March 28th, 2010, 09:47 AM | #1 |
Overheat!!
Ok, so I left the bike idling for about 8 minutes after a ride (stupid I know). When I came back to check on it, the fan was on and I noticed my temp light ON! What damage did I do to the bike? Am I f*****? It seems to be running fine right now.
March 28th, 2010, 09:53 AM | #2 |
As long as the radiator fluid did not boil over you should be fine. Check the radiator fluid level and check the oil to make sure it does not look or smell burnt.
March 28th, 2010, 09:54 AM | #3 |
I use distilled water as my coolant and because it is distilled water, I didn't smell anything burnt, and there's plenty of water left in reservoir.
March 28th, 2010, 10:01 AM | #4 |
Do you use water weter also or just distilled water?
March 28th, 2010, 10:04 AM | #5 |
Oh and when I noticed the light, I turned it off for like 8 seconds and it dawned on me that it needed more air to blow on the radiator fins so I started driving it. The light went away after about 15 seconds of driving.
March 28th, 2010, 10:04 AM | #6 |
March 28th, 2010, 10:08 AM | #7 |
You might want to consider an additive such as water weter.
March 28th, 2010, 10:10 AM | #8 |
March 28th, 2010, 10:14 AM | #9 |
Yes I think the bike should be ok. Watch for oil consumption. If the level starts going down that is a sign of thermal break down. If it starts using oil, change it and it should be ok with new oil.
March 28th, 2010, 11:48 AM | #10 |
A little water wetter will help a bit. It's pretty cool, the way it works is by lowering the surface tension of the water, so heat conducts better from the radiator surface to the water. Unlikely you did any real damage in 8 minutes.
March 28th, 2010, 12:09 PM | #11 |
What kind of damage should I expect, if there is one? This way, I can monitor the bike and see if anything need to be repaired ASAP. Thanks.
March 28th, 2010, 12:21 PM | #12 |
Total and complete engine failure. I think you should give away the bike to a friend at a shockingly low price right away.
If everything is still running fine right now, the coolant level is still appropriate, the worst thing you may have done is taken some life out of the oil, and perhaps your next change should be a little early.
March 28th, 2010, 12:22 PM | #13 |
why is it that you only have water in your cooling system?
March 28th, 2010, 12:33 PM | #14 |
Thanks Alex and Rick. I'll monitor the oil to make sure it's not depleting.
March 28th, 2010, 01:42 PM | #15 |
MOTM - Mar '13, Jun '14
Strictly race bike (for the street).
OVERHEAT | heyzeus | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 7th, 2014 07:08 AM |
Totally and completely lost on overheat issue | surlistyc | 1986 - 2007 Ninja 250R Tech Talk | 43 | August 28th, 2012 08:06 AM |
Overheat Issue | Avenged7Fold | 1986 - 2007 Ninja 250R Tech Talk | 18 | April 30th, 2012 12:42 AM |
