June 20th, 2018, 07:50 AM | #1 |
[RideApart] - 2019 Yamaha YZ250F New From the Ground Up
The little entry-level motocross is finally stepping into the 21st Century with technologies old and new Yamaha has been keeping busy lately. After introducing a brand-new YZ450F for 2018, the company is now giving its little brother a overhaul. Here’s what’s new for 2019 with the YZ250F. What’s new, you ask? Pretty much everything. The little off-roader has been fully redesigned. First big change is the now-electric starter; no need to kick it into life anymore. Welcome to 2018 little trooper. The aluminum beam frame is also brand new and features a new swingarm pivot as well new engine mounts that centralizes the weight and gravity center and provide additional rigidity. MORE YAMAHA GOODIES: Celebrating 20 Years of R1 at Suzuka 8 Hour The bodywork has shed some weight in the design process. Seat height has been lowered by up to 0.8 inch and ground clearance by 0.4 inch to increase maneuverability. Additional weight has also been trimmed in the wheels for a total wet weight of 234 pounds. Fuel capacity has been reduced to 1.6 gallons from 2.0. SECOND LIFE FOR YOUR DIRT BIKE ENGINE Guy Puts Dirt Bike Engine In Barbie Mustang, Becomes Legend New frame, new engine, ne configuration, new everything! The 2019 YZ250F is new from the ground up.The engine has been fully redesigned as well with a flight of updated components—cylinder head, piston, and cam profile—for optimized power available at a broader power band. Despite all the new parts, the engine’s specs remain the same: a single-cylinder, four-stroke, 250cc, liquid-cooled block teamed with a five-speed transmission and multi-plate wet clutch. ALSO NEW FOR 2019: Kawasaki Announces Fancy New KX450 for 2019 Just like on the YZ450F, the 250 is now offered with onboard WiFi to connect to the Power Tuner smartphone application, a first in the 250cc class. The app connects to the bike’s Communication Control Unit (CCU) and allows the rider to tune up to 16 settings on the motorcycle to finetune and personalize its performance. The handlebar height can also be adjusted in four different possible settings. The new 2019 Yamaha YZ250F is expected in dealers in June 2018. You can get yours in Team Yamaha’s blue-and-white racing colors or in white, both priced at $8,199. Source: Dirt Rider More from RideApart:
Click here for full story...
[RideApart] - 2019 KTM XC and XC-F Range First Look | Ninjette Newsbot | Motorcycling News | 0 | May 23rd, 2018 01:11 PM |
[motorcycle.com] - 2016 Yamaha YZ250F Review | Ninjette Newsbot | Motorcycling News | 0 | August 20th, 2015 12:30 PM |
[cyclenews.com] - First Ride: 2016 Yamaha YZ250F | Ninjette Newsbot | Motorcycling News | 0 | August 20th, 2015 02:10 AM |
[motorcycle.com] - 2014 Yamaha YZ250F First Ride | Ninjette Newsbot | Motorcycling News | 0 | August 10th, 2013 12:50 AM |
2006 Yamaha YZ250F | massacremasses | Motorcycle-related | 11 | February 19th, 2013 02:21 PM |
