Old October 14th, 2011, 08:12 AM   #1
Lowspeed Lowside
Tightwad Tinker
Lowspeed Lowside's Avatar
Motorcycle(s): '09 Ninja 250R
Delayed valve check
My bike has 6700 miles on it so a valve-check is past due. The bike has occasionally been ridden aggressively but usually stays between 6000-9000rpm under medium load. I'll be doing a 1700 mile trip soon (constant 70mph at ~8500rpm ) and I would really like to do all the maintenance myself (not a cost-saving measure, it's more of a 'pride' thing... My bike! Hands off! I do everything myself!) Unfortunately I have very little time (I met a special someone ... too much <3 <3 <3 to stay focused), so if I delay valve adjustments...
Q1: what's the worst thing that can be expected to happen?
Q2: what's the most likely thing that can be expected to happen?
Thanks in advance for the feedback.
Lowspeed Lowside is offline   Reply With Quote
Old October 14th, 2011, 08:16 AM   #2
Vampyre
Vampyre's Avatar
Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue
I believe the valve check is at 7500mi according to the manual.
Vampyre is offline   Reply With Quote
Old October 14th, 2011, 08:24 AM   #3
pop0tart
Motorcycle(s): stolen :(
I am at 6,700 too! Not past due for my valve check, though...going to do it over winter
pop0tart is offline   Reply With Quote
Old October 14th, 2011, 08:37 AM   #4
Lowspeed Lowside
Tightwad Tinker
Thanks, guys!
Note to self: definitely first check brain if working properly, then possibly check valves if working properly...
Old October 14th, 2011, 08:42 AM   #5
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Wait, you post ad nauseum about turbocharging, FI, all sorts of scientific and mathematical formula yet don't know what the results of tight valves would be nor do you know the maintenance interval?
Old October 14th, 2011, 08:54 AM   #6
Live2ride
Live2ride's Avatar
Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r
I got my 7500 mile valve check at 9500 miles and she ran like a champ the entire time.
Live2ride is offline   Reply With Quote
Old October 14th, 2011, 09:20 AM   #7
rusninja
Ninjette wanabe :D
rusninja's Avatar
Motorcycle(s): white 300 :D
Doesnt it depend how much their off. The more specs are off the more trouble. :S
VROOOM vrooom >.>
rusninja is offline   Reply With Quote
Old October 14th, 2011, 10:20 AM   #8
Lowspeed Lowside
Tightwad Tinker
Originally Posted by backinthesaddleagain View Post
Wait, you [...] don't know what the results of tight valves would be nor do you know the maintenance interval?
Not at all.
I don't know whether tight valves are an issue on a *'09 Kawasaki 250r engine* and whether the manufacturer's maintenance intervals are too lax in the experience of people who operate these engines.
Old October 14th, 2011, 09:49 PM   #9
KELPHYN
KELPHYN's Avatar
Just had mine checked, 52000kms (30,000mi) Still within specs and has never had an adjustment made ever. As long as your bike starts fine, isn't starting to use alot of gas, or was a tendency to stall and then hard to start 10-15 minutes after starting chances are valves are fine. If any of these symptoms start happening on a regular occurrence, start thinking valve adjustment.
P.S I regularly run my bike 9000+ rpms for hours.
Old October 14th, 2011, 10:12 PM   #10
pop0tart
Glad to hear that ..but I won't condone it either.
Old October 14th, 2011, 11:11 PM   #11
KELPHYN
KELPHYN's Avatar
When I said I just had them "checked", I should have said "checked again". Just meant to say they have never needed adjustment.
Stealership is at it again. How much was your valve check? Floki General Motorcycling Discussion 30 June 30th, 2014 06:48 PM
Valve Clearance check tsmith3605 2008 - 2012 Ninja 250R Tech Talk 3 July 26th, 2013 01:10 PM
How to tell if valve check was done? Looking at 09 250. rwheelz 2008 - 2012 Ninja 250R Tech Talk 5 September 18th, 2010 04:04 PM
Another valve check thread wellcraft 2008 - 2012 Ninja 250R Tech Talk 3 August 5th, 2010 01:23 PM
Question re valve check adouglas 2008 - 2012 Ninja 250R Tech Talk 16 July 7th, 2010 05:53 PM
