Go Back   ninjette.org > Marketplace > Motorcycle-related
Closed Thread
Old June 15th, 2015, 06:54 PM   #1
garth285
KAWASAKI GURU
garth285's Avatar
Ninja 250 to Ninja 300 EFI Conversion Kit
Complete EFI conversion kit for the ninja 250
Will include:
Throttle bodies (secondary throttle plates removed) Also have multiple injectors to go with it (stock 250 or 300 or bigger)
Flywheel
ECU (can flash to any ECU Spec you want)
Main Harness (has 2 connections cut)
Regulator
Coils
Junction Box
MAP Sensor
Tip Over Sensor
Air Temp Sensor
Woolich Racing programming bench harness ($120 new) Will require program and Denso programmer
$550 OBO
garth285 is offline
Old July 2nd, 2015, 09:11 AM   #2
garth285
KAWASAKI GURU
garth285's Avatar
BUMP
garth285 is offline
Old July 2nd, 2015, 09:49 AM   #3
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
man, that's a heck of a deal! If only this was Oct or Nov...
spooph is offline
Old July 2nd, 2015, 10:10 AM   #4
greg737
Motorcycle(s): -
A "complete" EFI system would have to include a fuel pump.
What kind of fuel pump does this system use? Would you just substitute a fuel tank from an F.I. EX-250, so you get the in-tank fuel pump? Are the fuel tanks interchangeable between the later models of the EX-250?
greg737 is offline
Old July 2nd, 2015, 10:21 AM   #5
garth285
KAWASAKI GURU
garth285's Avatar
I was using an external walbro 255lph pump with a aeromotive 1:1 FPR
You can use the 250 FI tank and pump or if the ninja 300 tank will bolt up use that.
Plain and simple like every other standard EFI system you need a constant 44psi of fuel pressure.
garth285 is offline
Old July 2nd, 2015, 12:48 PM   #6
greg737
Motorcycle(s): -
I've done 2 fuel injection conversions: the first was on my 2005 EX-250 and the second is on my 1993 Suzuki GSF400 Bandit.
On both of these projects I used the Honda TRX500 Rancher four-wheeler fuel pump. It's a very good external fuel pump, and priced pretty cheap too.
greg737 is offline
Old July 16th, 2015, 06:07 PM   #7
garth285
KAWASAKI GURU
garth285's Avatar
BUMP, willing to make a killer deal
garth285 is offline
Old July 18th, 2015, 01:37 PM   #8
Hey, I hate to be OT, but I've not heard from you in a while since you started the project on your GSF. any walk-through's on your youtube channel or anywhere on the web I can follow for good reading material?
choneofakind is offline
Old July 18th, 2015, 03:01 PM   #9
greg737
Motorcycle(s): -
http://forums.banditalley.net/index.php?topic=13747.0
my build thread over at Bandit Alley.
greg737 is offline
Old July 29th, 2015, 10:51 AM   #10
garth285
KAWASAKI GURU
garth285's Avatar
SOLD
garth285 is offline
Closed Thread
Ninja 250/300 Turbo Kit garth285 Motorcycle-related 3 June 19th, 2015 10:04 AM
2002 Kawasaki Ninja 250 EFI (EcoTrons) lolibater Motorcycle-related 7 November 5th, 2013 06:27 PM
Ninja 250 Compressed Natural Gas Conversion nrninja 1986 - 2007 Ninja 250R Tech Talk 43 November 1st, 2013 08:59 AM
Ecotrons EFI for ninja 250 (GROUP BUY) ninja_thresh_hold Motorcycle-related 101 March 4th, 2013 05:45 PM
Group Buy: EFI (Fuel Injection) Conversion Kit Jiggles Motorcycle-related 874 November 30th, 2012 04:54 AM
