Old July 31st, 2014, 12:19 AM   #1
Triple R
Motorcycle(s): Suzuki's
- - -Bike Wont Start - - -
I have a 2010 250 that I'm currently building into a race bike. For some reason the bike wont start now (go figure). I tore the bike down to clean/inspect everything and now she wont crank at all.
The battery & fuses are good, there's fuel in the tank, and the ignition and on/ off switch is all on. The kickstand and clutch switches are unplugged (not sure if that is the problem, however I've started it before with those 2 switches unplugged). The ground wires to the starter and engine are connected. The bike is also in neutral. Kinda going off on a limb here and asking for help online (although I know it's very hard to diagnose over the interwebz). Don't think this bike has a tip over sensor (or from searching the manual I can't find one). When I jump the starter relay it cranks but it wont start either. Any help would be much appreciated! If nothing works I guess I'll have to just drop her off at the local shop. Thanks in advance guys!
Triple R is offline   Reply With Quote
Old July 31st, 2014, 06:54 AM   #2
Plug the kickstand and clutch switches back in and give it a try. If that doesn't do it, start tracing wires and checking connectors and grounds.
You'll figure it out. You can't take a race bike into a shop to have it worked on! It's just not right. You have to figure it out yourself.
Tank under pressure and bike wont start Shawn250 2008 - 2012 Ninja 250R Tech Talk 4 May 13th, 2012 01:42 PM
Friend's bike wont start... ideas? setasai General Motorcycling Discussion 7 August 3rd, 2011 07:41 PM
bike wont start after new flasher relay onizthegnome 2008 - 2012 Ninja 250R Tech Talk 7 December 12th, 2010 12:32 PM
Bike wont start, please help? zev42 2008 - 2012 Ninja 250R Tech Talk 11 November 9th, 2010 01:02 PM
uhh, bike wont start. ajaygraci 2008 - 2012 Ninja 250R Tech Talk 37 June 24th, 2009 06:39 PM
