Old February 28th, 2013, 08:30 PM   #3241
lolibater
lolibater's Avatar
Motorcycle(s): 2005 ZX6R, 2011 Sprint GT
Originally Posted by rojoracing53 View Post
Yeah it was a nice day out to go around swapping and buying parts for the Motos.
Got in a quick run through redwood, Pinehurst and canyon heading home
Smart move avoiding 880; it was a parking lot
"The enemy is fear. We think it is hate, but it is fear." - Gandhi
lolibater is offline   Reply With Quote
Old February 28th, 2013, 09:16 PM   #3242
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
What else is new?
Old February 28th, 2013, 11:22 PM   #3243
ricomtzjr
Razor's Edge
ricomtzjr's Avatar
Motorcycle(s): 2007 Sportster XL1200C
Chain cleaning and lube
I have been using the DuPont chain saver for the first 4000 miles. Since the Walmarts in San Antonio don't seem to have t here, I decided to try Maxima Chain Wax. Seems to go on very well, not as clumpy as chain saver. A little harder to clean overspray because it does have a tackiness to it. Otherwise, absolutely no fling an leaves a nice bronze film that is very helpful with showing what you have sprayed.
ricomtzjr is offline   Reply With Quote
Old March 1st, 2013, 02:06 PM   #3244
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Powdered the sprocket I got from Rick yesterday but I'm still waiting on the chain so I can install all this cool stuff.
Old March 1st, 2013, 07:49 PM   #3245
lolibater
lolibater's Avatar
Got my rear wheel aligned, chain slack adjusted, chain cleaned and lubed, cleaned the engine, and updated the fuel map a bit. Very productive day
Old March 1st, 2013, 10:34 PM   #3246
tfkrocks
tfkrocks's Avatar
Put on black swingarm spools. Conditioned the seats. Attempted to make the tank pad stick better but I think what's done is done. About to go for a ride.
Last futzed with by tfkrocks; March 3rd, 2013 at 07:19 PM.
Old March 2nd, 2013, 05:47 PM   #3247
BallsOfSteele
BallsOfSteele's Avatar
Motorcycle(s): 2012 Kawasaki Ninja 250r ( Candy Lime Green)
Brought It Home
BallsOfSteele is offline   Reply With Quote
Old March 2nd, 2013, 05:50 PM   #3248
lgk
lubed my clutch cable
Old March 2nd, 2013, 07:11 PM   #3249
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Checked tire pressures, lubed chains and fiddled around with my Z-Fi to get rid of an annoying bog at 5-5.5k RPM.
menikmati is offline   Reply With Quote
Old March 2nd, 2013, 07:23 PM   #3250
psych0hans
psych0hans's Avatar
Took delivery of a bunch of goodies for my baby.
1) dual electronics xgps150
2) digital tire pressure gauge
3) iPhone stabiliser tripod mount
4) battery tender junior
5) k&n oil filter
6) put together an extensive selection of tools for my new tool box.
Still waiting for some more parts to turn up. Can't wait to put everything to use.
Old March 2nd, 2013, 10:27 PM   #3251
ChrisCusi
ChrisCusi's Avatar
Motorcycle(s): 2013 Ninja 300 (Black)
Installed a battery tender cable and a USB power source to charge accessories!
ChrisCusi is offline   Reply With Quote
Old March 2nd, 2013, 11:54 PM   #3252
DeltaFoxtrotZulu
Motorcycle(s): 2013 Kawasaki Ninja 300
I wanna get one of those USB Power Sources. What one did you use?
DeltaFoxtrotZulu is offline   Reply With Quote
Old March 2nd, 2013, 11:57 PM   #3253
ChrisCusi
ChrisCusi's Avatar
I used a Tapp Lite from 3BR Powersports. Super easy. Black to negative battery terminal and red tapped into taillight so as to not drain the battery. Only provides power when bike is on. Works great! You can always wire it directly to your battery if you wanted.
Old March 3rd, 2013, 12:23 AM   #3254
psych0hans
psych0hans's Avatar
Put my bike up on the rear stand, strapped it down, connected PCV to the computer and ran it through all the gears(clutch less mostly) keeping it in the 10-13k rpm range. what did I achieve? I have no idea... lol I'm pretty clueless as to tuning it is concerned and don't have access to a tuning center either.
Bike strapped to the rear stand.
Non heat resistant power coat pretty much burnt off... Not sure if you can see the smoke, but it was smoking pretty bad before I took the pics...
