Old May 1st, 2018, 12:40 PM   #1
David Ninja
Motorcycle(s): 2012 Kawasaki Ninja 250R
Angry 2012 Spark Plug Issue
Removed old spark plugs to replace with new ones. Now, one side is stripped, will not tighten, and is losing compression. Can anybody verify that i need a 10mm x 1.25 insert to rethread with Helicoil...or a better suggestion to fix? Should the head be removed or replaced or can i helicoil with head on? So stressed out.....
David Ninja is offline   Reply With Quote
Old May 1st, 2018, 01:08 PM   #2
Pretty sure it's 10x1mm. Helicoils aren't that strong. I recommend Time-serts 10mm plug repair
Old May 1st, 2018, 01:12 PM   #3
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
I always take the head off if I strip sparkplug threads (on various motors), some say it can be done with head on without getting drilling metal in the motor but I've found most times there isn't enough room to drill and tap with the head on, and you don't wonder how much metal fell into the cylinder. I don't even get a new head gasket unless it's bad, I paint it with copper or aluminum paint and put it together before the paint dries, I've yet to get a leaker doing this. (all surfaces cleaned well) I always take the head to a machine shop to have it repaired, never done the do it yourself kits.
and always put anti seize on the plug threads when you have an aluminum head!!!
Old May 1st, 2018, 01:16 PM   #4
And screw in the plugs by hand for at least 4-5 threads ...
Old May 1st, 2018, 01:17 PM   #5
David Ninja
Thank you Z1R Rider
Thank you.
Old May 1st, 2018, 01:25 PM   #6
David Ninja
Thank you DannoXYZ
Thanks
Old May 1st, 2018, 02:19 PM   #7
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
yup anti seize for sure
"trying not to get old"
Old May 1st, 2018, 04:44 PM   #8
David Ninja
Anti Seize
NGK does not recommended anti seize. Over torqueing can occur and cause thread damage.
Old May 1st, 2018, 05:12 PM   #9
Use anti-seize - and skip the torque wrench.
You just need to learn what "snug" is. 3/8" drive ratchet and don't grip it all the way at the end...
Old May 3rd, 2018, 07:12 AM   #10
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I keep typing why they put that warning, and why you should still use anti-seize; I also keep deleting it
Non aluminum parts going into aluminum should have anti-seize so close to always that I type always; but that's just my thoughts and training
Old May 3rd, 2018, 08:03 AM   #11
My friends at Lucas Aviation says every single bolt they use on planes has to have either lube/anti-seize or locking-compound and torque recorded. Never bare threads.
Spark Plug not sparking? PLEASE HELP nickk_pike 2008 - 2012 Ninja 250R Tech Talk 48 July 26th, 2019 04:20 PM
Spark Plug Colour OK ? GiGs 2008 - 2012 Ninja 250R Tech Talk 9 October 8th, 2010 02:11 AM
What is the best Spark Plug to buy? dive1tom 2008 - 2012 Ninja 250R Tech Talk 7 November 5th, 2009 09:44 AM
Spark plug reading Racer x 2008 - 2012 Ninja 250R Tech Talk 14 October 7th, 2009 07:53 PM
Spark plug wires diablo250 General Motorcycling Discussion 1 June 11th, 2009 05:23 AM
