Old May 3rd, 2013, 06:44 AM   #1
ninja_thresh_hold
ninjette.org *********
ninja_thresh_hold's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r
how to check a motorcycle engine to see if its good?
Okay, so I'm buying a ex500r engine to swap into my 250 and need to know how to chick the engines health, it's not on the frame and it isn't known if it runs, so how can I check it out?
Last futzed with by ninja_thresh_hold; May 3rd, 2013 at 08:47 AM.
ninja_thresh_hold is offline   Reply With Quote
Old May 3rd, 2013, 07:49 AM   #2
Eric,
I would make sure that the engine has enough and good lubricant inside before testing anything.
Secondly, I would anchor the thing solidly, keeping it properly leveled.
Clean or new spark plugs.
Then, I would connect fluids, sensors and power to it, verifying that vacuum tubes are OK and hooked or capped.
A compression test will tell you how worn the piston-rings-cylinders are.
A leak-down test will tell you how well the valves isolate the cylinder.
http://www.dansmc.com/compression_test.htm
http://www.dansmc.com/leakdown.htm
If the thing is in decent shape and no noises are present when turning it by hand, I would try firing it up.
The most probably is that the carbs are dirty inside and that you will need to clean and re-try starting up.
...........or you could skip all those steps and just buy it as is...........
Old May 3rd, 2013, 07:50 AM   #3
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
You smoke too much weed
AFM #676
Supersports are for n00bs
Old May 3rd, 2013, 07:51 AM   #4
ninja_thresh_hold
Originally Posted by Motofool View Post
Eric,
to the best of my knowledge it is not on a frame, so i dont think i can start it, but i think i might just low ball him saying that idk if it works, i mean hell, 100$ for an engine would be a hell of a deal whether it needs rebuilt or not lol
Old May 3rd, 2013, 08:40 AM   #5
ninja_thresh_hold
I didn't realize there was a such thing! Lol, what makes you say that?
Old May 3rd, 2013, 08:44 AM   #6
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Your entire OP
AFM #676
Old May 3rd, 2013, 08:45 AM   #7
ninja_thresh_hold
Your entire OP
Lol ah ;P I edited it, I was kinda tired when I posted it lol
Old May 3rd, 2013, 08:48 AM   #8
Not to hate here, but someone's going to say it:
Why not just buy a 500? You'll get a bike that has service history and can be test-ridden.
Now that that's out of the way,
Motofool is dead on. First thing I'd check is that nothing touches/bumps when turned over by hand. If that's good, I'd buy it on the spot for as cheap as possible.
Then starting it is the basics:
fuel
spark
air
compression
Don't forget to give the engine a thorough once-over to make sure things like rocker arms aren't broken. Open the oil filter thing to check for metal shavings on the filter etc etc. As long as it looks alright, go for it.
If you see metal shavings or bent rocker arms, run the other direction.
Old May 3rd, 2013, 08:58 AM   #9
ninja_thresh_hold
fuel
spark
air
compression
The reason I'm doing a swap is because I have grown to love the looks of my bike, and I have a lot of work in it, but I want more power, but not as much as a zx6r can provide, and the 500s are ugly IMO, so I'm going to swap the engine for a 500, and take the 250 engine and put it on a kx250 frame, and have a faster bike for the street, and a nicely running dirt bike.
Old May 3rd, 2013, 09:09 AM   #10
Joshorilla
Bass Master General
Joshorilla's Avatar
Get a zxr400 they're loooovely
Old May 3rd, 2013, 09:14 AM   #11
I'm not critiquing the swap. I'm just putting it out there because SOMEONE inevitably will say it. So I got it out of the way for you.
I'd go for it. When in doubt, you can always part out the engine on Ebay.
Old May 3rd, 2013, 09:16 AM   #12
Joshorilla
Bass Master General
Joshorilla's Avatar
What chode said, also, if he can't prove it's running i'd expect that to be reflected in the price.
Old May 3rd, 2013, 09:16 AM   #13
ninja_thresh_hold
Yeah, and if it does work out, I'll still have a dirt bike that I can sell for a profit
Old May 3rd, 2013, 09:17 AM   #14
ninja_thresh_hold
That's why I posted here, so I can know how to check stuff myself, and tell him I'll give him like 100$ or so for it since idk if it runs
Old May 3rd, 2013, 09:20 AM   #15
Joshorilla
Bass Master General
Joshorilla's Avatar
How much is he asking for it, if it looks to be solid, i'd say max of $200, $100 if it looks to be a bit knackered.
Make sure it includes the carbs and such, last thing you want is to source random expensive replacement parts, this is why a donor bike is often better.
Old May 3rd, 2013, 09:23 AM   #16
ninja_thresh_hold
He says complete engine, so it should have everything. He's parting out 2 500s and I just texted him and asked about it
Old May 3rd, 2013, 09:24 AM   #17
Jono
Jono's Avatar
Or you could just get one of these...
Old May 3rd, 2013, 09:28 AM   #18
Some relevant threads here:
The Ex 500 Engine swap with pics
Custom 09 ninja 250 with ex 500 or 650r engine + others
Old May 3rd, 2013, 09:32 AM   #19
ninja_thresh_hold
Originally Posted by Alex View Post
Thanks Alex, yeah I've read those before, I'm just trying not to get screwed over on an engine I can't use
Old May 3rd, 2013, 09:40 AM   #20
ninja_thresh_hold
Is that a cbr 500?
