Go Back   ninjette.org > General > Pictures
Old December 29th, 2008, 03:23 AM   #1
shporsche
shporsche's Avatar
Motorcycle(s): Ninja 250 09
New bits from Christmas
Hi,
Over Christmas santa has contributed some new parts for my bike.
Here are some shots of my new Yoshi exhaust, Targa tail kit and Intuitive frame sliders.
and a few dodgy shots with my Iphone, first pic is the cool little billet light in the tail kit and the others are 2 bikes that I rode with over the last few Christmas days.
shporsche is offline   Reply With Quote
Old December 29th, 2008, 10:08 AM   #2
HKr1
IC2(SW)
HKr1's Avatar
Nice!
Old December 29th, 2008, 11:13 AM   #3
Yes, very nice!!
Old December 29th, 2008, 11:55 AM   #4
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I've got a Targa fender eliminator, 15 tooth sprocket, and rim stripes to install. Did you get the Targa kit for stock signals where it has an aluminum piece on the bracket that is threaded?
k-os is offline   Reply With Quote
Old December 29th, 2008, 05:26 PM   #5
shporsche
shporsche's Avatar
thanks guys.
Sorry k-os dont understand your question. I used all the pieces from the kit with no troubles. I dont think the indicators are approved, so I may switch back to the stock ones.
Old December 30th, 2008, 11:29 AM   #6
Syphen
Some weird Canuck!
Syphen's Avatar
Motorcycle(s): '92 CBR250RR "Babyblade", 2008 Ninja 250R, 2001 CBR600F4i
Wow that pipe looks great. I've never seen shots of the tip. Looks great.
Syphen is offline   Reply With Quote
Old December 31st, 2008, 02:46 AM   #7
NJD022588
NJD022588's Avatar
Motorcycle(s): '09 Ninja 250R
Looks great! The carbon fiber pipe really tops it off.
Looks like iPhone makes the left side of pictures blurry.
NJD022588 is offline   Reply With Quote
Old January 1st, 2009, 11:21 PM   #8
shporsche
shporsche's Avatar
Ive only just noticed the phone was doing that, thats Iphone's for ya.
I recently added a seat cowl, it looks great. I'm unsure on how well the cowl mounts, hope it doesnt come flying off.
Here is a pic
Old January 2nd, 2009, 12:03 AM   #9
As long as it "clicks" and latches when you push it down at the front of the cowl, it should be secure and can't fly off.
Old January 2nd, 2009, 01:58 AM   #10
shporsche
shporsche's Avatar
thanks for the tip
Old January 5th, 2009, 08:46 PM   #11
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
I ahve got a rear cowel on my bike and I have found that is needs a firm push at the front to ensure it fully locks. Also, be sure not to put too much presure on the back as it can snap the pads that hold it firm (I found out the hard way) the cowel is still usable, it is just loose at the back.
Viper-Byte is offline   Reply With Quote
Old January 5th, 2009, 10:17 PM   #12
shporsche
shporsche's Avatar
I had a issue with the cowl today.
I rekon, kawa could have put a little more thought into how its installed, why not keep the same method as the seat.
Any way, I went out to grab some lunch and noticed the cowl wasnt sitting properly at the back, so took it of and reistalled it. When I tried to re-install the cowl, it just kept popping the gromit through. Its very hot today, 38-40deg, and it makes the grommit more floppy allowong it to fall strait through.
So I got some epoxy and glued the grommit in. Just installed the cowl, and now I get a small click. The cowl doesnt move for now, but its only a quick fix. I rekon the Epoxy will crack under the vibrations, so I need a stong flexible glue like fletchtite, but its hard to find.
Anyone else modded the seat cowl?
Old January 5th, 2009, 11:23 PM   #13
Viper-Byte
Viper-Byte's Avatar
Yeah, the same thing happened to me, I lost the rubber gromit, not sure when and after that the pads broke off. I am now going to look for another rubber gromit, though I can't see it being too hard to mod so it is the same as the seat. Maybe cut the part the fits into the gromit and then fix a plate with hooks like the seat to hook under the part where the rubber gromit sits. This to me would be far more secure.
Old January 6th, 2009, 12:16 AM   #14
shporsche
shporsche's Avatar
Yup I though about that, take out the 2 grommits on the back, so I can use them for mounting positions when I install a bracket simular to the one on the standard seat. Give it a go when I got some spare time and let you know how it goes.
Old January 6th, 2009, 12:21 AM   #15
Viper-Byte
Viper-Byte's Avatar
Cool, I would like to know how you get on. You could take pics of the process and then make a DYI for everyone else if the wish to do this.
I have got some HIDs to install and AP exhaust system to order and install before I will be doing this
Old January 6th, 2009, 12:23 AM   #16
... and carbs to shim.
Old January 6th, 2009, 12:26 AM   #17
Viper-Byte
Viper-Byte's Avatar
Hmmm... Yes, how could I forget them...
Old January 6th, 2009, 03:47 PM   #18
shporsche
shporsche's Avatar
I'm doing the shims very soon, just added an exhaust.
Yup I will do a DIY most probably this weekend, good idea viper.
Old January 6th, 2009, 04:01 PM   #19
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Beast had problems with his, and this is what was posted elsewhere about it... I know I saw at least one other mod to it as well, so I'll keep looking and edit as I find them:
http://www.kawiforums.com/showpost.p...48&postcount=2
Here was another:
http://www.kawiforums.com/showpost.p...89&postcount=1
Dipped a few bits Shell-case 2008 - 2012 Ninja 250R Farkles 2 July 18th, 2013 01:59 PM
250R Track Bits pjed Items Wanted 2 October 23rd, 2011 09:27 PM
Last bits WickerPig Motorcycle-related 0 September 25th, 2010 04:27 PM
87-07 engine bits ecannon1 Motorcycle-related 5 June 1st, 2010 10:51 PM
HO! HO! HO!! Merry Christmas!!! HO! HO! HO! What Can I get You for Christmas???? kkim General Motorcycling Discussion 55 December 23rd, 2008 03:59 PM
