Old October 30th, 2017, 11:33 AM   #8001
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Originally Posted by Ram Jet View Post
Eeeeeyowww! Oh, Chris, you got some splainin' to do! Are you OK? And you thought you were going to be bored this winter.
Bill
I’m all good, got a month to fix it and the suit. Wee race in the winter.
TEAM ALFALFA
www.apexassassins.com
Old October 30th, 2017, 12:18 PM   #8002
Ram Jet
Ram Jet's Avatar
Oh yeah. AZ, I didn't notice. We race here too (not me).
Bill
Old November 3rd, 2017, 07:18 PM   #8003
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
tore down the 250 and dropped the frame off at a shop to fix the rearset mounting points.
TEAM ALFALFA
Old November 4th, 2017, 09:25 AM   #8004
Any close-ups of the damaged rearset mounting area? Thx
Old November 4th, 2017, 10:27 AM   #8005
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
This is a common problem
File Type: jpg 20218F37-3361-4F55-8FF5-326D85E8D9E7.jpg (111.4 KB, 144 views)
TEAM ALFALFA
Old November 4th, 2017, 10:55 AM   #8006
Hmmm, this feels very familiar.... Kinda like the rear-derailleur hanger on bikes. They would bend or get permanently damaged in crashes. A lot of racing frames were totalled because of damaged threads at hanger. Then Canondale came up wiht revolutionary solution, a replaceable hanger!
So... I'm thinking an intermediate plate between frame & rearsets. The plate would be attached with break-away bolts so it would get ripped away before sufficient force was applied to damage frame... Hmmm... or explosive bolts...
Old November 4th, 2017, 11:05 AM   #8007
Agreed, replaceable hangers are the way to go. They were around in the 1970s though, so while Canondale deserves credit for using them, they don't really deserve the credit for the idea.
Old November 4th, 2017, 06:50 PM   #8008
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
we already have a fix, solid metal plate welded to the frame in that spot.
File Type: jpg 6233CF98-55CC-4CC1-B933-4E37CCD28FD3.jpg (56.5 KB, 6 views)
TEAM ALFALFA
Old November 4th, 2017, 07:06 PM   #8009
Yeah, but a more solid metal plate will still bend due to leverage of rearset. Which will extend the damaged area further and possibly bend frame near swingarm pivots.
I'm going in opposite direction, gonna use aluminium bolts to hold rearsets on. At 1/3rd strength of steel, they might be just strong enough to hold everything together, yet snap easily during crash before any damage to frame is done. Maybe i'll do some destructive testing and if they don't snap easily enough, I'll hollow out the bolts slightly.
Old November 4th, 2017, 07:11 PM   #8010
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Im going with the proven strategy from other CVMA racers.
TEAM ALFALFA
Old November 5th, 2017, 10:26 AM   #8011
Run some quick numbers for a "realistic" shear and/or bending case that feasibly makes intuitive sense... you may be able to stick your aluminum bolts on the lathe and drill the centers to optimize their yield strength to what you need so it's strong enough for full rider weight plus some safety factor, but easy enough to break that you save the frame.
Old November 5th, 2017, 04:01 PM   #8012
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Well I picked up the Versys-X 300 yesterday & did 50 miles down country lanes & discovered a couple things. 1. The seat is rock hard, so will need sorted. 2. The screen being straight as in nearly vertical causes a lot of turbulence around my head, I'm 6'1". 3. There is a lot of resonance from the intake under the seat.
So the seat will take a while to sort out, a gel pad will be used in the mean time.
The screen issue was confirmed today by taking it off & having a short ride, no turbulence ! It's now been modified to a more rakish angle, so will test ride again & see if it helped.
The resonance will have to wait & see.
Jet washed the dirt from the lanes off today too.
Old November 5th, 2017, 05:24 PM   #8013
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Putting her back together, the bike is going to be ready, unfortunately I am not positive about my suit. Haven't put the forks back onto the bike yet as I am going to change the fluid.
TEAM ALFALFA
Old November 6th, 2017, 08:04 AM   #8014
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
Very cool. I think if they up it to a V-X-400 after the Ninja 400 release it may have to be considered for my next "all arounder" bike.
Old November 12th, 2017, 11:22 PM   #8015
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
Although not as expert as tearing up your ninja, I managed to get a new tail bag... yeaayy....
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old November 12th, 2017, 11:27 PM   #8016
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
how was the installation?
"trying not to get old"
Old November 12th, 2017, 11:32 PM   #8017
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
I suck at it.