Old May 3rd, 2013, 09:45 AM   #21
Jono
Jono's Avatar
Originally Posted by ninja_thresh_hold View Post
Is that a cbr 500?
Yes!
Old May 3rd, 2013, 11:21 AM   #22
AFazakerley
AFazakerley's Avatar
Motorcycle(s): 2000 Ninja 250
See if you can turn the engine over manualy with-out spark plugs in, then turn it over with plugs in. Should be able to feel compression to certain point.
AFazakerley is offline   Reply With Quote
Old May 3rd, 2013, 11:27 AM   #23
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I don't think I've ever seen used oil, or a filter without metal particles
Old May 3rd, 2013, 12:07 PM   #24
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I liked the old op better
AFM #676
Old May 3rd, 2013, 12:51 PM   #25
My filter never has metal filings in it. Neither does my oil. I put a magnet in a plastic bag, then run that through the old oil to check. The metal filings would get stuck to the outside of the bag if there were any.
Are you thinking that metal shavings are normal? Or is this just because your bike is still brand new? Sorry, Idk what you were suggesting exactly.
Old May 3rd, 2013, 12:55 PM   #26
JohnnyBravo
Naw... I ran the army oil analysis program, so I saw on the machine the metal particles that were microscopic, so even if you can't see them they exist... Glad you can't find them though
Old May 3rd, 2013, 01:00 PM   #27
Oh gotcha. Well I meant like giant shiny metal shavings that would imply that something bad was happening. Of course there's going to be a bunch of tiny particles of metal in any engine oil
Old May 3rd, 2013, 01:18 PM   #28
Joshorilla
Bass Master General
Joshorilla's Avatar
Infact they add tiny particles of metals to most oils! Zinc being a notable one.
Old May 3rd, 2013, 02:17 PM   #29
JohnnyBravo
I didn't have any smarty, useful things to say besides all oil got metal stuff in em.
Chone glad you care enough for your bike to go the extra miles!!!
Old May 4th, 2013, 02:35 AM   #30
KawiKid860
KawiKid860's Avatar
Shut up, just shut up!
Do you know how many miles are on the engine? These 500 engines are a little more fragile than a lot of other bikes due to awkward design on kawis part. A really abused 500 motor can be trash around 20k miles, but a well cared for one can go for as long as any other sport bike engine. I'd just stay away from one in unknown condition, bad things happen if you continually go over 10,500 rpms.
Old May 4th, 2013, 06:25 AM   #31
Interesting. Have a little more info on this?
Old May 4th, 2013, 06:48 AM   #32
ChaoSS
Motorcycle(s): 2012 red 250 ninja
I think if you don't know enough about engines to know how to check one out, you don't know enough to do a proper engine swap.
Just my thought.
ChaoSS is offline   Reply With Quote
Old May 4th, 2013, 01:35 PM   #33
how to check if an engine is good.
has fluids, still in bike:
run the engine, get it up to temp. does it sound horrible? is it spewing fluids? does it even run? ok good so its looking good so far. do a compression test. still good? drain the oil and catch some oil with an oil test kit then send it off to the lab to be tested. when the results come back if it tests clean its probably good.
no fluids, out of bike, off ebay or something:
disassemble the engine and examine the crank and bearings, valves and seats, pistons, cams, the trans, do ohms checks on the stator and pickup coils, check the oil pump and all the seals. make sure nothing is bent (crank, rods, trans shafts or forks) if everything looks good, reassemble. otherwise replace or fix whats broken or toss it aside for spare parts in the future.
Old May 4th, 2013, 04:54 PM   #34
KawiKid860
KawiKid860's Avatar
I spose I could get some info from ex-500.com but I'm too lazy right now. OP may want to check it out himself.
Also just saying if you start pulling the 500 engine apart you have to lap the head before reassembling or else it'll be toast before you go 500 miles. Buying a replacement motor is usually a lot cheaper than rebuilding for the 500 unless you can do it all yourself and are pretty good at it.
Another note, make sure you get a 2nd gen engine (1994-2009) or if you get a 1st gen (1987-1993) You'll want to replace the CCT, flywheel, transmission and probably a few other bits with 2nd gen units.
Old August 25th, 2013, 04:58 PM   #35
ninja_thresh_hold
ended up gettinga zx6r instead
Old August 25th, 2013, 07:57 PM   #36
ChickenRun
ChickenRun's Avatar
Motorcycle(s): 2010 250r SE (without stupid tribal decals)
Awww quitter
"It sounds like a lawnmower."
"Shut up no it doesn't."
ChickenRun is offline   Reply With Quote
PSA - Check your engine covers. red5 2008 - 2012 Ninja 250R Tech Talk 4 October 21st, 2013 02:18 PM
Check out my DIY engine stand headshrink 2008 - 2012 Ninja 250R Tech Talk 4 January 1st, 2012 12:08 AM
Pre-ride inspection: Don't forget to also check that your engine is still attached. Skippii General Motorcycling Discussion 5 September 14th, 2011 09:52 AM
Why it's always good to check your tires before any ride... capt_bugaloo 2008 - 2012 Ninja 250R Tech Talk 8 September 23rd, 2009 06:21 PM
Possible upgrade: Things to look for and check on a good deal... Verus Cidere General Motorcycling Discussion 33 May 24th, 2009 05:01 AM
