Old October 25th, 2012, 07:50 AM   #41
How high do Steve's links raise the tail?
Go cheap on the front. Buy some washers. Add a couple mm of preload, and go with a slightly heavier fork oil. It will take you all of 30 minutes to have a slightly less suckish front end
Old October 25th, 2012, 07:51 AM   #42
I haven't measured, but they say it's about 1.5"
Old October 25th, 2012, 08:11 AM   #43
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
Why don't you just get the Woodcraft clipons with the risers?
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old October 25th, 2012, 09:01 AM   #44
^ that. Then just put the WC ones with risers as low as they'll go on the fork tubes.
Old October 25th, 2012, 09:07 AM   #45
I actually have those for my J-series. The question wasn't for anyone in particular. It was to determine if they would be necessary going forward or if low-cost generic 37mm clip-ons were feasible with the 300/L-series. I'm working on adapting the SV650 41mm clipons to the F-series' 36mm forks. The Woodcraft ones will probably bolt right on but the triple shape is such that they would have to bolt lower and, thus, would not clear even with the rise. The clamping portion of the SV650 ones is thin enough to mount on top, though I plan to thin them more so that they are flush with the rest of the triple clamp. From there, I plan to make an overlay that makes the triple look more like the J/K/L/300-series and makes the clip-ons appear to rise from underneath. It's all about cosmetics with this bike.
Old November 15th, 2012, 06:09 PM   #46
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
So can someone confirm the proper size clip ons for the 300? 37 mm, with risers?
JBinSD is offline   Reply With Quote
Old November 15th, 2012, 06:21 PM   #47
JBinSD
NM must be 37mm, but riser or not? Or do either work?
Old November 15th, 2012, 06:57 PM   #48
I looked at one today and it is clear that it need a riser if you do not lower the front and attach over the triple.
When were motorcycle controls standardized? Soujyu General Motorcycling Discussion 3 February 15th, 2014 04:04 PM
WTB pregen handlebar controls Kirin240 Items Wanted 0 June 12th, 2013 05:01 PM
FS: New-gen Aftermarket & OEM Parts (Integrated Light, FE, & controls) jp129 Motorcycle-related 27 November 13th, 2012 09:34 AM
Decent Aftermarket Left Handlebar Controls (Lights/Signals/Horn) indr 2008 - 2012 Ninja 250R Tech Talk 3 October 8th, 2012 05:31 PM
left hand controls 95 bike 05 controls mapolley07 1986 - 2007 Ninja 250R Tech Talk 12 December 22nd, 2011 10:05 AM
