#1 |
Join Date: Jan 2015 Motorcycle(s): 1999 Triumph Legend "Arwen", 2006 Ninja 650 "Matsuo Hotaru". 2010 Ninja 250 "Firefly" - sold. Posts: 338
Bar end mirrors
All I can see in my mirrors are my elbows. So, what bar end mirrors are people using around here? What works, what doesn't?
#2 |
Join Date: Aug 2014 Motorcycle(s): 2011 Ninja 250R Posts: 36
Wait... your supposed to be able to see something other than your elbows on a bike? I would be interested in some options also.
#3 |
On my Triumph I can also see my love handles
#4 | |
Certified looney toon
MOTM Jul '13, Jul '14
https://www.ninjette.org/forums/showthread.php?t=127686
![]() Hey Unregistered! The code [you] shows the username currently logged in. ![]() IBA # 56020 AMA # 521481 ![]() Hold yourself to the same rules you expect others to follow. |
#5 |
I changed out my mirrors,1989-2007 Kawasaki Ninja EX 250 BLACK SPORTBIKE MIRRORS conversion kit from eBay seller "i5motorcycle" got a little bit better, here's my wwrite up, https://www.ninjette.org/forums/blog.php?b=8350, then I installed a backup camera, problem solved. https://www.ninjette.org/forums/blog.php?b=8337
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#6 |
So nobody on this whole site installed bar end mirrors?
#7 |
If you look at the bottom of the page, you'll see similar threads.
Here's some: https://www.ninjette.org/forums/show...27&postcount=6 https://www.ninjette.org/forums/show...73&postcount=6 https://www.ninjette.org/forums/show...76&postcount=8 https://www.ninjette.org/forums/show...47&postcount=3 https://www.ninjette.org/forums/show...8&postcount=10
#8 |
Also check out the ones the Blue Collar Bobbers use on their cafe' racer kit, they slip on your existing bar ends. Cost is $49.00 USD
http://bluecollarbobbers.com/m/caferacer.html
#9 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
Bar ends
I have bar ends on my 250. I'll take some pics and post them tomorrow.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
#10 |
cadd cadd cadd
MOTM - May '15
I got the mirror extenders from eBay. They move the mirrors out about an inch or so. It's better than stock, but don't expect day and night improvement. But I'll take that little improvement.
#11 |
Join Date: Apr 2011 Motorcycle(s): 2002 Honda 919, 2004 Ninja 500R NAKED Posts: A lot.
Bar end mirrors are super cheap and work really well. My only beef with them on my 919 is they make my already wide handlebars a lot wider, but I've got one on my 500 too and it isn't an issue on it.
#12 | |
#13 |
MOTM - July '15
I don't have this problem. I just move my head a little if my elbow is in the way, but it usually isn't. I guess I just have lucky body dimensions.
#14 | |
Join Date: Jun 2013 Motorcycle(s): 2013 Kawasaki EX300 , 1999 Kawasaki ZRX1200. Posts: 164
Me too....
IBA # 59523 |
#15 |
Inline 4!!!
I also don't have this problem, I am short though so maybe that's it. 5'7
#16 |
I have bar ends. I got them, because I like the look of them better. I'm also 6'1 and wasn't seeing much out of the factory ones. They definitely helped.
Paint side up, rubber side down! |
#17 |
yeah, i am 6'1 as well. if i push the mirrors out to the limit, i can see some of the cars on the next lanes, but not behind me. so i ordered a cheap-ish set of mirrors on amazon, stay tuned, this will be my first mode of the Firefly.
#18 | |
color will be orange to match my 500, and accent color will be silver to match the 250.
#19 |
Removed the bar end weighs on the 99 Ninja 250 Cafe Racer project. Will keep them in case there's too much vibration and need to re-install them. If you keep the bar end weights, longer bolts can be used to install the SpeedMetal mirrors. Have two other bikes including a 2012 Ninja 650, with bar end mirrors installed this way without issues and can actually see behind the bike.
Ninja Cafe Racer project: ![]() ![]() |
#20 |
Got my mirrors, now to find time to put them on...
Screw the inscrutable, eff the ineffable. |
Bar end mirrors? | krapzed | General Motorcycling Discussion | 14 | May 31st, 2014 05:40 AM |
Best Bar End Mirrors? | Roca | 1986 - 2007 Ninja 250R Farkles | 4 | October 30th, 2013 05:24 PM |
Bar end mirrors | JoeLansing | 2008 - 2012 Ninja 250R Farkles | 18 | June 27th, 2011 06:28 AM |
Bar-end mirrors | Rayme | 2008 - 2012 Ninja 250R Farkles | 22 | May 23rd, 2011 11:16 AM |
Bar end Mirrors? | zartan | 2008 - 2012 Ninja 250R Farkles | 6 | December 18th, 2008 08:03 AM |
