement. I have the normal length Pazzo’s on my K13 without problem. I would say you wil have to change them back.
Steve
Some mistakes are too much fun to make only once. |
February 12th, 2017, 05:36 AM | #6 |
I did try that. I went down put original lever back on and the problem continues. I have no idea what happened
February 12th, 2017, 06:35 AM | #7 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
I would find where I needed to make the adjustment (since your stocks don't work right no more) I had to adjust my cable (top and bottom) just the other day for a similar problem
February 12th, 2017, 06:45 AM | #8 |
Thank you. Now gotta u tube how to adjust there. :-)
February 12th, 2017, 06:47 AM | #9 |
hope it helps
February 12th, 2017, 06:49 AM | #10 | |
Check that the sheath of the cable is all the way inside its pocket and that the lower lever is in the correct position.
February 12th, 2017, 06:58 AM | #11 |
Thank yall again. About to get back to it. Fingers crossed
February 12th, 2017, 08:01 AM | #12 |
You are welcome