Old November 16th, 2017, 09:42 AM   #8018
isuoboe
Motorcycle(s): 1981 Honda CB125S, 2006 Ninja 250
I ride all winter if it's not too cold and the roads are clear. (central Iowa) I stick to in-town, not-very-fast riding. It was 25ºF when I left on a couple of errands and almost took the car, then decided to try the balaclava. I took the balaclava off when I when into a store so they wouldn't think it was a stickup. Then I decided to ride without it to see the difference. It is definitely helpful in mid-20's temps!
isuoboe
isuoboe is offline   Reply With Quote
Old November 16th, 2017, 10:00 AM   #8019
I wear a balaclava any time the temperature is below about 50 or 55, but I tend to ride longer rides out in the country. It's amazing how much clothing it takes to stay warm when riding 55 mph for 100 miles.
Old November 16th, 2017, 06:06 PM   #8020
isuoboe
No doubt about that. One can bear almost anything for 15 minutes in town!
isuoboe
Old November 16th, 2017, 06:55 PM   #8021
Ram Jet
Ram Jet's Avatar
Yeah, 55 M.P.H. on a Kawasaki H2. Who's zoomin' who.
Bill
Old November 16th, 2017, 07:27 PM   #8022
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
I ride year around, but seeing shiny/damp patches on the road below 30, gets a little sketchy. 50 degrees is a relative to the time of year, if its fall, it feels cold, but spring its warm.
TEAM ALFALFA
Old November 16th, 2017, 07:30 PM   #8023
Yeah, 55 M.P.H. on a Kawasaki H2. Who's zoomin' who.:lie
I usually take the Moto Guzzi Mille GT on the long rides and multi-day trips, and I always stick to the smallest, most winding back roads I can find.
Old November 16th, 2017, 08:43 PM   #8024
Ram Jet
Ram Jet's Avatar
Dang, I thought I had ya!
Bill
Old November 16th, 2017, 09:59 PM   #8025
Bill, even when I'm out on the H2, I'm almost never going fast enough for a ticket. I've come to like curves more than straight line speed. Although once in a while a 2-stroke needs to get the oil that's collecting in the crankcase blown out good.
Old November 17th, 2017, 12:11 AM   #8026
Ram Jet
Ram Jet's Avatar
Agreed!
Bill
Old November 17th, 2017, 02:03 AM   #8027
The twisties are way more fun than going fast in straight line!!!
Old November 17th, 2017, 06:59 AM   #8028
"...once in a while a 2-stroke needs to get the oil that's collecting in the crankcase blown out good." - he says to the officer...
Old November 17th, 2017, 06:46 PM   #8029
Ram Jet
Ram Jet's Avatar
Hey TJ,
Which balaclava would you choose?
Bill
Old November 17th, 2017, 07:09 PM   #8030
I'm not sure. I have an Alpinestars:
https://www.amazon.com/Alpinestars-T.../dp/B001F112S2
Old November 17th, 2017, 07:22 PM   #8031
Ram Jet
Ram Jet's Avatar
Very nice!!! Well, the one on the left is $3.29 and the one on the right is $5.39 with free shipping. I think the Alpinestars will have to wait.
Thanks,
Bill
Old November 17th, 2017, 08:06 PM   #8032
MillerTime
MillerTime's Avatar
Motorcycle(s): CharlesdiubsOB
I put some fresh rubber on and then went and broke them in up in the mountains. I also put a stock length kickstand and dogbones on since the p/o had it lowered at some point.
After the mountains...love them on the Ninja as much as I did on my R3.
MillerTime is offline   Reply With Quote
Old November 17th, 2017, 08:07 PM   #8033
Anything is a lot better than nothing, so I'm sure you'll like the one you get. The Alpinestars version has two layers of skirt, one that tucks in and one that can stay on top or get tucked in to a different layer. Motorcyclegear.com has a good description.
Old November 20th, 2017, 07:47 AM   #8034
taz
taz's Avatar
MOTM - May '17
were did you get and what kind of tire changer is that on the back of your nissan?
Old November 20th, 2017, 07:51 AM   #8035
From a Google Images search, it looks like a No-Mar Classic tire changer and an optional hitch mount for it.
Old November 20th, 2017, 08:42 AM   #8036
MillerTime
MillerTime's Avatar
Nomar is correct.
https://www.nomartirechanger.com/Cla...tc-classic.htm
Old November 20th, 2017, 06:14 PM   #8037
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Thats a pretty sweet setup!
Bought a bigger tach (stock pregen) for the newgen 250 racebike. Not sure if its gonna work.
Dave Wolfe is offline   Reply With Quote
Old November 20th, 2017, 06:43 PM   #8038
It’ll work.
Old November 20th, 2017, 08:13 PM   #8039
MillerTime
MillerTime's Avatar
Thank you! I will mount it on the floor mount once we frame up the shop area in the basement...didn't want to drill the studs down until I finalized where it's going.
Old November 20th, 2017, 08:19 PM   #8040
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
Replaced the silicone water tubes.
TEAM ALFALFA
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
