#1 |
Join Date: Jun 2010 Motorcycle(s): 2008 ninja 250 Posts: 168
Tech Questions
Hello, I am converting my bike to track and I have a few issues.
- Threaded bolt hole in front of engine with no bolt in it IMG_2429.jpg IMG_2428.jpg - New AP Exhaust rubbing on swing arm and about a millimeter gab between the header and flange. IMG_2425.jpg IMG_2426.jpg - Having trouble removing the carbs with the stock airbox. - Is there a rear shock install DIY? Help would be very much appreciated. Thanks
Colin #191 - Area P, Elka Shock, Woodcraft Clip-Ons and Rearsets, Attack Race Bodywork, BT 003RS, .700 Fork Springs, DynoJet Stage 2 and BMC High Flow Air Filter. 613 MOTORSPORTS.COM |
#2 |
There is the gap for the exhaust
#3 |
Missing bolt is a drain plug for the water pump. Replace it ASAP.
p/n# 132BB0610 BOLT-FLANGED-SMALL,6X & p/n# 92022-304 WASHER,PLAIN Flip the exhaust hanger bracket around (point the tip out). Loosen all exhaust bolts, make sure the exhaust header gaskets are seated properly, re-torque and check for leaks (tighten the header bolts first) |
#4 |
yes, loosen all exhaust bolts slightly, wiggle all the components so they are in the position you want them in, then start tightening the exhaust system from front and work your way back. that's in the installation instructions that came with your AP exhaust, if you bought it new.
http://www.ninjette.org/forums/showthread.php?t=10005 |
#5 |
Thanks Guys,
Any tips or tutorials on replacing a rear shock?
#6 |
#7 |
Elka
ecotrons tech questions. | bigbadbob | 1986 - 2007 Ninja 250R Tech Talk | 1 | April 17th, 2015 10:50 AM |
New Here, Have some Tech Questions | btovar250r | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 12th, 2011 10:54 AM |
[topix.net] - Motorcycle Tech Questions and Answers | Ninjette Newsbot | Motorcycling News | 0 | September 3rd, 2010 05:40 PM |
[topix.net] - Tech Questions & Answers | Ninjette Newsbot | Motorcycling News | 0 | August 13th, 2010 10:30 PM |
[sportrider - tech] - Street Tires, Clutch, And Cylinders - Questions And Answers - A | Ninjette Newsbot | Motorcycling News | 0 | March 29th, 2010 11:40 PM |
