Old July 2nd, 2013, 06:43 PM   #1
ChickenRun
ChickenRun's Avatar
Motorcycle(s): 2010 250r SE (without stupid tribal decals)
Interesting fuse problem
I've got an interesting fuse problem that I can't figure out. I've been through 5 10a fuses in two days, where at first the fuse would work but after a mile down the road it blows. To fix this I electrical taped all the open wires under seat, but now I have a weird problem: If I turn the bike on but not the engine and hit the signal switch, the fuse blows instantly. But If I turn the bike on AND the engine then hit the signal switch the fuse works but only for one side (if I change to the other side it blows). I'm stumped.
ChickenRun is offline   Reply With Quote
Old July 2nd, 2013, 06:47 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Your bikes totaled, just go buy another one
Old July 2nd, 2013, 06:52 PM   #3
ChickenRun
ChickenRun's Avatar
lol please god no I just got it 4 months ago
Old July 2nd, 2013, 06:59 PM   #4
Dano
Dano's Avatar
Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919
forget about it go buy a R6!
as with all electrical problems you are going to have to investigate. it might be as simple as 1 wire has the insulation rubbed off and the bare wire is hitting metal somewhere. good luck electrical probs suck
Dano is offline   Reply With Quote
Old July 2nd, 2013, 07:07 PM   #5
ChickenRun
ChickenRun's Avatar
If I get a 600 it will be a blue 06 ZX6R them thangs are beautiful.
Well is there any specific area where shorts are more frequent? I was surprised the first time I took the seat off to install a new relay how many wires weren't protected.
Old July 2nd, 2013, 07:16 PM   #6
tc.young
Motorcycle(s): '89 klr 650, '00 250r
buy a 50a fuse!
if it blows with ignition on (shouldn't matter if engine's running) then it's a short before the switch (the one you use to indicate signal), could either be between power to turn relay or from turn relay to switch.
if it only happens when you signal, then it appears it would be from green which controls the left signal or gray which controls the right. looks like black/yellow is ground.
tc.young is offline   Reply With Quote
Old July 2nd, 2013, 07:26 PM   #7
Trailerboy531
Gear crash test dummy
Trailerboy531's Avatar
Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r
Yeah but they have terrible fuse problems
CVMA #531
Trailerboy531 is offline   Reply With Quote
Old July 2nd, 2013, 07:37 PM   #8
ChickenRun
ChickenRun's Avatar
Originally Posted by tc.young View Post
buy a 50a fuse!
50a? I wouldn't call myself electrically competent but that sounds like a little too much. Since the fuse only blows when I signal, what can I do about those grey and green wires? I've already coved the whole bundle of wires connecting to the box.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Old July 3rd, 2013, 11:14 AM   #9
ChickenRun
ChickenRun's Avatar
bump
So a larger fuse would fix my problem? 15a maybe? I wanna make sure before I accidentally set my baby on fire.
Old July 3rd, 2013, 12:50 PM   #10
indr
Probably won't. But try it. Instead of popping the fuse, it might fry the load.
indr is offline   Reply With Quote
Old July 5th, 2013, 07:19 AM   #11
agent of orange
Motorcycle(s): gsf1200, gsxr750, r6, gpz400, gpx400r, zx6d
instead of poping the fuse you will melt the harness.. maybe. with a dead short any fuse size should pop though. bigger fuse is not a solution. check the harness where the signals are back into the harness.
agent of orange is offline   Reply With Quote
Old July 5th, 2013, 02:06 PM   #12
ChickenRun
ChickenRun's Avatar
Problem Solved
So after being so frustrated at my bike that I had called it every name in the book I took a seat next to it and found that the ground wire was sticking out *just* enough to touch the metal that it was grounded to. Too bad I found out AFTER blowing 7 fuses through trial and error.
Old July 5th, 2013, 03:18 PM   #13
xorbe
xorbe's Avatar
7 fuses is better than setting your bike on fire and possibly house if it was parked in the garage!!!
