Old January 26th, 2021, 11:37 PM   #1
sseN
Motorcycle(s): Ninja 250 EX250F
Issue Reassembling Left Control pod
Hey yall,Good Morning/Night which ever time youre reading this at. here goes another help thread by a newbie,be gentle please.
Earlier this week I went and bought an ex 500 clutch lever. Everything was going swimmingly thanks to the 250 wiki...however nowhere on the wiki does it say how to take the old perch/assembly off.Long story short I end up prying it off but in that process I took apart the left pod so I wouldnt damage it. Now I cant get it back together. Anyone ever done this?
sseN is offline   Reply With Quote
Old January 27th, 2021, 01:24 AM   #2
Did you take any photos along the way?
Post one of where you are with it now and let's see if we can point you in right direction.
Old January 27th, 2021, 10:37 AM   #3
sseN
took some just now. i see where there are indentions for the cable and the cable housing my problem is that im not sure how the lever fits,with the indention slotted on the top or the bottom,because i cant really pull the choke cable very far one way or another im not trying to break it, a secondary issue is that the bottom part where the cable is supposed to run outside of the housing isnt really wanting to go there
Old January 27th, 2021, 10:49 AM   #4
Hmm, did you use this page from 250 FAQ?
https://faq.ninja250.org/wiki/Replac...6_brake_levers
It's just one bolt to remove lever and one bolt to re-install. None of that stuff had to come part. Although it would make procedure easier if FAQ mentioned to loosen clutch-cable adjuster down by engine as well. Issue you have is you don't have enough slack on choke-cable and it's pulling choke-lever and cable-guide together and overlapping them, making re-assembly difficult.
Best to disconnect choke-cable from carb to have plenty of slack. Then it'll be much, much easier to re-assemble. You want to line up the channel that cable runs through and connect them between pieces. Then it'll make sense how it all goes together.
First, disconnect choke-cable from carbs: https://www.ninjette.org/forums/show...41#post1280141 . This can be done from side of bike without removing tank or carbs (don't be tempted to remove and lower engine). Might as well lube choke cable while you have apart.
Old January 27th, 2021, 11:01 AM   #5
sseN
thank you!so ill have as much slack as i need,if i dont have any lube will that prevent me from getting enough slack to reattach the choke cable to the carb?
how should the lever be positioned in the pic?
Old January 27th, 2021, 11:23 AM   #6
Lube not necessary, depending upon condition of cable. It's mostly maintenance-free as it faces much lower stresses than clutch-cable.
Lever should be aimed up in that photo.
Old January 27th, 2021, 12:35 PM   #7
There's plastic stud in centre of that cover that goes into hole in handlebar. If you don't line up stud with hole, you won't be able to clamp two halves together.
Old January 27th, 2021, 03:45 PM   #8
sseN
Big ups DannoXYZ! if i can figure out how to give you rep I will! everything is back together with much frustration,just need to buy a fuel line for my pet cock! the one i had was old and cracked when i went to snug it back on!
much love,mods can close the thread when they are ready.
Old January 27th, 2021, 04:28 PM   #9
Originally Posted by sseN View Post
...just need to buy a fuel line for my pet cock!
You have one of those? My wife has three pet rats.
Old January 27th, 2021, 08:24 PM   #10
AHAHHHAHAhahhaha!!
My wife wants to raise chickens, for eggs & food.
I remember seeing my mum hacking off chick heads and blood squirting everywhere!!! No thank you!
Old January 28th, 2021, 06:20 AM   #11
My mother's family had chickens during the depression. She told the story of her older brother's turn killing one for dinner. Unfortunately he was queasy around blood, got the chicken's head half off and fainted, leaving my mother to catch the thing, now running around the yard, and finish the job.
Old January 28th, 2021, 03:15 PM   #12
Reminds of this French chicken!!!
https://www.bbc.com/news/magazine-34198390
Left control switch question kg4kpg 1986 - 2007 Ninja 250R Tech Talk 5 October 11th, 2012 05:28 AM