Old March 3rd, 2013, 06:39 AM   #3255
S1att3r
S1att3r's Avatar
Motorcycle(s): White 2013 Ninja 300(Storm), Silver 2003 Fjr1300
Used the same one and hooked it up the same way, hardest part is routing the wires.
ATGATT
For all I know, women who ride motorcycles are all man-hating dominatrix's.
It was like a mild panic attack!
S1att3r is offline   Reply With Quote
Old March 3rd, 2013, 09:03 AM   #3256
psych0hans
psych0hans's Avatar
Later in the day I went to the service center to get some stuff sorted out. My issues were: -
1) Rear brakes not working properly - Seems the Banjo bolts or washers are causing a leakage in the rear brake lines, gotta get them replaced. I think I overtightened them while installation.
2) Front brake indicator switch was unplugged - got it fixed
3) Front indicators weren't working - I had wired them incorrectly, got it fixed.
4) Throttle not closing all the way and has lots of play thanks to my constant fiddling for the zip tie mod - gotta tinker with it a bit more as the cable is running off the cam, causing it to stick. I'll probably grind down a bit and add another zip tie to let the ribbed part act as a guide.
5) Got the coolant changed.
6) One side of my HID install is not working, gotta sort it out.
Gonna work on it a bit more tomorrow and install the tender cable etc...
Old March 3rd, 2013, 01:45 PM   #3257
cuong-nutz
cuong-nutz's Avatar
ordered new gaskets for engine tear down. Not really looking forward to it. I hope I don't have to order rings. Damn shipping is ridiculous.
Also, really not looking forward to spending more money on motor. Going to get the crank balanced as well.
HalfFast Racing Team
Old March 3rd, 2013, 07:16 PM   #3258
tfkrocks
tfkrocks's Avatar
Replaced OEM grips
Old March 3rd, 2013, 09:53 PM   #3259
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
So I'm still waiting on my chain so I can mount my new tires and in the mean time I can do anything but the necessary commuting on it, so no fun rides this weekend so if a can't ride then I guess I'll do the next best thing and work on it.
I traced a minor lose connection in my Koso wiring and did some rerouting of my birds nest of wires to clean it up a bit(I know its hard to tell but its better now)
Next on the list was my insanely hard to turn throttle. No it's not hanging up and it snaps back just fine, its just feels like it has the world stiffest Efing return spring. I've but wanting to do this for over a year but I HATE pulling the Efing carbs because its a total PITA with the airbox still in the way. After pulling it out and doing some inspecting I tried to take out on rotation of the spring but then it was to weak. So I split the difference and hung the spring about 90degs from it original location with some safety wire. I put it all back together and it felt a little better until I started the bike. After waiting a moment for the bike to idle properly from the carbs being dry I went to wick open the throttle and HOLY $HIT WHY DIDN'T I DO THIS SOONER. It's so much better now I can't wait for later this week when I ride 500 miles down to San Diego. I suspect my MPG is going to take a nose dive now that I don't have to physically prepare myself to twist the throttle.
Since I had my carb out I figured I'd give them a good cleaning because if at all possible I'd like to never have to pull the MoFos out ever again. There just a slight bit of grim on the out side that instantly fell off with a little WD40. I opened the float bowls to find that inside I've never seen carbs so clean before. I did a treatment of seafoam last month so that or the fact that I almost always run shell or chevron gas but there was just nothing to clean so I bolted it all back together.
I pulled the headers off so I could high temp powdercoat them black tomorrow.
Old March 3rd, 2013, 10:39 PM   #3260
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
Adjusted chain then drove her the usual 140 miles a day.
kirk595x is offline   Reply With Quote
Old March 4th, 2013, 10:58 AM   #3261
Joshorilla
Bass Master General
Joshorilla's Avatar
Changed the crappy oil out for Castrol GTX 10w-40 it seems to pull better at low revs, vibration is reduced and gear shifts are a little less clinky more clunky and the engine is a little cooler to run.
My clutch feels the same, I thought that may change but it didn't.
Old March 4th, 2013, 02:39 PM   #3262
LNasty
Daily Jap rider
LNasty's Avatar
washed her ass, gettin a little ripe down there
Old March 4th, 2013, 11:26 PM   #3263
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Finish blacking out the rest of my exhaust but I think ill try something a little different with the canister section when I have more time but for now it looks good enough.
Mounted flush mount protons but had to hold off on making the final connections till tomorrow so it would be done the right way.
New throttle spring setup may be to light or I've just adapted an iron throttle hand from it being stiff to long. I hope I just need to get used to it or else the carbs are going to have to come back out plus the bike feels just a little different off the bottom end it bogs just a hair but I'm hoping its just my perception from all the throttle changes and not something related to me cracking the magic seal on my perfectly balanced carbs.