Old July 5th, 2013, 04:27 PM   #14
Whiskey
A bit late, but if you're going to investigate an electrical issue getting hold of a mini circuit breaker can save you using a **** load of fuses
Old July 5th, 2013, 07:08 PM   #15
agent of orange
if its a ground it shouldnt matter that a strand is touching the frame.
Old July 7th, 2013, 02:29 PM   #16
ChickenRun
ChickenRun's Avatar
Well I tapped it up anyway just to be sure and the fuse hasn't blown yet, but still every time I hit the signal switch my heart stops in anticipation.
Old July 10th, 2013, 02:27 PM   #17
ChickenRun
ChickenRun's Avatar
GOD. DAMMIT. IT BLEW AGAIN AND THEY KEEP BLOWING WHEN I HIT THE SWITCH. I've evaluated and covered EVERY wire under the seat and behind the fairings. I give up. It's going to the shop, even though I never wanted it to come to this.
Old July 10th, 2013, 03:03 PM   #18
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Just hardwire it without a fuse and wait for the problem to start smoking then bam you fix whatever's on fire
Old July 10th, 2013, 03:29 PM   #19
Lychee
sail away
Lychee's Avatar
That sucks man, electrical problems are really tough to fix. Many times you need to test and eliminate each part of the circuit one by one, including the switch and light fixtures.
Old July 10th, 2013, 03:45 PM   #20
xorbe
xorbe's Avatar
Since the fuse seems to repeatably burn out when the engine is off + turn signal, in the hands of an experienced person, it shouldn't take long to pin-point.
Old July 10th, 2013, 04:49 PM   #21
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
what is your battery voltage at?
Old July 10th, 2013, 06:03 PM   #22
ChickenRun
ChickenRun's Avatar
lol at rojo, and I'm not sure what my battery voltage is. The previous owner didn't touch the bike customization wise, so I guess it's whatever voltage stock is supposed to be. I'm gonna give it three days and if I can't accidentally fix it by then then I'm letting the professionals have at it.
Old July 10th, 2013, 06:14 PM   #23
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Sounds like it is somewhere between the switch (if not the switch itself) and the turn signals.
baxtc1 is offline   Reply With Quote
Old July 11th, 2013, 03:42 PM   #24
ChickenRun
ChickenRun's Avatar
Fixed it...again...I think.
In one last attempt at solving this issue I tore all fairings off and UN-tapped every wire that I did my myself so that I could re-tape them. What I found was that the two turn signal wires (green one and yellow/black one) were touching each other UNDER the tape. After I fixed those I checked all the other turn signal wires to make sure they weren't getting jiggy with each other. Turned my baby on and she works once again.
Too bad I can't go for a celebration ride though, it's thundering here in Fleming Island.
Old July 11th, 2013, 04:40 PM   #25
baxtc1
baxtc1's Avatar
Excellent, good to hear. Rechecking can sometimes pay off. Bugger the weather, go for a ride anyway.
Old July 11th, 2013, 10:22 PM   #26
xorbe
xorbe's Avatar
Great job!!! +5 DIY
Old July 17th, 2013, 07:46 AM   #27
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Glad you figured it out..... might want to take a note and stopp electrical taping the wiring harness on the bike.... get some shrink wrap and a bic.... or even invest in a crimper and some male female ends....
electrical tape electrical modds are often bad buisness!
unreliable in the wet weather and prone to shorts.
get some dielectric grease too and lub up every connection you decide to mess with..
Blown fuse. Then another. mrudich 1986 - 2007 Ninja 250R Tech Talk 34 July 30th, 2020 08:26 AM
Headlight out/fuse blown... tsdexter 2008 - 2012 Ninja 250R Tech Talk 4 June 18th, 2013 12:43 PM
Keep blowing headlight fuse! Hexdex 2008 - 2012 Ninja 250R Tech Talk 8 October 26th, 2010 07:01 PM
where to buy headlight fuse ? tac12345 2008 - 2012 Ninja 250R Farkles 6 July 15th, 2010 06:40 PM
blown headlight fuse sombo 1986 - 2007 Ninja 250R Tech Talk 15 July 4th, 2009 11:00 PM