Old March 5th, 2013, 02:35 PM   #3264
Joshorilla
Bass Master General
Joshorilla's Avatar
Checked my oil, seemed a little too full, has anybody noticed a difference between standing the bike upright and a paddock stand?
Old March 5th, 2013, 04:12 PM   #3265
kirk595x
kirk595x's Avatar
Bike needs to be on a level surface. It's easy on the old gen with a center stand. But if it's new gen just balance the bike from the side and look at the sight glass..easy breezy!!
Old March 5th, 2013, 06:40 PM   #3266
lolibater
lolibater's Avatar
Plugged it in to the battery tender
Old March 5th, 2013, 08:54 PM   #3267
kkim and Alex went back and forth about this and the conclusion was that it does measure differently when lifted on a stand.
Old March 5th, 2013, 09:06 PM   #3268
Yes, if just lifted up on a rear stand, it can be significantly different. If it's lifted on a front & rear stand, and is reasonably level, I have to believe that the level in the sight glass is close enough.
Old March 5th, 2013, 09:15 PM   #3269
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
I hauled Saturn home. Rented a trailer from UHaul. Tomorrow the baby 300 gets insured and registered.
Old March 5th, 2013, 09:19 PM   #3270
S1att3r
S1att3r's Avatar
Pulled the throttle off to do the zip tie mod but was unsuccessful. A combination of glue not strong enough and the zip tie being too stiff.
ATGATT
Old March 5th, 2013, 09:44 PM   #3271
lolibater
lolibater's Avatar
Just balance it with tires on the ground and look at the sight glass. EZPZ.
Old March 6th, 2013, 03:53 AM   #3272
psych0hans
psych0hans's Avatar
Making a trailer to haul my baby to the track... Should be ready by tomorrow. I'm targeting something similar to this.
Old March 6th, 2013, 05:43 AM   #3273
Joshorilla
Bass Master General
Joshorilla's Avatar
I initially filled her up to mid point in the sight glass on my paddock stand, I didn't want to replace the filter as the only reason I was chaining oil is because my bike is kept outside, and it's been a harsh wet winter, the oil was looking a little foamy and very black so potentially sludgy thus the Castrol GTX to "clean" my engine a bit, so this is purely a stop gap between a proper change so I wasn't able to gauge how much to put in due to retained oil in the filter being on an unknown quanity.
Also partly why I replaced the oil was because it seemed too high from the shop, they must also have done this on a paddock stand, as when I measure it with the stand jacked up to balance point "with a spotter" it comes all the way up to the top line with a tiny air bubble, I will probably go to the hardware store and get a length of silicone tubing and syphon some oil out for peace of mind.
Oh well, I don't seem to be burning any oil whatsoever so that's good, I have thursday & friday off work so I plan on topping up the radiator and giving her a once over
Thanks guys for the feedback.
Old March 6th, 2013, 05:45 AM   #3274
Joshorilla
Bass Master General
Joshorilla's Avatar
Easier said than done, the difference between a degree or two can make the difference between full or empty, and it's near impossible to feel the true balance point while by the side of the bike and not on it.
Old March 6th, 2013, 06:15 AM   #3275
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
New Michelin power one front 120/70 and Pirelli Rosso II rear 140/60.
New 15-42 sprockets and D.I.D. Chain
Pro grip neon orange rim tap
Old March 6th, 2013, 10:27 AM   #3276
lolibater
lolibater's Avatar
I guess I'm just a master at it then
practice makes perfect.
Old March 7th, 2013, 10:27 AM   #3277
Joshorilla
Bass Master General
Joshorilla's Avatar
I've got thursday friday off so I topped up my coolant and blacked out my windscreen, pics after the jump.
Old March 7th, 2013, 10:44 AM   #3278
psych0hans
psych0hans's Avatar
Backed off the preload in my GSXR600 shock all the way and managed to get 30mm of sag. Good enough I think.
Old March 7th, 2013, 10:53 AM   #3279
S1att3r
S1att3r's Avatar
Managed to finally successfully do the zip tie mod.
ATGATT
Old March 7th, 2013, 07:07 PM   #3280
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Parked her at Corbin all day while they made me a seat to my specs. It's way different then the standard 250 seat he originally walked out with and I'd say its already a little more comfortable and its a completly differ t shape so it still feels awkward.
The good news is I've gotten used to my easier throttle spring and love it and now that I e gotten two days on my new tires I have no idea how I was able to like the last set.
She got a lot of complements while sitting at Corbin for all her mods.
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
